M-Bus (Meter-Bus) on Raspberry Pi Integration
I’d like to share how I managed integrate an M-Bus connected water meter into HA. M-Bus or Meter-Bus is a specification for a serial bus and communication protocol that is popular for smart meters. These meters usually have long-lasting batteries (10 years+) that will last even longer when the meter can draw power from the bus. In this way the meter has a persistent counter value, and one doesn’t miss any counts, even if the meter is not read for a while.
Unfortunately most M-Bus interfaces are quite expensive, but a cost-effective solution is available for the Raspberry Pi as a so-called Hat from packom.net. They also provide a RESTful server mbus-httpd) that runs on the Raspi, which in turn can be integrated into HA via the rest platform. The RESTful server returns XML formatted meter data (in my case counted water volume, timestamp, etc.), without requiring any instructions. Apparently the M-Bus interface provides the server with all of this information.
I am running HA OS on a different Raspi than the one that runs the RESTful server. The respective part of my configuration.yaml looks roughly as follows:
  # water meter
  - platform: rest
    resource: http://raspberrypi.home:8080/mbus/get/ttyAMA0/2400/0
    method: POST
    value_template: "{{ value_json.MBusData.DataRecord[0].Value | int }}"
    unit_of_measurement: "l"
    scan_interval: 60
The resource URL is straight from the mbus-httpd. I had to play around a bit with the proper value_template to extract the one value I am interested in from the JSON-converted XML. HA’s template test page was quite helpful in this respect.
I hope this may be helpful for others, too.
I’d like to read data from my water meter by using M-Bus and then feed HA. Are you aware of any step-by-step guide for the whole setup?
Thanks!
not really, that would be quite a few steps, depending on what you already have in terms of hardware and software. Do you already have an M-bus interface? If yes, which kind?
Thanks for your reply. Actually I’ve realized that my water meter supports wireless M-Bus. I don’t have an interface yet, therefore I’m trying to understand what’s the best approach for my use case.
unfortunately I have no experience with wireless M-bus. I suppose once you have a device to read the wirless M-bus, it will be possible to hook that into HA.
Hi, did you find a solution?
I don’t have a final solution yet. On my spare free time I’ve been trying to implement a solution based on ESP32 + CC1101 and this firmware GitHub - chester4444/esp-multical21: ESP8266 decrypts wireless MBus frames from a Multical21 water meter
If that worked fine, data would be available on MQTT.
Hi
can you share us your full code in the config yaml?
Did that work out for You?
I am somewhat reluctant to set up a Pi just for converting MBus…
Nope, sorry. I wasn’t able to progress, I couldn’t spent time on it.
Hey, any news ? Would be great to have water meter i ha to avoid any leaks
Hi, today I was finally able to read data from my water meter Multical21 via wM-bus.
Do you still need help?
Hi pazzotranquillo and all,
I am looking to achieve the same to read my instant/daily/montly water consumption through Home Assistant.
I have this [1] Pulse meter on my counter (which is therefore covered) installed by my water provider, and I wanted to know if I can do something with it, or if there are other effective/working solutions to do so.
Any idea is more than welcome!
[1] https://prod-edam.honeywell.com/content/dam/honeywell-edam/pmt/hps/products/sme/water/digital-metering/wmbus/falcon-mj-pulse-mbus/Falcon-MJ-Pulse-MBus-specs.pdf
Hi. I’m interested in your solution reading data via wM-bus. It looks like you don’t need an extra computer for that, which is what I’m searching for. Also this topic is older than a year I hope to get an answer.
Regards
Hi, I achieved that with Esphome in combination with this external component: github://SzczepanLeon/esphome-components.
In my case I’m using an ESP32 + CC1101 which supports multiple frequencies (https://aliexpress.com/item/1005008223029421.html)
Here is my sketch:
esphome:
  friendly_name: esp-004
esp32:
  board: esp32dev
  framework:
    type: arduino
logger:
  level: DEBUG
api:
  encryption:
    key: !secret api_key_esp-004
ota:
  - platform: esphome
    password: !secret ota_pwd_esp-004
wifi:
  ssid: !secret wifi_iot_ssid
  password: !secret wifi_iot_password
time:
  - platform: sntp
external_components:
  - source: github://SzczepanLeon/esphome-components@version_4
    refresh: 0d
    components: [ wmbus ]
wmbus:
  mosi_pin: GPIO13
  miso_pin: GPIO23
  clk_pin:  GPIO22
  cs_pin:   GPIO14
  gdo0_pin: GPIO21
  gdo2_pin: GPIO18
  led_pin: GPIO0
  led_blink_time: "1s"
  frequency: 868.950
  all_drivers: False
  sync_mode: True
  log_all: False
  mqtt:
    broker: 192.168.1.50
    username: !secret mqtt_user
    password: !secret mqtt_pwd
  - platform: wmbus
    meter_id: !secret multical_id
    type: multical21
    key: !secret multical_key
    sensors:
      - name: "Multical21 RSSI"
        field: "rssi"
        accuracy_decimals: 0
        unit_of_measurement: "dBm"
        device_class: "signal_strength"
        state_class: "measurement"
        entity_category: "diagnostic"
      - name: "Multical21 Water Usage"
        field: "total"
        accuracy_decimals: 3
        unit_of_measurement: "m³"
        device_class: "water"
        state_class: "total_increasing"
        icon: "mdi:water"
