I would like to run the voice output through my HomePod mini instead of the Atom Echo (which is very quiet).
I have searched through various communities and found that the following attachment in YAML config in ESPHome should activate external speakers:
text:
# Text configuration to se the media player you want to use for the assistant voice.
name: "Assistant Media Player"
entity_category: CONFIG
initial_value: media_player.wohnzimmer #my HomePod mini
# Saves and loads the state to RTC/Flash
restore_value: true
mode: text
voice_assistant:
on_tts_end:
# Call the media player as a service. You need to configure the device in the ESPHome integration to
# "Allow the device to perform Home Assistant actions".
- homeassistant.service:
service: media_player.play_media
entity_id: !lambda "return id(assistant_media_player).state.c_str();"
media_content_id: !lambda "return x;"
media_content_type: music
announce: "true"
optimistic: true
When I open Atom Echo under “Settings - Devices”, I see my HomePod mini under “Assistant Media Player.”
However, no sound comes out of it. Occasionally, I hear a crackling noise.
How can I redirect the voice output from Atom Echo to my HomePod?
[22:27:12][D][voice_assistant:477]: State changed from STOPPING_MICROPHONE to AWAITING_RESPONSE
[22:27:12][D][voice_assistant:623]: Event Type: 4
[22:27:12][D][voice_assistant:661]: Speech recognised as: "Wieviel Uhr ist es?"
[22:27:12][D][voice_assistant:623]: Event Type: 5
[22:27:12][D][voice_assistant:666]: Intent started
[22:27:12][D][voice_assistant:623]: Event Type: 6
[22:27:12][D][voice_assistant:623]: Event Type: 7
[22:27:12][D][voice_assistant:718]: Response: "Es ist 22:27"
[22:27:12][D][voice_assistant:623]: Event Type: 8
[22:27:12][D][voice_assistant:740]: Response URL: "http://192.168.x.x:xxxx/api/tts_proxy/qxIaJ9e8CSfY38XLAUxHkg.wav"
[22:27:12][D][voice_assistant:477]: State changed from AWAITING_RESPONSE to STREAMING_RESPONSE
[22:27:12][D][voice_assistant:484]: Desired state set to STREAMING_RESPONSE
[22:27:12][D][voice_assistant:623]: Event Type: 2
[22:27:12][D][voice_assistant:763]: Assist Pipeline ended
[22:27:12][D][light:052]: 'M5Stack Atom Echo xxx4' Setting:
[22:27:12][D][light:069]: Brightness: 100%
[22:27:12][D][light:076]: Red: 0%, Green: 0%, Blue: 100%
[22:27:12][D][light:126]: Effect: 'None'
[22:27:12][D][media_player:074]: 'M5Stack Atom Echo fd4894' - Setting
[22:27:12][D][media_player:081]: Media URL: http://192.168.x.x:xxxx/api/tts_proxy/qxIaJ9e8CSfY38XLAUxHkg.wav
[22:27:12][D][media_player:087]: Announcement: yes
[22:27:12][D][light:052]: 'M5Stack Atom Echo fd4894' Setting:
[22:27:12][D][speaker_media_player:406]: State changed to ANNOUNCING
[22:27:13][E][speaker_media_player.pipeline:112]: Media reader encountered an error: ESP_FAIL
[22:27:13][E][speaker_media_player:326]: The announcement pipeline's file reader encountered an error.
[22:27:14][E][speaker_media_player.pipeline:112]: Media reader encountered an error: ESP_FAIL
[22:27:14][E][speaker_media_player:326]: The announcement pipeline's file reader encountered an error.
[22:27:15][E][speaker_media_player.pipeline:112]: Media reader encountered an error: ESP_FAIL
[22:27:15][E][speaker_media_player:326]: The announcement pipeline's file reader encountered an error.
[22:27:16][E][speaker_media_player:326]: The announcement pipeline's file reader encountered an error.
[22:27:16][E][speaker_media_player.pipeline:112]: Media reader encountered an error: ESP_FAIL
