I am trying to use an M5stack Paper as a fridge display for Temperature and Calendar events. I am using hass-lovelace-kindle-screensaver to capture a dashboard image and then the online image component to grab the image and present it on the screen. I am using the code below but I am only getting about 2 days of battery life. I feel like I should be able to squeeze out at least a week on charge but I must be missing something. Does anyone have any insight on what may be draining the battery down so quickly or what I can change to get more battery life?
substitutions:
device_name: m5stack-paper1
esphome:
name_add_mac_suffix: true
on_boot:
- priority: 220.0
then:
- it8951e.clear
- delay: 100ms
- it8951e.updateslow
- priority: -100.0
then:
- delay: 10s
api:
encryption:
key: ""
ota:
- platform: esphome
password: ""
esp32:
board: m5stack-grey
framework:
type: arduino
external_components:
- source:
type: local
path: /config/components
# Enable logging
logger:
level: INFO
# Enable psram
psram:
spi:
clk_pin: GPIO14
mosi_pin: GPIO12
miso_pin: GPIO13
i2c:
sda: GPIO21
scl: GPIO22
display:
- platform: it8951e
cs_pin: GPIO15
reset_pin: GPIO23
reset_duration: 100ms
busy_pin: GPIO27
rotation: 270
# reversed: True
reversed: False
update_interval: never
lambda: |-
// Draw the image my_image at position [x=0,y=0]
// with front color "OFF" and back color "ON"
it.image(0, 0, id(calender), COLOR_OFF, COLOR_ON);
#interval:
#- interval: 60min
#then:
#- component.update: calender
touchscreen:
- platform: gt911
display: m5paper_display
interrupt_pin: GPIO36
transform:
mirror_x: true
mirror_y: false
swap_xy: true
calibration:
x_min: 0
x_max: 540
y_min: 0
y_max: 960
wifi:
ssid: !secret wifi_ssid
power_save_mode: "HIGH"
use_address:
#on_connect:
switch:
- platform: restart
time:
- platform: homeassistant
on_time_sync:
- bm8563.write_time
- platform: bm8563
sleep_duration: 3600000ms
on_time:
- seconds: 0
hours: /1
then:
- component.update: m5paper_display
- component.update: m5paper_battery_level
- seconds: 0
minutes: 0
then:
- bm8563.apply_sleep_duration
- delay: 1s
- m5paper.shutdown_main_power
timezone: NA/REGINA
on_time_sync:
- bm8563.write_time
m5paper:
battery_power_pin: GPIO5
main_power_pin: GPIO2
http_request:
verify_ssl: false
online_image:
- url: "http://192.168.1.50:5001"
format: png
type: BINARY
- platform: adc
disabled_by_default: true
pin: GPIO35
name: ${device_name} battery voltage
update_interval: 60min
attenuation: 11db
filters:
- multiply: 2 #1,27272727
name: ${device_name} battery level
unit_of_measurement: '%'
device_class: "battery"
state_class: "measurement"
icon: mdi:battery-high
lambda: |-
constexpr float min_level = 3.52;
constexpr float max_level = 4.15;
return ((id(m5paper_battery_voltage).state - min_level) / (max_level - min_level)) * 100.00;
filters:
- clamp:
min_value: 0
max_value: 100
binary_sensor:
- platform: gpio
name: ${device_name} right button
icon: mdi:gesture-tap-button
pin:
number: GPIO37
inverted: true
- platform: gpio
name: ${device_name} BTN/PWR button
pin:
number: GPIO38
inverted: true
- platform: gpio
name: ${device_name} left button
pin:
number: GPIO39
inverted: true
