m5Stack Mic Unit with Atom S3 Lite ESPHome
I have an m5Stack Atom S3 Lite that I want to use as a Voice Assistant receiver. It has a Mic unit attached with a Grove Connector that I want to use the i2s_audio platform with.
The problem is I can’t seem to get the microphone to work.
Has anyone had any success setting up a mic with the atom s3 lite?
Here is my config:
esphome:
  friendly_name: Bedroom Assist
esp32:
  board: esp32-s3-devkitc-1
  framework:
    type: arduino
# Enable logging
logger:
# Enable Home Assistant API
api:
  encryption:
    key: REDACTED
ota:
wifi:
  ssid: !secret wifi_ssid
captive_portal:
external_components:
  - source: github://pr#5230
    components:
      - esp_adf
# Output that blinks the LED
output:
    type: binary
    write_action:
    - if:
        condition:
          lambda: return (state);
        then:
          - light.turn_on:
              brightness: 70%
              red: 100%
              green: 0%
              blue: 0%
        else:
          - light.turn_off: led
#G4=IR
remote_transmitter:
  pin: GPIO4
  carrier_duty_percent: 50%
light:
  # Enable status LED
  - platform: status_led
    output: status_output
    internal: True
  #G35=RGB WS2812C-2020
  - platform: esp32_rmt_led_strip
    rgb_order: GRB
    pin: 35
    num_leds: 4
    # RMT 0 channels will be occupied by IR
    rmt_channel: 1
    chipset: ws2812
button:
  - platform: factory_reset
#G41=Button
binary_sensor:
  - platform: gpio
    disabled_by_default: true
    entity_category: diagnostic
    pin:
      number: GPIO41
      inverted: true
      mode:
        input: true
        pullup: true
    filters:
      - delayed_off: 10ms
    on_multi_click:
      - timing:
          - ON for at least 250ms
          - OFF for at least 50ms
        then:
          - if:
              condition:
                switch.is_off: use_wake_word
              then:
                - if:
                    condition: voice_assistant.is_running
                    then:
                      - voice_assistant.stop:
                      - script.execute: reset_led
                    else:
                      - voice_assistant.start:
              else:
                - delay: 1s
                - script.wait: reset_led
                - voice_assistant.start_continuous:
      - timing:
          - ON for at least 10s
        then:
          - button.press: factory_reset_btn
i2s_audio:
  i2s_lrclk_pin: GPIO2
microphone:
  - platform: i2s_audio
    adc_type: external
    i2s_din_pin: GPIO1
    pdm: false
voice_assistant:
  microphone: external_mic
  noise_suppression_level: 2
  auto_gain: 31dBFS
  volume_multiplier: 2.0
  on_listening:
    - light.turn_on:
        blue: 100%
        red: 0%
        green: 0%
        effect: "Slow Pulse"
  on_stt_vad_end:
    - light.turn_on:
        blue: 100%
        red: 0%
        green: 0%
        effect: "Fast Pulse"
  on_tts_start:
    - light.turn_on:
        blue: 100%
        red: 0%
        green: 0%
        brightness: 100%
        effect: none
  on_tts_end:
    - homeassistant.service:
        service: media_player.play_media
          entity_id: media_player.bedroom_speaker
          media_content_id: !lambda 'return x;'
          media_content_type: music
          announce: "true"
  on_end:
    - delay: 100ms
  on_error:
    - light.turn_on:
        red: 100%
        green: 0%
        blue: 0%
        brightness: 100%
        effect: none
    - delay: 1s
  on_client_connected:
    - if:
        condition:
          switch.is_on: use_wake_word
        then:
  on_client_disconnected:
    - if:
        condition:
        then:
script:
  - id: reset_led
    then:
      - if:
          condition:
            - switch.is_on: use_wake_word
            - switch.is_on: use_listen_light
          then:
            - light.turn_on:
                red: 100%
                green: 89%
                blue: 71%
                brightness: 60%
                effect: none
          else:
switch:
    name: Use wake word
    optimistic: true
    restore_mode: RESTORE_DEFAULT_ON
    entity_category: config
    on_turn_on:
      - lambda: id(va).set_use_wake_word(true);
      - if:
          condition:
            not:
              - voice_assistant.is_running
          then:
    on_turn_off:
      - lambda: id(va).set_use_wake_word(false);
    name: Use Listen Light
    optimistic: true
    on_turn_on:
    on_turn_off:
I skimmed the results of the following search and it appears that people have only had success with the Atom Echo model and can’t get the microphone working (using ESPHome) for other models.
https://community.home-assistant.io/search?q=Atom%20microphone%20
I may be wrong so I encourage you to review the search results.
I am using the PDM MEMS Microphone Unit (SPM1423) and the GPI ports align as follows:
AtomS3 Lite - Port A PDM Mic - PortI2S
G1 CLK
G2 DAT
I believe PDM should be set to true.
However, I’m uncertain if the ADC would be internal nor how to set the CLK pin.
Did you manage to get this working? I’m connecting the speaker base to my lites3 and a PDM mic also. The speaker works fine, but I cannot get the PDM mic to work at all.
Maybe you guys can help me out. Programming is not my thing :slight_smile:
I have an M5stack atom lite and an m5stack unit mic (m5-docs).
I want to create a sensor to measure decibels with this code below. It gives platform errors validating… Anyone who can help me in the right direction…?
substitutions:
  friendly_name: Mic Unit
packages:
  esphome.bluetooth-proxy: github://esphome/bluetooth-proxies/m5stack/m5stack-atom-lite.yaml@main
esphome:
  name_add_mac_suffix: false
  friendly_name: ${friendly_name}
api:
wifi:
# I2S Audio Configuratie
i2s_audio:
  i2s_lrclk_pin: GPIO33
  i2s_bclk_pin: GPIO26
microphone:
    adc_type: external
    i2s_audio_id: i2s_in
    i2s_din_pin: GPIO32
    pdm: false
    channel: left
    update_interval: 1s
    filters:
      - lambda: return 20.0 * log10(x + 0.0001);  # dB-berekening
    unit_of_measurement: "dB"
