I have an OpenMQTTGateway to collect date from BLE devices.
The new Xiaomi sensors like LYWSD03MMC are encrypting the traffic.
My OpenMQTT gateway does see the servicedata and the servicedateuuid so would hope I can decod this somehow with the bindkey a got via tool on https://github.com/atc1441/ATC_MiThermometer
I would like to use the curren OpenMQTTGateway and not add again another ESP just to do the decoding.
Hey thanks for the reply. Did try it but still don’t get it as seperate fields. I expect it is part of the servicedata mqtt message but how do you get it out/decoded
Yes I did select custom.
I don’t get a json message but the servicedata message is different now.
it starts with the mac address 00 and I think values in hex
frist two look the temp in hex so expect to find the rest after that but I’m not that experienced in stripping strings and converting hex to decimal and certainy not in hassio.
My openmqttgateway is configured to send separate mqtt messages for every value and not json because that is easier. Maybe that is teh problem
Your devices are flashed with the custom firmware and the setting “Custom” advertising type.
You see the smiley blinking (to verify you have custom firmware).
But you don’t get temperature data into the json.
my smiley is not blinking but when I change battery visible it does work
also i don’t get temp/hum any more in the flashing tool and also when I connnect it states custom firmware.
It also has an ATC name now
Can’t find the mqtt gateway version. Looks not in the files and is not send as mqtt topic.
Started playing with it jan 2020
it is indeed a hex string : mac 00 temp hum bat rest I didn’t find what it is
Thanks, Was just reading your documentation and saw LYWSD03MMC was added in v0.9.5
Will download it tomorrow and test it. I have to check what I changed in the config to get it working.
thanks for helping and building this nice gateway.
Strange is that my smily doesn’t blink while it is on al the youtube tutorials
Hi, I flashed the new version and try to force it to manual setup but it doesn’t do it.
It looksit forces the esp into a sleep since it never leaves the setup part and tries the setup from time to time.
It looks to work with the wifimanager mode but strange thing is it just starts with the stored sid and password and doesn’t setup an access point.
Could you tell me what stupid mistake I’m making here.
This config does find the LYWSD03MMC_ATC and I do see the values in the json in the esp console.
Some issues I have
if I change the value for Base_Topic it stays home/…
the cleargrass no longer publishes the battery value but I do see a value tem what is the same as tempc
Yes I’m sure the cleargrass did publish the battery. Will see if it comes back.
I will also try to erase the flash and hope it will solve the wifi stuff
Any idea about the basic_topic that stays at home ?
It wasn’t home before I uploaded v0.9.5 so that looks a different issue ?
I changed the software a few times on the ESP but it still keeps home/…
Alse the cleargrass still doesn’t sent the batt info. I have the feeling the “tem” value it does send now is not necessary and replaced the “batt” value.
The new ATC_ do send the batt info inevery message.
The cleargrass model is : CGG1
For the ESP I don’t know more than uploading the config via arduino ide.
Could you point me to a link if possible.
Sorry if this looks a stupid question.
