M5 Atom Echo setup issues
I have been trying all day to get this into Home assistant. I got it to show in devices once with an Add button and this seemed to work as it found ESPHome builder but I have not been able to install anything on it even though it is connected locally when it gets to the end is states it is unable to find the device by IP. I have since tried flashing from Ready-Made Projects — ESPHome as a voice assistant from Chrome and Edge but it just sits there with a spinning wheel stating “Preparting installation”. I have left it running for more than an hour on both browsers with no luck. I was following $13 voice assistant for Home Assistant - Home Assistant and even that connect button does not work. Both ways detect the atom and I have used this machine to setup esp32’s for BT proxy and temp and humidity but this has got me stumped. I will gladly try anything and supply whatever logs would be useful.
4 hours and it is still preparing installation. I would think it would be able to prepare without connecting to the device at all but nothing and the contact on the website is (no support!) which I find unusual for a Home Assistant maintained codebase.
What OS are you using?
Windows 11 on two machines and the same then I tried Chrome on a MacBook and it worked in less than 30 seconds. I have other issues now with the config on GitHub. I’ve posted those on the GitHub though.
Also when uploading from the Mac with Chrome when it gets to 100% it crashes the whole browser every time, not the tab but the whole browser.
