I am trying to get the M5StickC Plus working but i get this error
Compiling .pioenvs/m5stick/lib64d/WiFi/WiFiMulti.cpp.o
src/main.cpp: In function 'void setup()':
src/main.cpp:458:3: error: reference to 'internal' is ambiguous
internal = new remote_transmitter::RemoteTransmitterComponent(esp32_esp32internalgpiopin_4);
In file included from src/esphome/components/font/font.h:3,
from src/esphome.h:27,
from src/main.cpp:3:
src/esphome/core/datatypes.h:9:11: note: candidates are: 'namespace esphome::internal { }'
namespace internal {
src/main.cpp:42:49: note: 'esphome::remote_transmitter::RemoteTransmitterComponent* internal'
remote_transmitter::RemoteTransmitterComponent *internal;
src/main.cpp:459:3: error: reference to 'internal' is ambiguous
internal->set_component_source("remote_transmitter");
src/main.cpp:460:26: error: reference to 'internal' is ambiguous
App.register_component(internal);
src/main.cpp:461:3: error: reference to 'internal' is ambiguous
internal->set_carrier_duty_percent(50);
/config/esphome/m5stickc.yaml: In lambda function:
/config/esphome/m5stickc.yaml:110:31: error: 'ST77XX_WHITE' was not declared in this scope
it.print(80, 0, id(roboto), ST77XX_WHITE, TextAlign::TOP_CENTER, "M5Stick Test");
Compiling .pioenvs/m5stick/lib64d/WiFi/WiFiSTA.cpp.o
*** [.pioenvs/m5stick/src/main.cpp.o] Error 1
My yaml is this.
substitutions:
devicename: m5stick
upper_devicename: M5StickC
esphome:
platform: ESP32
board: m5stick-c
platformio_options:
upload_speed: 115200
wifi:
ssid: !secret wifi_ssid
ap:
ssid: $devicename Fallback Hotspot
captive_portal:
logger:
api:
ota:
external_components:
- source: github://martydingo/esphome-axp192
components: [axp192]
# AXP192 power management - must be present to initialize TFT power on
- platform: axp192
model: M5STICKC
address: 0x34
i2c_id: bus_a
update_interval: 30s
battery_level:
name: "M5Stick Battery Level"
binary_sensor:
- platform: gpio
pin:
number: GPIO37
inverted: true
name: ${upper_devicename} Button A
on_press:
then:
- light.turn_on: led1
on_release:
then:
- light.turn_off: led1
- platform: gpio
pin:
number: GPIO39
inverted: true
name: ${upper_devicename} Button B
on_press:
then:
on_release:
then:
light:
- platform: monochromatic
output: builtin_led
output:
- platform: ledc
pin: 10
inverted: true
remote_transmitter:
- pin:
number: GPIO9
carrier_duty_percent: 50%
spi:
clk_pin: GPIO13
mosi_pin: GPIO15
i2c:
- id: bus_a
sda: GPIO21
scl: GPIO22
scan: True
font:
- file: "gfonts://Roboto"
# 1.14 inch, 135*240 Colorful TFT LCD, ST7789v2
display:
- platform: st7789v
model: TTGO TDisplay 135x240
cs_pin: GPIO5
dc_pin: GPIO23
reset_pin: GPIO18
rotation: 270
lambda: |-
i2s_audio:
i2s_lrclk_pin: G26
i2s_bclk_pin: G0
microphone:
- platform: i2s_audio
i2s_din_pin: GPIO34
i2s_audio_id: bus_i2s
adc_type: external
pdm: true
I have been trying for a while to do this so it would be wonderful if you have a idea to fix.
