I’m experimenting with various ways to make a noise with the M5Stack Atom Echo.
Using the pin assignments from the voice assistant instructions, changing type from esp-idf to arduino, I have it working – sort of. When playing a wave file from HA (local media) the result is full of static.
I’ve read notes, generally associated with the voice assistant, about it (not exactly sure what it is here) not supporting raw files, and that the voice assistant platform is incompatible with media player (but I’m not using it). But there do not seem to be a lot of people using this as a media player alone.
My real goal is just to make a noise in a standalone environment, RTTTL would be fine. The media player is an intermediate step. But now I’m baffled as I do not see anything that might impact quality of playback, especially static (I mean, it’s digital). I can play the same wave file on a nest mini (as media player from HA) and it’s perfect.
Any thoughts or advice?
Here are the relevant portions:
esphome:
friendly_name: ${friendly_name}
esp32:
board: m5stack-atom
framework:
type: arduino
i2s_audio:
i2s_lrclk_pin: GPIO33
i2s_bclk_pin: GPIO19
speaker:
- platform: i2s_audio
i2s_dout_pin: GPIO22
dac_type: external
mode: mono
media_player:
dac_type: external
mode: mono
Light’s in there and works, I stripped out the button. Solid wifi connection, I’m just a few feet from the main access point (-38dBm).
Oh, if flashed with the current voice assistant setup the static is NOT present. So I do not think the hardware is broken.
Linwood
