Hi all,
I’m trying to use a M5Stack-Fire with ESP Home. I’ve made this yaml:
esphome:
friendly_name: M5-Stack-Fire
esp32:
board: m5stack-core-esp32
framework:
type: arduino
# Enable logging
logger:
# Enable Home Assistant API
api:
encryption:
key: "XXXX"
ota:
password: "XXXXX"
wifi:
ssid: !secret wifi_ssid
manual_ip:
static_ip: 192.168.1.106
gateway: 192.168.1.1
subnet: 255.255.255.0
ap:
ssid: "M5-Stack-Fire Fallback Hotspot"
password: "XXXX"
captive_portal:
web_server:
port: 80
i2s_audio:
- i2s_lrclk_pin: GPIO21
i2s_bclk_pin: GPIO22
i2c:
sda: 21
scl: 22
scan: true
spi:
clk_pin: GPIO18
mosi_pin: GPIO23
miso_pin: GPIO23
output:
- platform: ledc
pin: 32
binary_sensor:
- platform: gpio
pin:
number: 39
inverted: true
- platform: gpio
pin:
number: 38
inverted: true
- platform: gpio
pin:
number: 37
inverted: true
light:
- platform: neopixelbus
type: GRB
variant: 800KBPS
pin: GPIO15
num_leds: 10
- platform: monochromatic
output: gpio_32_backlight_pwm
name: "Display Backlight"
restore_mode: ALWAYS_ON
- platform: wifi_signal
name: "WiFi Signal Sensor"
update_interval: 60s
- platform: mpu6886
address: 0x68
accel_x:
name: "MPU6886 Accel X"
accel_y:
name: "MPU6886 Accel Y"
accel_z:
name: "MPU6886 Accel z"
gyro_x:
name: "MPU6886 Gyro X"
gyro_y:
name: "MPU6886 Gyro Y"
gyro_z:
name: "MPU6886 Gyro z"
temperature:
name: "MPU6886 Temperature"
media_player:
- platform: i2s_audio
dac_type: external
i2s_dout_pin: GPIO25
mode: mono
display:
- platform: ili9xxx
model: ili9341
cs_pin: 14
dc_pin: 27
reset_pin: 33
lambda: |-
it.line(0, 0, 50, 50);
I have problem with screen and media player.
Backlight screen is ok, but i have a little problem with the screen:
With the media player I hear the speaker turn on but no sound.
Thanks for your help!
