M5StickC Plus 2 Voice assistant, micro and speaker configuration help
I’m trying to configure an M5StickC Plus 2 with voice assistant. I managed to get the microphone to work as best I could. I was able to display the response on the screen, but there is a problem with the text being long and if it goes off the screen, there are errors in the logs.
I’ve a SPK2 HAT speaker, which I would like to configure. But I can’t find the right configuration, because the microphone and speaker use the same GPIO0 and the two cannot work together.
There is also the speaker (buzzer) on the GPIO2, which must be deactivated for the microphone to work.
Shematic:
an arduino example to operate the microphone and speaker, if it helps.
my config.yaml ( not perfect, but works )
substitutions:
  friendly_name: M5StickC PLUS2 Voice
esphome:
  name_add_mac_suffix: false
  friendly_name: ${friendly_name}
  project:
    version: "1.0"
  min_version: 2023.11.1
  platformio_options:
    upload_speed: 115200
  on_boot:
    - priority: 600
      then:
        - output.turn_on: output_high
  on_shutdown:
    - priority: 600
      then:
        - output.turn_off: output_high
esp32:
  board: m5stick-c
  framework:
    type: esp-idf
  flash_size: 8MB
# Enable logging
logger:
# Enable Home Assistant API
api:
  encryption:
    key: "xxxxxxxxx"
ota:
  password: "xxxxxxxx"
wifi:
  ssid: !secret wifi_ssid
improv_serial:
esp32_improv:
  authorizer: none
script:
  - id: reset_led
    then:
      - if:
          condition:
            switch.is_on: use_wake_word
          then:
            - light.turn_on:
          else:
            - light.turn_off: led
output:
  - platform: ledc
    pin: GPIO19
  # Buzzer output
  - platform: ledc
    pin:
      number: GPIO2
    inverted: false
  # Backlight TFT LCD
  - platform: ledc
    pin: 27
    inverted: false
  # Battery output
  - platform: gpio
    pin:
      number: GPIO4
      mode:
        output: true
spi:
  clk_pin: GPIO13
  mosi_pin: GPIO15
i2s_audio:
  - id: mic_adc
    i2s_lrclk_pin:
       number: GPIO0
#       allow_other_uses: true
       ignore_strapping_warning: true
#  - id: spk_adc
#    i2s_lrclk_pin:
#       number: GPIO0
#       ignore_strapping_warning: true
#    i2s_bclk_pin: GPIO26
microphone:
  - platform: i2s_audio
    i2s_din_pin: GPIO34
    adc_type: external
    channel: left
    i2s_audio_id: mic_adc
#    bits_per_sample: 16bit
#    sample_rate: 44100
    pdm: true
#speaker:
#  - platform: i2s_audio
#    dac_type: internal
#    i2s_audio_id: spk_adc
#    mode: right
#speaker:
#    id: echo_speaker
#    i2s_dout_pin: GPIO25
#    i2s_audio_id: mic_adc
#    dac_type: external
#    mode: mono
voice_assistant:
  microphone: echo_microphone
#  speaker: echo_speaker
  noise_suppression_level: 2
  auto_gain: 31dBFS
  volume_multiplier: 2.0
  vad_threshold: 3
  on_listening:
    - light.turn_on:
        effect: "Listening"
  on_stt_vad_end:
    - light.turn_on:
        effect: "Listening"
  on_tts_start:
    - text_sensor.template.publish:
        state: !lambda 'return x;'
    - light.turn_on:
        brightness: 60%
    - delay: 100ms
  on_end:
    - delay: 100ms
#    - wait_until:
#        not:
#          speaker.is_playing:
    - script.execute: reset_led
  on_error:
    - light.turn_on:
        effect: "Error"
    - delay: 2s
    - script.wait: reset_led
  on_client_connected:
    - if:
        condition:
        then:
          - voice_assistant.start_continuous:
  on_client_disconnected:
    - if:
        condition:
        then:
          - voice_assistant.stop:
binary_sensor:
  - platform: gpio
    pin:
      number: GPIO37
      inverted: true
    disabled_by_default: true
    entity_category: diagnostic
    on_click:
      min_length: 50ms
      max_length: 350ms
      then:
        - if:
            condition:
              switch.is_off: use_wake_word
            then:
              - if:
                  condition: voice_assistant.is_running
                  then:
                  else:
                    - output.turn_off: buzzer
                    - voice_assistant.start:
            else:
              - delay: 1s
  - platform: gpio
    pin:
      number: GPIO39
      inverted: true
    on_click:
      min_length: 50ms
      max_length: 350ms
      then:
        - light.toggle: display_bl
light:
  - platform: monochromatic
    entity_category: config
    output: led_pwm
    effects:
      - pulse:
          transition_length: 1s
          update_interval: 1s
          min_brightness: 0%
          max_brightness: 30%
      - pulse:
          transition_length: 0.25s
          update_interval: 0.25s
          min_brightness: 0%
          max_brightness: 100%
  # Backlight TFT LCD
    output:  backlight
    restore_mode: RESTORE_DEFAULT_ON
  - platform: uptime
    update_interval: 60s
    internal: true
switch:
    name: Use wake word
    restore_mode: ALWAYS_OFF
    optimistic: true
    on_turn_on:
      - lambda: id(va).set_use_wake_word(true);
      - if:
          condition:
            not:
              - voice_assistant.is_running
          then:
    on_turn_off:
      - lambda: id(va).set_use_wake_word(false);
  - platform: restart
    entity_category: "diagnostic"
time:
  - platform: homeassistant
text_sensor:
    lambda: |-
      int seconds = (id(uptime_sec).state);
      int days = seconds / (24 * 3600);
      seconds = seconds % (24 * 3600);
      int hours = seconds / 3600;
      seconds = seconds % 3600;
      int minutes = seconds /  60;
      seconds = seconds % 60;
      if ( days ) {
        return { (to_string(days) +"d " + to_string(hours) +"h " + to_string(minutes) +"m "+ to_string(seconds) +"s ").c_str() };
      } else if ( hours ) {
        return { (to_string(hours) +"h " + to_string(minutes) +"m "+ to_string(seconds) +"s ").c_str() };
      } else if ( minutes ) {
        return { (to_string(minutes) +"m "+ to_string(seconds) +"s ").c_str() };
      } else {
        return { (to_string(seconds) +"s ").c_str() };
    icon: mdi:clock-start
font:
  - file: "gfonts://Roboto"
    glyphs: "<>!'%()/+,-_.:;*=°?#0123456789AÀBCDEÉÈÊFGHIJKLMNOPQRSTUVWXYZ aàbcdeéèêfghijklmnopqrstuvwxyzôöç"
color:
  - id: my_white
    red: 100%
    green: 100%
    blue: 100%
  - id: my_blue
    red: 0%
    green: 0%
    blue: 100%
  - id: my_red
    red: 100%
    green: 0%
    blue: 0%
  - id: my_green
    red: 0%
    green: 100%
    blue: 0%
  - id: my_yellow
    red: 100%
    green: 100%
    blue: 0%
  - id: my_orange
    red: 100%
    green: 50%
    blue: 0%
# 1.14 inch, 135*240 Colorful TFT LCD, ST7789v2
display:
  - platform: ili9xxx
    model: st7789v
    cs_pin: GPIO5
    dc_pin: GPIO14
    reset_pin: GPIO12
    rotation: 90
    dimensions:
      height: 240
      width: 135
      offset_height: 40
      offset_width: 52
    # Required or the colors are all inverted, and Black screen is White
    invert_colors: true
    lambda: |-
      it.strftime(30, 2, id(roboto), id(my_blue), "%H:%M:%S %d/%m/%y", id(my_time).now());
      it.printf(5, 28, id(roboto), id(my_white), "Réponse:");
      it.printf(5, 54, id(roboto), id(my_green), id(tts).state.c_str());
external_components:
  - source: github://pr#5230
    components:
      - esp_adf
    refresh: 0s
esp_adf:
[20:08:16][D][voice_assistant:439]: State changed from STOPPING_MICROPHONE to AWAITING_RESPONSE
[20:08:18][D][voice_assistant:563]: Event Type: 4
[20:08:18][D][voice_assistant:591]: Speech recognised as: "éteindre cuisine"
[20:08:18][D][voice_assistant:563]: Event Type: 5
[20:08:18][D][voice_assistant:596]: Intent started
[20:08:18][D][voice_assistant:563]: Event Type: 6
[20:08:18][D][voice_assistant:563]: Event Type: 7
[20:08:18][D][voice_assistant:619]: Response: "Éteint"
[20:08:18][D][text_sensor:064]: 'text-to-speech': Sending state 'Éteint'
[20:08:18][D][light:036]: 'M5StickC PLUS2 Voice' Setting:
[20:08:18][D][light:051]:   Brightness: 60%
[20:08:18][D][light:085]:   Transition length: 1.0s
I’m looking for people who could help me in this project, who would have better skills than me.
To be able to configure the microphone and speaker and have a portable voice assistant.
Thank you in advance and sorry for my english.
I couldn’t reliably get the wake word to work so i left it out entirely but this is what I made based on what I’ve found around the internet about it. The speaker works fine for me, you hold button a until it detects silence and starts processing then you can let go and it will read out the response on the display and say it on the speaker. I tried the media player component but it was slowing it down so i kept with speaker, it’s not very loud but you can monitor a sensor in HA and pull the tts file from it when it changes and play it on something else if you want. I also have code in it to use it as an RFID scanner with the RFID 2 but it was slowing it down so it’s commented out. Honestly it works fine, I’m not sure if I just don’t understand the silence detection flag or it just doesn’t turn off when you set it to false to act like proper ptt, but waiting for it to start processing on its own is fine for now. I also put in a battery bar and charge detection script but it’s not very reliable.
substitutions:
  devicename: m5stickc-plus2
  upper_devicename: M5StickC PLUS2
esphome:
  on_boot:
    - priority: 600
      then:
        - output.turn_on: hold_pin  # Set GPIO4 high to maintain power
        - select.set:
            option: "Full Mode"
            state: "    Voice Assistant\n\n  Button B - Backlight ↖\n\n  Button A - Voice     →\n\n  Button C - Refresh   ↘"
        - light.turn_on: display_bl
  on_shutdown:
    - priority: 600
      then:
        - output.turn_off: hold_pin
        - component.update: battery_percentage
  platformio_options:
wifi:
  ap:
    ssid: "M5Stickc-Plus2 Fallback Hotspot"
captive_portal:
esp32:
  board: m5stick-c
  framework:
    type: arduino
  flash_size: 8MB
logger:
ota:
  - platform: esphome
    password: "..."
api:
  encryption:
    key: "..."
  - platform: adc
    pin: GPIO38
    attenuation: 12db
    update_interval: 1s
    filters:
      - multiply: 2.0
      - round: 2
      - quantile:
          window_size: 7
          send_every: 4
          send_first_at: 3
          quantile: 0.9
    name: "Battery Percentage"
    update_interval: 1s
    unit_of_measurement: "%"
    lambda: |-
      if (!id(battery_voltage).has_state()) {
        return 0.0;  // Default to 0% if the voltage is not available
      float voltage = id(battery_voltage).state;
      // Adjust voltage ranges if needed
      float min_voltage = 3.0;
      float max_voltage = 4.2;
      // Calculate percentage with a simple linear interpolation
      float percentage = (voltage - min_voltage) / (max_voltage - min_voltage) * 100.0;
      // Apply limits
      percentage = percentage > 100.0 ? 100.0 : (percentage < 0.0 ? 0.0 : percentage);
      // Exponential moving average to smooth changes (adjust alpha as needed)
      static float smoothed_percentage = percentage;
      float alpha = 0.5;  // Smoothing factor between 0 and 1
      smoothed_percentage = alpha * percentage + (1 - alpha) * smoothed_percentage;
      return smoothed_percentage;
    update_interval: 1s
    lambda: |-
      if (id(inactivity_counter) > 0) {
        id(inactivity_counter)--;
      if (id(inactivity_counter) == 0) {
        auto call = id(display_bl).turn_off();
        // set parameters (optional)
        call.set_transition_length(1000); // in ms
        // perform action:
        call.perform();
      return id(inactivity_counter);
    unit_of_measurement: "s"
    internal: True
# Voice Assistant Configuration
voice_assistant:
  microphone: stickc_microphone
  speaker: media_out
  auto_gain: 31dBFS
  on_listening:
    - select.set:
        option: "Full Mode"
        state: "Listening..."
  on_stt_vad_end:
    - light.turn_on: led1
        state: "Processing..."
  on_tts_start:
    - light.turn_off: led1
    - select.set:
        option: "Word Mode"
  on_tts_end:
    - globals.set:
        value: "10"
  on_error:
        state: !lambda 'return message;'
  on_idle:
    - select.set:
        option: "Full Mode"
    - globals.set:
        value: "10"
select:
    optimistic: true
    options:
      - "Character Mode"
      - "Word Mode"
      - "Full Mode"
    initial_option: "Full Mode"
    internal: true
globals:
  - id: inactivity_counter
    type: int
    restore_value: no
    initial_value: "10"
number:
    optimistic: true
    min_value: 0.65
    max_value: 1.00
    step: 0.01
    initial_value: 0.8
    restore_value: True
    set_action:
      - light.turn_on:
          brightness: !lambda "return x;"
# Button A to activate the microphone and trigger voice assistant
binary_sensor:
  - platform: gpio
    pin:
      number: GPIO37
      inverted: true
    name: ${upper_devicename} Button A
    on_press:
      - if:
          condition:
            not:
          then:
              silence_detection: false
    on_release:
      - delay: 300ms
      - if:
          condition:
            and:
              - lambda: |-
                  return id(display_text).state != id(text_response).state;
              - lambda: |-
                  return id(display_text).state != "Processing...";
          then:
            - select.set:
                option: "Full Mode"
      - globals.set:
          value: "10"
  - platform: gpio
    pin:
      number: GPIO39
      inverted: true
    name: ${upper_devicename} Button B
    on_click:
      min_length: 50ms
      max_length: 350ms
      then:
  - platform: gpio
    pin:
      number: GPIO35
      inverted: true
    name: ${upper_devicename} Button C
    on_click:
      then:
    lambda: |-
      // Retrieve the current battery percentage
      float current_percentage = id(battery_percentage).state;
      // Static variables to store the last three percentage readings and last valid reading
      static float last_readings[3] = {current_percentage, current_percentage, current_percentage};
      static float last_valid_reading = current_percentage;
      static int index = 0;
      // Define thresholds
      float charging_threshold = 0.5;  // 0.5% increase
      float discharging_threshold = 0.1;  // 0.1% decrease
      // Only update the buffer if the percentage has changed
      if (current_percentage != last_valid_reading) {
        // Update the readings buffer with the current percentage
        last_readings[index] = current_percentage;
        index = (index + 1) % 3;  // Cycle through the last three readings
        // Update the last valid reading
      // Calculate the trend over the last three readings
      bool is_charging = true;
      bool is_discharging = true;
      for (int i = 1; i < 3; i++) {
        if (last_readings[i] <= last_readings[i - 1] + charging_threshold) {
          is_charging = false;
        if (last_readings[i] >= last_readings[i - 1] - discharging_threshold) {
          is_discharging = false;
      // Return true if charging trend is detected, false if discharging, otherwise hold the previous state
      return is_charging ? true : (is_discharging ? false : id(charging_status).state);
# Microphone and buzzer output configuration
output:
  - platform: ledc
    pin: GPIO19
  # Buzzer output
  - platform: ledc
    pin:
      number: GPIO2
    inverted: false
  # Backlight TFT LCD
  - platform: ledc
    pin: 27
    inverted: false
  - platform: gpio
    pin:
      number: GPIO4
      mode: OUTPUT
    inverted: false
i2s_audio:
  - id: mic_adc
    i2s_lrclk_pin:
      number: GPIO0
microphone:
    i2s_din_pin: GPIO34
    adc_type: external
    pdm: true
    channel: left
# media_player:
#     id: media_out
#     name: ${upper_devicename} I2S Media Player
#     mode: mono
speaker:
    dac_type: external
text_sensor:
    name: "Voice Assistant Response"
    icon: "mdi:message-text-outline"
    update_interval: never
#   - platform: template
#     name: "NFC Tag Sensor"
#     id: nfc_tag_sensor
#     icon: "mdi:nfc"  # Optional icon for NFC
#     update_interval: never  # Update only when tag is scanned
    internal: true
    name: "Voice Assistant Response Text"
    internal: true
light:
    output:  builtin_led
    output:  backlight
    name: ${upper_devicename} Backlight
    on_turn_on:
      then:
        - globals.set:
            value: "10"
display:
  - platform: ili9xxx
    model: st7789v
    cs_pin: GPIO5
    dc_pin: GPIO14
    reset_pin: GPIO12
    rotation: 90
    dimensions:
      height: 240
      width: 135
      offset_height: 40
      offset_width: 52
    invert_colors: true
    update_interval: 150ms
    lambda: |-
      // Add a static flag for the button press state
      static bool button_pressed = false;
      // Check if the button has been pressed
      if (id(button_c).state) {
        button_pressed = true;
      enum ProcessingMode {
          CHAR_MODE,
          WORD_MODE,
          FULL_MODE
      // Variable to hold the current processing mode
      ProcessingMode process_mode;
      // Static variables
      static size_t current_char_index = 0;
      static std::deque<std::string> lines;
      static std::string text_buffer;
      static std::string line_buffer;
      static size_t last_space_index = std::string::npos;  // Index of the last space in line_buffer
      // Variables for word mode
      static std::vector<std::string> tokens;
      static size_t current_token_index = 0;
      const int max_chars_per_line = 26;
      const int max_lines = 8;
      // Get the selected mode from the select component
      std::string selected_mode = id(output_mode_select).state;
      if (selected_mode == "Character Mode") {
          process_mode = CHAR_MODE;
      } else if (selected_mode == "Word Mode") {
          process_mode = WORD_MODE;
      } else if (selected_mode == "Full Mode") {
          process_mode = FULL_MODE;
      } else {
          process_mode = FULL_MODE; // Default mode
      // Detect if the mode has changed
      static ProcessingMode last_process_mode = FULL_MODE;
      bool mode_changed = (process_mode != last_process_mode);
      std::string response = id(display_text).state;
      // If the response has changed, the mode has changed, or the button has been pressed, reset the tracking
      if (text_buffer != response || mode_changed || button_pressed) {
          lines.clear();
          text_buffer = response;
          line_buffer.clear();
          // Reset indices
          // Reset button_pressed state
          // In word mode or full mode, split the text into tokens
          if (process_mode == WORD_MODE || process_mode == FULL_MODE) {
              tokens.clear();
              // Custom tokenization that handles words, whitespace, and newlines
              size_t pos = 0;
              while (pos < text_buffer.length()) {
                  char current_char = text_buffer[pos];
                  if (current_char == '\n') {
                      // Add a newline token
                      tokens.push_back("\n");
                      pos++;
                  } else if (current_char == ' ' || current_char == '\t') {
                      // Collect consecutive whitespace characters
                      size_t start = pos;
                      while (pos < text_buffer.length() && (text_buffer[pos] == ' ' || text_buffer[pos] == '\t')) {
                          pos++;
                      tokens.push_back(text_buffer.substr(start, pos - start));
                  } else {
                      // Collect consecutive non-whitespace, non-newline characters (words)
                      size_t start = pos;
                      while (pos < text_buffer.length() && text_buffer[pos] != ' ' && text_buffer[pos] != '\t' && text_buffer[pos] != '\n') {
                          pos++;
          // In FULL_MODE, prepare lines immediately
          if (process_mode == FULL_MODE) {
              // Clear any existing lines and rebuild them based on the entire text
              lines.clear();
              while (current_token_index < tokens.size()) {
                  std::string token = tokens[current_token_index];
                  if (token == "\n") {
                      // Handle newline: add the current line_buffer to lines
                      if (lines.size() == max_lines) {
                          lines.pop_front();
                      lines.push_back(line_buffer);
                      current_token_index++;
                      continue;
                  // Check if the token fits in the remaining space
                  if (line_buffer.length() + token.length() <= max_chars_per_line) {
                      line_buffer += token;
                  } else {
                      if (!line_buffer.empty()) {
                          // Add current line_buffer to lines and start new line
                              lines.pop_front();
                      } else {
                          // Token is too big to fit on one line, need to split it
                          size_t token_pos = 0;
                          while (token_pos < token.length()) {
                              size_t remaining_space = max_chars_per_line - line_buffer.length();
                              size_t chars_to_copy = std::min(remaining_space, token.length() - token_pos);
                              line_buffer += token.substr(token_pos, chars_to_copy);
                              token_pos += chars_to_copy;
                              if (line_buffer.length() >= max_chars_per_line) {
                                      lines.pop_front();
              // Add any remaining text in line_buffer to lines
                      lines.pop_front();
          // Update the last process mode
          last_process_mode = process_mode;
      // Process based on the selected mode
      if (process_mode == CHAR_MODE) {
          // *** Character Mode Processing ***
          if (current_char_index < text_buffer.length()) {
              char next_char = text_buffer[current_char_index];
              current_char_index++;
              // Handle newline character
              if (next_char == '\n') {
                  // Add the current line_buffer to lines
                      lines.pop_front();
                  // Reset last_space_index
              } else {
                  // Add the character to line_buffer
                  line_buffer += next_char;
                  // Update last_space_index if the character is a space
                  if (next_char == ' ' || next_char == '\t') {
                      last_space_index = line_buffer.length() - 1;
                  // Check if line_buffer exceeds max_chars_per_line
                      std::string line_to_add;  // Declare line_to_add here
                      if (last_space_index != std::string::npos) {
                          // Wrap at the last space
                          size_t wrap_index = last_space_index;
                          line_to_add = line_buffer.substr(0, wrap_index);
                          // Remove the line up to the wrap_index from line_buffer
                          line_buffer = line_buffer.substr(wrap_index + 1);
                          // Reset last_space_index in the new line_buffer
                          size_t new_space_index = line_buffer.find_last_of(' ');
                          if (new_space_index != std::string::npos) {
                              last_space_index = new_space_index;
                          } else {
                      } else {
                          // No space found, we have to wrap mid-word
                          line_to_add = line_buffer.substr(0, max_chars_per_line);
                          line_buffer = line_buffer.substr(max_chars_per_line);
                      // Add the line to lines
                          lines.pop_front();
                      lines.push_back(line_to_add);
              id(inactivity_counter) = 10;
      } else if (process_mode == WORD_MODE) {
          // *** Word Mode Processing ***
          if (current_token_index < tokens.size()) {
                      lines.pop_front();
              } else {
                  } else {
                              lines.pop_front();
                      } else {
                                      lines.pop_front();
      } else if (process_mode == FULL_MODE) {
          // *** Full Mode Processing ***
          // No incremental processing needed; lines are already prepared
      // After processing, we need to render the content
      // Clear the screen
      it.fill(id(my_black));
      // it.image(0, 0, id(background_image));
      // Before rendering, add 'line_buffer' to 'lines' if not empty
      bool added_line_buffer = false;
              lines.pop_front();
          added_line_buffer = true;
      // Render the lines
      int y_offset = 0;
      for (const auto& line : lines) {
          it.print(0, y_offset, id(font_id), id(my_green), line.c_str());
          y_offset += 16;
      // After rendering, remove 'line_buffer' if it was added
      if (added_line_buffer) {
          lines.pop_back();
      // Draw battery bar based on battery level and charging status
      float battery_level = id(battery_percentage).state;
      int bar_height = static_cast<int>(battery_level / 100.0 * 135);
      int bar_width = 5;
      // Draw the battery bar on the right side based on charging status
      if (id(charging_status).state) {
        it.filled_rectangle(235, 135 - bar_height, bar_width, bar_height, id(my_blue));  // Blue when charging
      } else {
        it.filled_rectangle(235, 135 - bar_height, bar_width, bar_height, id(my_green));  // Green when not charging
      // Draw red bar to fill the remaining space
      it.filled_rectangle(235, 0, bar_width, 135 - bar_height, id(my_red));
spi:
  clk_pin: GPIO13
  mosi_pin: GPIO15
font:
  - file: "gfonts://LXGW WenKai Mono TC"
    glyphs: " !\"#$%&'()*+,-—./:;<>?@[\\]^_`{|}~°±×÷=≠≤≥∞√∑∏∫∂∇€£¥¢₩‘’“”0123456789ABCDEFGHIJKLMNOPQRSTUVWXYZabcdefghijklmnopqrstuvwxyzÀÁÂÃÄÅÆÇÈÉÊËÌÍÎÏÐÑÒÓÔÕÖØÙÚÛÜÝÞßàáâãäåæçèéêëìíîïðñòóôõöøùúûüýþÿ︵︶︷︸︹︺︻︼︽︾︿﹀□←↑→↓↔↖↗↘↙╭╮╯╰─━┄┅│┃┆┇┌┍┏┐┑┓└┕┗┘┙┛├┝┠┤┥┨┬┯┳┴┷┻┼┽┿╀╁╂"
color:
  - id: my_white
    red: 100%
    green: 100%
    blue: 100%
  - id: my_blue
    red: 0%
    green: 0%
    blue: 100%
  - id: my_red
    red: 100%
    green: 0%
    blue: 0%
  - id: my_green
    red: 0%
    green: 100%
    blue: 0%
  - id: my_yellow
    red: 100%
    green: 100%
    blue: 0%
  - id: my_orange
    red: 100%
    green: 50%
    blue: 0%
  - id: my_black
    red: 0%
    green: 0%
    blue: 0%
# external_components:
#   - source:
#       type: git
#       url: https://github.com/chill-Division/M5Stack-ESPHome/
#       ref: main
#     components: mfrc522_i2c
# i2c:
#   - id: bus_a
#     sda: GPIO32
#     scl: GPIO33
#     scan: true
# mfrc522_i2c:
#   - i2c_id: bus_a
#     address: 0x28 # I2C adress
#     update_interval: 200ms # It seems happiest with 200ms minimum
#     on_tag:
#       then:
#         - light.turn_on: display_bl
#         - select.set:
#             id: output_mode_select
#             option: "Character Mode"
#         - text_sensor.template.publish:
#             id: display_text
#             state: !lambda 'return x;'
#         - homeassistant.tag_scanned: !lambda 'return x;'
#         - light.turn_on: led1
#         - delay: 1s
#         - light.turn_off: led1
