M5STACK Atomic Echo Base
Looks like M5STACK just dropped new hardware, in the form of the Atomic Echo Base module (you’ll need an Atom ESP32 module as well):
I wonder how it will compare to the “all-in-one” Atom Echo? I know people haven’t been as pleased with it, maybe having the mic+speaker in a dedicated separate module with more room, will give better results.
I was hoping I could attach one to my atom echo and use the base’s mic and speaker instead, but I can’t seem to get it to work. Not sure if I need to do something special in the esphome yaml config to use the base’s components.
Did you manage to sort this, got the Atom to work with voice but the base seems to knock out the mic and speaker.
No, I never did. Exactly the same experience
