SSHFS – remote file system over SSH
This tutorial is for MacOS. You can probably do the same on Linux, but I don’t know about Windows – I don’t use them on desktop, so can’t help.
This tutorial is a bit advanced. If you actually need SSHFS, you probably don’t need this tutorial → but since I’ve already figured it out, I decided to share it for others (and as a future reference for myself as well).
Why you may want this?
- It mounts a remote filesystem as if it was a normal “disk” (drive, volume) on your Mac.
- You can use the HomeAssistant’s (remote) files in your regular Finder window.
- Easy to copy/move/rename files → open config files in your favorite Mac editor.
- It’s secure (encryption).
- You can’t use / don’t want to use Samba (for “reasons”).
Why not Samba (SMB)?
- Requires additional addon (apart from the “must have” anyway:
Terminal & SSHaddon, hehe) - I’ve experienced issues with Samba mounted volume within Pycharm IDE:
What’s required:
- SSH configured on HomeAssistant (
Terminal & SSHaddon) MacFuseandSSHFSon Mac- Terminal/shell familiarity
The steps:
- Install
Terminal & SSHaddon for your HA:- It is “built–in”: http://homeassistant.local:8123/hassio/addon/core_ssh
- Make sure you can connect to your HA with Mac’s Terminal:
ssh [email protected] - Pro tip: use keys instead of passwords
- Pro tip: Keep the passhprase in Keychain
- Install
MacFuseANDSSHFS(both!): https://osxfuse.github.io/- Unfortunately, it cannot be installed with
homebrewanymore. MacFuseuses a Kernel extension, so u will need to boot into Recovery and set the “Reduced Security” – I think the description is a bit misleading → I wouldn’t worry about it, the extension still needs to be (is being) signed by Apple.
- Mount your HA remote as a MacOS volume via SSHFS.
- It is recommended not to mount at
/Volumes/→ better to do it in your home dir. Therefore I mount it at~/Volumes/homeassistant_ssh/(notice the tilde!). - Not to repeat yourself, make a few shell scripts:
➜ cat sshfs_mount.sh mkdir -p ~/Volumes/homeassistant_sshfs sshfs [email protected]:/ ~/Volumes/homeassistant_sshfs \ -o reconnect \ -o volname=homeassistant_sshfs➜ cat sshfs_unmount.sh diskutil unmount force ~/Volumes/homeassistant_sshfs➜ cat sshfs_remount.sh ./sshfs_unmount.sh ./sshfs_mount.sh - I actually just always call
./sshfs_remount.sh.
- Voila!
Footnotes:
- I know… a bit complicated with all the SSH configurations and scripts… If you only want to mount for Finder → it will be easier with Samba. I personally switched to SSHFS because Pycharm was giving me issues.
- It sometimes disconnects when Mac is put to sleep → just remount the volume.
- Tested on: M1 Mac, Sonoma 14.3.1, MacFuse 4.6.1, SSHFS 2.5.0, HomeAssistant Core 2024.2.5, Terminal & SSH addon 9.10.0.
