Hey together!
For some reasons i want to install HA OS on my Mac Mini M4 in a VM. I would like to use VMware Fusion 13 as it is free for private now.
Can somebody help me? I tried different things but nothing works at the moment.
Thank you!
Hey together!
Thank you!
I highly recommend a proxmox os setup. This is free also and allows for a lot of cool things but you’d need a system you’re willing to put on a server os.
Here’s a step-by-step guide to installing Home Assistant on a Mac Mini using VMware Fusion 13:
Prerequisites
Step 1: Create a New Virtual Machine
Step 2: Configure the Virtual Machine
Step 3: Adjust VM Settings
Step 4: Start the Virtual Machine
Step 5: Access Home Assistant
Open a web browser on your Mac and go to:
http://<VM_IP_ADDRESS>:8123
Step 6: Configure the VM for Better Performance
Optional Step: Update Home Assistant
After setting up the Home Assistant OS, you may want to update to the latest version:
Troubleshooting Tips
Let me know if you run into any challenges or need further assistance!
Yes, i know that proxmox is a good solution and i thought about it. But i need some software only running on macos (FindMySync for example) so i have to run a macos the complete time. Thats the reason why i don´t want to have two machines running also when the Mac Mini M4 is highly overpowered ![]()
Thank you for the setup process. Which VMDK file should i donwload? can you recommend a direkt URL?
I was successfull with the Aarch vmdk - my error on my first tries was to use the wrong vmdk file. Its starting at the moment. Thank you for your help!
Id have to imagine
https://github.com/home-assistant/operating-system/releases/download/14.0/haos_ova-14.0.vmdk.zip
or
https://github.com/home-assistant/operating-system/releases/download/14.0/haos_ova-14.0.ova
.vmdk might be an issue with mac for some reason, and .ova might be designed for ESXi use EFI boot firmware, so maybe enable in the VM settings…
Alternatively, I wonder how many people have put proxmox on a mac and then put osx back in proxmox(is that a hackintosh APPLE?)
I installed it on MacOs 15.2 with fusion 13.6.1. Use haos genric aarch64 vmdk. 32 GB SSD, 2 GB RAM, Network Bridges Ethernet.
I can’t access the haos webpage. The HAOS ist up i can ping it.
Can anyone help.
http://<IP_ADDRESS>:8123) in your browser.homeassistant.local: If the IP doesn’t work, try accessing it via http://homeassistant.local:8123 in case your network supports mDNS.Also just so yall know
For some reason none of the downloaded files can be uploaded/added to the VMFusion setup. They are all greyed out. The only one I could choose was an image from HA generic version 13, but that won’t start up when I load it into the image section of the VM. Any ideas?
Verify that the .vmdk file is fully extracted.
Hello JerryM,
I tried to install HA OS on my Mac Mini M4 following your step-by-step guide but when I start the virtual Machine with de NVME it says: “no compatible bootloader found” and after “no operating system found”
my VM settings are:
CPU 2 cores with 8GB RAM
disk space 64GB
graphics memory 256MB
I tried with haos_ova-14.0.vmdk and haos_ova-14.1.vmdk
Can you help me please ?
Verify the VMDK Is Fully Extracted
When the wizard asks for a disk:
.vmdk file you just extracted.Mac with NVME might be difficult
I still say someone tries a hackintosh setup instead trying to run it on osx
*Disclaimer: i don’t own a mac and wont be testing this. Apple silicone is different depending on the year. Ive used almost every osx released until 2023. If i had to have a mac id use an older bootcamp version(personal preference idk if it would reliably run ha). I imagine any Sequoia device is a real pain to do this with.
I installed HA OS on my Mac Mini M1 with VMware, it is running but have some issue with sound:
https://community.home-assistant.io/t/no-sound-when-installed-on-mac-mini-with-vmware-fusion/900503
