asherw83
(Asher)
July 23, 2024, 12:00pm
1
On device wake word is working on the M5Stack Atom Echo! I’m pumped.
I started to throw it all together when I came across a PR from someone who did all the hard work. PR Here: Github , ESPHome config file here: m5stack-atom-echo.yaml
My config here:
substitutions:
friendly_name: VoiceAssistant
micro_wake_word_model: alexa
esphome:
friendly_name: ${friendly_name}
name_add_mac_suffix: true
min_version: 2024.7.1
project:
version: "24.7.4.1"
esp32:
board: m5stack-atom
framework:
type: esp-idf
# Enable logging
logger:
# Enable Home Assistant API
api:
encryption:
key: "xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx"
# Allow Over-The-Air updates
ota:
- platform: esphome
password: "xxxxxxxxxxxxxxxxxxxxxxxxx"
# Allow provisioning Wi-Fi via serial
improv_serial:
wifi:
ssid: !secret wifi_ssid
ap:
captive_portal:
button:
- platform: factory_reset
i2s_audio:
- id: i2s_audio_bus
i2s_lrclk_pin: GPIO33
i2s_bclk_pin: GPIO19
microphone:
- platform: i2s_audio
i2s_din_pin: GPIO23
adc_type: external
pdm: true
speaker:
i2s_dout_pin: GPIO22
dac_type: external
mode: mono
voice_assistant:
microphone: echo_microphone
speaker: echo_speaker
noise_suppression_level: 2
auto_gain: 31dBFS
volume_multiplier: 1.0
vad_threshold: 3
on_listening:
- light.turn_on:
blue: 100%
red: 0%
green: 0%
effect: "Slow Pulse"
on_stt_vad_end:
- light.turn_on:
blue: 100%
red: 0%
green: 0%
effect: "Fast Pulse"
on_tts_start:
- light.turn_on:
blue: 100%
red: 0%
green: 0%
brightness: 100%
effect: none
on_end:
- delay: 100ms
- voice_assistant.stop:
- wait_until:
not:
voice_assistant.is_running:
- if:
condition:
lambda: return id(wake_word_engine_location).state == "On device";
then:
- micro_wake_word.start:
- script.execute: reset_led
else:
- voice_assistant.start_continuous:
on_error:
- light.turn_on:
red: 100%
green: 0%
blue: 0%
brightness: 100%
effect: none
- delay: 2s
on_client_connected:
- delay: 5s
- if:
condition:
then:
else:
on_client_disconnected:
- micro_wake_word.stop:
binary_sensor:
# button does the following:
# Restart either microwakeword or voice assistant continuous
- platform: gpio
pin:
number: GPIO39
inverted: true
disabled_by_default: true
entity_category: diagnostic
on_multi_click:
- timing:
- ON for at least 50ms
- OFF for at least 50ms
then:
- if:
condition:
then:
- delay: 1s
- script.wait: reset_led
else:
- if:
condition: voice_assistant.is_running
then:
- timing:
- ON for at least 10s
then:
- button.press: factory_reset_btn
light:
- platform: esp32_rmt_led_strip
entity_category: config
pin: GPIO27
default_transition_length: 0s
chipset: SK6812
num_leds: 1
rgb_order: grb
rmt_channel: 0
effects:
- pulse:
transition_length: 250ms
update_interval: 250ms
min_brightness: 50%
max_brightness: 100%
- pulse:
transition_length: 100ms
update_interval: 100ms
min_brightness: 50%
script:
- id: reset_led
then:
- if:
condition:
- lambda: return id(wake_word_engine_location).state == "On device";
- switch.is_on: use_listen_light
then:
- light.turn_on:
red: 100%
green: 89%
blue: 71%
brightness: 60%
effect: none
else:
- if:
condition:
- lambda: return id(wake_word_engine_location).state != "On device";
then:
- light.turn_on:
red: 0%
green: 100%
blue: 100%
brightness: 60%
effect: none
else:
- light.turn_off: led
switch:
name: Use listen light
optimistic: true
restore_mode: RESTORE_DEFAULT_ON
on_turn_on:
on_turn_off:
select:
- id: wake_word_engine_location
platform: template
name: Wake word engine location
optimistic: true
restore_value: true
options:
- In Home Assistant
- On device
initial_option: On device
on_value:
- if:
condition:
lambda: return x == "In Home Assistant";
then:
- delay: 500ms
- lambda: id(va).set_use_wake_word(true);
- if:
condition:
lambda: return x == "On device";
then:
- lambda: id(va).set_use_wake_word(false);
- delay: 500ms
external_components:
- source: github://pr#5230
components:
- esp_adf
refresh: 0s
- source:
type: git
url: https://github.com/kahrendt/esphome
ref: mww-v2-external-library
refresh: 0s
components: [ micro_wake_word ]
esp_adf:
# https://esphome.io/components/micro_wake_word.html
micro_wake_word:
vad:
model: github://esphome/micro-wake-word-models/models/v2/vad.json
models:
- model: github://esphome/micro-wake-word-models/models/v2/${micro_wake_word_model}.json
on_wake_word_detected:
- voice_assistant.start:
wake_word: !lambda return wake_word;
Hi @asherw83
This works perfectly. Thanks so much!
If I want to use ‘hey jarvis’ as the on device wake word, do you know how I should change this?
substitutions:
friendly_name: Bedroom 2 Assist Device
micro_wake_word_model: hey jarvis ???
The code doesn’t use the substition values for models.
You need to change the models in the block:
micro_wake_word:
vad:
models:
- model: github://esphome/micro-wake-word-models/models/v2/alexa.json
from alexa.json to hey_jarvis.json and reinstall
Thanks for writing this down! It was very helpful
sejnub
(Heiner)
July 24, 2024, 10:32am
6
Great, it works.
And there is a lot of space for improvement, acoustically and logically. I see this state as a proof of concept; the everyday usefulness is still there to come.
I think we should wait nd see what hardware Nabu Casa have up their sleeve.
asherw83
(Asher)
July 25, 2024, 2:24am
8
Hi @templeton_nash , because the substitute block doesn’t yet support arrays/lists, you’ll have to manually add the ‘hey jarvis’ model.
So if you scroll down to the bottom of the yaml file you’ll find the micro_wake_word: component.
micro_wake_word:
vad:
models:
To add another supported wake word model (All current supported wake words can be found here: github/esphome/micro-wake-word-models )
After you add ‘hey jarvis’ your config should look like this:
micro_wake_word:
vad:
models:
- model: github://esphome/micro-wake-word-models/models/v2/hey_jarvis.json
You’ll notice the url looks different as it is the ‘short hand’ version (as mentioned in the esphome doco ) which gets translated to the full github url upon compilation.
Merc
July 31, 2024, 3:23pm
9
HI all,
so with the last GITHUB update of the Atom Echo firmware I managed to get micro wake work running.
Before that I had tweaked my Atom Echo firmware in a way so that it plays a little confirmation sound when the wakeword is recognized. I did not figure that one out on my own but with some code I found on the forum. I can’t remember who was the original author but I am very grateful for the code and definitely do not want to sell this as my product.
I will paste the code and the little click sound I am using below, if people want to use it.
Now I would like to marry the two, i.e. have the confirmation sound played with the firmware that uses on device wakeword but this does not work yet. Maybe someone with more coding experience will quickly figure out what I am doing wrong.
I would appreciate the help!
Here is the code for Atom Echo wakeword with sound feedback:
substitutions:
name:
friendly_name:
static_ip: 192.168.1.17
esphome:
friendly_name: "${friendly_name}"
name_add_mac_suffix: false
project:
version: "1.0"
min_version: 2024.6.0
file:
- id: ok_sound
file: wakeword_detected3.raw
- id: timer_finished_wave_file
file: https://github.com/esphome/firmware/raw/main/voice-assistant/sounds/timer_finished.wav
esp32:
board: m5stack-atom
framework:
type: esp-idf
logger:
api:
encryption:
key:
ota:
platform: esphome
dashboard_import:
package_import_url: github://esphome/firmware/voice-assistant/m5stack-atom-echo.yaml@main
wifi:
networks:
- ssid: !secret wifi_ssid
manual_ip:
static_ip: ${static_ip}
gateway: 192.168.1.1
subnet: 255.255.255.0
button:
- platform: restart
i2s_audio:
microphone:
i2s_din_pin: GPIO23
adc_type: external
pdm: true
speaker:
dac_type: external
mode: mono
voice_assistant:
auto_gain: 31dBFS
volume_multiplier: 2.0
vad_threshold: 3
- microphone.stop_capture:
- wait_until:
not:
microphone.is_capturing:
- lambda: id(echo_speaker).play(id(ok_sound), sizeof(id(ok_sound)));
on_listening:
- delay: 600ms
- wait_until:
not:
speaker.is_playing:
- microphone.capture:
- light.turn_on:
blue: 100%
red: 0%
green: 0%
on_stt_vad_end:
- light.turn_on:
blue: 100%
red: 0%
green: 0%
on_tts_start:
- light.turn_on:
blue: 100%
red: 0%
green: 0%
brightness: 100%
effect: none
on_end:
- delay: 100ms
- wait_until:
not:
speaker.is_playing:
on_error:
- light.turn_on:
red: 100%
green: 0%
blue: 0%
brightness: 100%
effect: none
- delay: 1s
- if:
condition:
switch.is_on: use_wake_word
then:
- if:
condition:
then:
on_timer_finished:
- switch.turn_on: timer_ringing
- wait_until:
not:
- light.turn_on:
red: 0%
green: 100%
blue: 0%
brightness: 100%
- while:
condition:
switch.is_on: timer_ringing
then:
- lambda: id(echo_speaker).play(id(timer_finished_wave_file), sizeof(id(timer_finished_wave_file)));
- delay: 1s
- wait_until:
not:
speaker.is_playing:
- switch.turn_off: timer_ringing
- if:
condition:
then:
binary_sensor:
- platform: gpio
pin:
number: GPIO39
inverted: true
on_multi_click:
- timing:
then:
- if:
condition:
then:
else:
- if:
condition:
switch.is_off: use_wake_word
then:
- if:
then:
else:
else:
- delay: 1s
- timing:
then:
light:
pin: GPIO27
chipset: SK6812
num_leds: 1
rgb_order: grb
rmt_channel: 0
effects:
- pulse:
min_brightness: 50%
- pulse:
min_brightness: 50%
script:
- id: reset_led
then:
- if:
condition:
- switch.is_on: use_wake_word
then:
- light.turn_on:
red: 100%
green: 89%
blue: 71%
brightness: 60%
effect: none
else:
switch:
name: Use wake word
optimistic: true
on_turn_on:
- if:
condition:
not:
- voice_assistant.is_running
then:
on_turn_off:
optimistic: true
on_turn_on:
optimistic: true
internal: true
restore_mode: ALWAYS_OFF
on_turn_on:
- delay: 15min
on_turn_off:
components:
- esp_adf
refresh: 0s
- source: github://jesserockz/esphome-components
components: [file]
esp_adf:
I think I cannot attach the soundfile here but would be happy to share that if someone needs a small sound that works on the Atom Echo.
And here is the not working “on device micro wakeword with confirmation sound” firmware that needs fixing:
substitutions:
friendly_name: Atom Echo
micro_wake_word_model: okay_nabu # alexa, hey_jarvis, hey_mycroft are also supported
esphome:
project:
version: "24.7.29"
esp32:
board: m5stack-atom
framework:
type: esp-idf
logger:
api:
encryption:
key:
ota:
- platform: esphome
- platform: http_request
update:
source: https://firmware.esphome.io/wake-word-voice-assistant/m5stack-atom-echo/manifest.json
http_request:
dashboard_import:
package_import_url: github://esphome/firmware/wake-word-voice-assistant/m5stack-atom-echo.adopted.yaml@main
wifi:
manual_ip:
static_ip: 192.168.1.40
improv_serial:
captive_portal:
button:
i2s_audio:
- id: i2s_audio_bus
microphone:
i2s_din_pin: GPIO23
adc_type: external
pdm: true
speaker:
dac_type: external
mode: mono
voice_assistant:
auto_gain: 31dBFS
vad_threshold: 3
- wait_until:
not:
on_listening:
- light.turn_on:
blue: 100%
red: 0%
green: 0%
on_stt_vad_end:
- light.turn_on:
blue: 100%
red: 0%
green: 0%
on_tts_start:
- light.turn_on:
blue: 100%
red: 0%
green: 0%
brightness: 100%
effect: none
on_end:
- delay: 100ms
- wait_until:
not:
- wait_until:
not:
- if:
condition:
then:
else:
on_error:
- light.turn_on:
red: 100%
green: 0%
blue: 0%
brightness: 100%
effect: none
- delay: 2s
- delay: 2s # Give the api server time to settle
- if:
condition:
then:
else:
on_timer_finished:
- wait_until:
not:
- light.turn_on:
red: 0%
green: 100%
blue: 0%
brightness: 100%
- while:
condition:
then:
- delay: 1s
- wait_until:
not:
speaker.is_playing:
- if:
condition:
then:
else:
binary_sensor:
# short click - stop a timer
# if no timer then restart either microwakeword or voice assistant continuous
- platform: gpio
pin:
number: GPIO39
inverted: true
on_multi_click:
- timing:
then:
- if:
condition:
then:
else:
- if:
condition:
then:
- delay: 1s
else:
- if:
then:
- timing:
then:
light:
pin: GPIO27
chipset: SK6812
num_leds: 1
rgb_order: grb
rmt_channel: 0
effects:
- pulse:
min_brightness: 50%
- pulse:
min_brightness: 50%
script:
- id: reset_led
then:
- if:
condition:
then:
- light.turn_on:
red: 100%
green: 89%
blue: 71%
brightness: 60%
effect: none
else:
- if:
condition:
then:
- light.turn_on:
red: 0%
green: 100%
blue: 100%
brightness: 60%
effect: none
else:
switch:
optimistic: true
on_turn_on:
on_turn_off:
optimistic: true
internal: true
on_turn_on:
- delay: 15min
select:
optimistic: true
restore_value: true
options:
- In Home Assistant
- On device
on_value:
- if:
condition:
then:
- delay: 500ms
- if:
condition:
then:
- delay: 500ms
components:
- esp_adf
refresh: 0s
components: [file]
refresh: 0s
esp_adf:
file:
- id: ok_sound
micro_wake_word:
vad:
models:
- model: ${micro_wake_word_model}
If anybody can spot the error and knows the solution that would be great.
I realised that the Echo’s work very well if they are restarted frequently.
Thanks and regards,
Merc
Merc
August 1, 2024, 8:20am
10
OK , solved it by moving the
part down to the micro wake word section.
Joe68
August 13, 2024, 9:33pm
11
Merc:
Hi, You say you solved it, can you please post the whole working code?
THX
blackie333
(Blackie333)
August 14, 2024, 12:58pm
12
Have tried to adapt this Echo project version for M5Stack AtomU (USB microphone device). I have done this few time before successfully, firmware is linked but it’s size is too big for upload.
Can I do anything, device has 4MB flash but update via OTA is failing?
(I removed .wav file + speaker confirmation code + all openwakeword-related code )
Merc
August 14, 2024, 2:07pm
13
Clean build files first.
That solved the space issue for me. Since then I have never had it again and I am running 6 Atom Echos here.
Also, make sure the sound file you are using is as small as possible.
Merc
August 14, 2024, 2:21pm
14
Literally as I wrote.
Just take my yaml which I had pasted in above and move the code I had mentioned to the other section in the code.
Simple cut and paste.
So what are the benefits of having an on device wake word compared to having it on HA? Doesn’t HA have more horsepower to perform calculations?
Merc
August 15, 2024, 5:14pm
16
If you run many little satellites the server has to listen all the time. This load is gone when running the wake word on device.
On my Nuc I5 the processor load and with it the temperature came down significantly since switching 6 devices to local.
You can imagine what this means for running HA on a Pi.
ThijsM
August 25, 2024, 6:55pm
17
Hi @asherw83 , Congrats on getting this to work! I’m close but my micro wake word models seem to be too large. How did you create your micro wake word model?
I have used Colab to create a custom model as described here: Create your own wake word - Home Assistant
I use ESPHome to install the model on the Echo, but after install on startup I get the error “Failed to allocate tensors for the streaming model”.
It does work if I use one of the models from here , but my custom models must be larger (the files are about 4x the size as well):
Any suggestions? Thanks!
Vargash
(Vargash)
September 6, 2024, 3:03pm
18
I got the same problem “Failed to allocate tensors for the streaming model” while trying to install a custom wakeword on-device…
Is there any tricks to reduce the size of trained words in order to make them loadable in the Atom Echo?
tiko
September 11, 2024, 7:41pm
19
Hi there,
I do not know if I am too stupid or something like that but I can’t get it to run. The installation always fails no matter what I do.
Right now I can’t even get the installation to start as the HomeAssistant API key is not working.
Is it right that I just have to create a long living access token in the security tab and add it to the
api:
encryption:
key: <my-key-here>
What am I doing wrong?
Any help is appreciated, thanks in advance!
Edit:
And when I get the installation to start it runs for a very long time and ending in an error. I will look for the error and add it here.
BramNH
(Bram Nijenhuis)
September 22, 2024, 10:55am
20
Did anyone get this working with the current versions?
Whatever I do, my atom echo just doesn’t work with all the configurations I find online. Clean build files and started over and over again.
Could someone provide versions of ESPHome on which their configuration works?
I had a version where the micro wakeword seemed to work, but it would then be stuck at streaming_microphone.
@asherw83 is your atom echo still working with micro wakeword?
