I just got an M5Stack dial, there is a bit of info here about how to get it to do a few things like use as a media centre control or light dimmer or fan control.
but I cant find anything on the intial set up, how to get it into Home Assistant etc
after trying to install, fail, delete, repeat copious amounts of times everyday for the past two weeks, the dial which now shows nothing on the screen was “discovered”. I tried to adopt it and it has come up with the following:
INFO ESPHome 2024.8.1
INFO Reading configuration /config/esphome/esphome-web-968ebc.yaml...
Failed config
esphome: None
friendly_name: Hudson Dial
Your ESPHome version is too old. Please update to at least 2025.5.0.
min_version: 2025.5.0
name_add_mac_suffix: False
build_path: build/esphome-web-968ebc
much like the method for setting up this dial, i cant find anything on upgrading esphome except for a comment on the web saying that it had to be completely uninstalled and then re-installed. im assuming this will destroy the configs for the other devices i have in here?
Nothing bad should happen. Anyway, make a backup of your config folder that contains your yamls.
And when you upgrade esphome, you don’t need to upgrade your devices that are working like desired.
I was doing so many things wrong and also uploading code that didn’t work. I now can move code to the device. I used the code from here:
I was able to get the code on the dial using esp home/builder with no errors, it now has “offline” on the screen of the dial.
So now is this a problem with wifi connection?
does the code need to be tailored for my set up?
is this an issue with the version of the stamp, mine is S3A?
