M5Stack Atom with M5Stack ENV Pro Unit with Temperature, Humidity, Pressure and Gas Sensor (BME688)
I had a requirement to have a USB powered sensor (due to the frequency of measurements). Having already been using the M5Stack as a Bluetooth Proxy for some blinds I thought I’d see whether this was an appropriate platform.
The answer was, of course, yes as there are a variety of sensors that simply plug into the Grove port and can be addressed by I2C.
In this case I went with the Env Pro with BME688 sensor which came with the connecting cable.
Picture of the sensor
Connect the Sensor to the M5Stack with the supplied cable.
Connect the M5Stack to you computer with USBC cable (has to be a data cable).
Open ESPHome and Add new device and prepare for first time use.
After you’ve got it added to HA then use the following yaml for a start.
esphome:
  friendly_name: <Your_Friendly_Name>
  min_version: 2024.11.0
  name_add_mac_suffix: false
esp32:
  board: esp32dev
  framework:
    type: esp-idf
# Enable logging
logger:
# Enable Home Assistant API
api:
# Allow Over-The-Air updates
ota:
- platform: esphome
wifi:
  ssid: !secret wifi_ssid
i2c:
  sda: 26
  scl: 32
  scan: true
  - platform: bme680
    address: 0x77
    update_interval: 10s
    temperature:
    pressure:
    humidity:
There are some other bits on the sensor board like Air quality etc but this is the basic starting point. Hope this helps someone!
Hi Dan, short question… How do you implement the gas sensor for usefull readings? Is there a possibility to read the air quality index directly out of the chip? Warm regards Thomas
I just started working on this and this is what I have so far. I got most of this by spending a lot of time with Gemini 2.5 Pro, so…not sure it’s all functional yet.
# Sensoren von der bme68x_bsec2_i2c Komponente
  - platform: bme68x_bsec2
    bme68x_bsec2_id: env_pro_bme_core
    temperature:
      name: "${upper_devicename} ENV Pro Temperatur"
      filters: [ median ]
    pressure:
      name: "${upper_devicename} ENV Pro Luftdruck"
      filters: [ median ]
    humidity:
      name: "${upper_devicename} ENV Pro Luftfeuchtigkeit"
      filters: [ median ]
    iaq:
      name: "${upper_devicename} ENV Pro IAQ"
      filters: [ median ]
      on_value:
        - component.update: iaq_classification_id
    iaq_static:
      name: "${upper_devicename} ENV Pro Static IAQ"
      filters: [ median ]
      on_value:
        - component.update: static_iaq_classification_id
    co2_equivalent:
      name: "${upper_devicename} ENV Pro eCO2"
      filters: [ median ]
    breath_voc_equivalent:
      name: "${upper_devicename} ENV Pro bVOC"
      filters: [ median ]
    gas_resistance:
      name: "${upper_devicename} ENV Pro Gaswiderstand"
      filters: [ median ]
    # update_interval: 60s # Globales Sendeintervall an HA für diese Sensoren (Standard ist 60s)
text_sensor:
    iaq_accuracy:
      name: "${upper_devicename} ENV Pro IAQ Genauigkeit"
    name: "${upper_devicename} ENV Pro IAQ Klassifikation"
    icon: "mdi:leaf"
    lambda: |-
      if (!id(env_pro_iaq).has_state()) { return {"Kalibrierung..."}; }
      int iaq_value = id(env_pro_iaq).state;
      if (iaq_value <= 50) { return {"Ausgezeichnet"}; }
      else if (iaq_value <= 100) { return {"Gut"}; }
      else if (iaq_value <= 150) { return {"Leicht verschmutzt"}; }
      else if (iaq_value <= 200) { return {"Mäßig verschmutzt"}; }
      else if (iaq_value <= 250) { return {"Stark verschmutzt"}; }
      else if (iaq_value <= 350) { return {"Sehr stark verschmutzt"}; }
      else if (iaq_value > 350) { return {"Extrem verschmutzt"}; }
      else { return {"Fehler"}; }
    update_interval: never
    name: "${upper_devicename} ENV Pro Static IAQ Klassifikation"
    icon: "mdi:leaf-map"
    lambda: |-
      if (!id(env_pro_static_iaq).has_state()) { return {"Kalibrierung..."}; }
      int iaq_value = id(env_pro_static_iaq).state;
      if (iaq_value <= 50) { return {"Ausgezeichnet (s)"}; }
      else if (iaq_value <= 100) { return {"Gut (s)"}; }
      else if (iaq_value <= 150) { return {"Leicht verschm. (s)"}; }
      else if (iaq_value <= 200) { return {"Mäßig verschm. (s)"}; }
      else if (iaq_value <= 250) { return {"Stark verschm. (s)"}; }
      else if (iaq_value <= 350) { return {"Sehr stark v. (s)"}; }
      else if (iaq_value > 350) { return {"Extrem verschm. (s)"}; }
      else { return {"Fehler (s)"}; }
