Hello, just installed HA (0.98.1) on a MacOS computer (10.13.6/High Sierra) and now I’m trying to get a Z-stick Gen5 to work. My log looks as follows:
2019-09-01 16:14:30 INFO (SyncWorker_0) [openzwave] Start Openzwave network.
2019-09-01 16:14:50 WARNING (Dummy-24) [openzwave] Z-Wave Notification DriverFailed : {'notificationType': 'DriverFailed', 'homeId': 0, 'nodeId': 255}
2019-09-01 16:19:30 WARNING (MainThread) [homeassistant.components.zwave] Z-Wave not ready after 300 seconds, continuing anyway
2019-09-01 16:19:30 INFO (MainThread) [homeassistant.components.zwave] final network state: 1 Driver failed
2019-09-01 16:19:30 ERROR (MainThread) [homeassistant.core] Error doing job: Future exception was never retrieved
File "/usr/local/Cellar/python/3.7.4/Frameworks/Python.framework/Versions/3.7/lib/python3.7/concurrent/futures/thread.py", line 57, in run
File "/Users/bjornekengren/homeassistant/lib/python3.7/site-packages/homeassistant/components/zwave/__init__.py", line 877, in _finalize_start
poll_interval = network.get_poll_interval()
File "/Users/bjornekengren/homeassistant/lib/python3.7/site-packages/openzwave/network.py", line 873, in get_poll_interval
return self.manager.getPollInterval()
File "/Users/bjornekengren/homeassistant/lib/python3.7/site-packages/openzwave/network.py", line 564, in manager
raise ZWaveException(u"Manager not initialised")
openzwave.object.ZWaveException: 'Zwave Generic Exception : Manager not initialised'
For config I have tried both with
zwave:
usb_path: /dev/tty.usbmodem14D41
…and without the zwave
section but it doesn’t seem to be any difference. The OZW_Log:
2019-09-01 16:14:18.794 Always, OpenZwave Version 1.4.3440 Starting Up
2019-09-01 16:14:30.560 Info, Setting Up Provided Network Key for Secure Communications
2019-09-01 16:14:30.560 Info, mgr, Added driver for controller /dev/tty.usbmodem14D41
2019-09-01 16:14:30.560 Info, Opening controller /dev/tty.usbmodem14D41
2019-09-01 16:14:30.560 Info, Trying to open serial port /dev/tty.usbmodem14D41 (attempt 1)
2019-09-01 16:14:30.560 Error, ERROR: Cannot open serial port /dev/tty.usbmodem14D41. Error code 16
2019-09-01 16:14:30.560 Error, ERROR: Failed to open serial port /dev/tty.usbmodem14D41
2019-09-01 16:14:30.560 Warning, WARNING: Failed to init the controller (attempt 0)
2019-09-01 16:14:35.634 Info, Opening controller /dev/tty.usbmodem14D41
2019-09-01 16:14:35.634 Info, Trying to open serial port /dev/tty.usbmodem14D41 (attempt 1)
2019-09-01 16:14:35.634 Error, ERROR: Cannot open serial port /dev/tty.usbmodem14D41. Error code 16
2019-09-01 16:14:35.634 Error, ERROR: Failed to open serial port /dev/tty.usbmodem14D41
2019-09-01 16:14:35.634 Warning, WARNING: Failed to init the controller (attempt 1)
2019-09-01 16:14:40.634 Info, Opening controller /dev/tty.usbmodem14D41
2019-09-01 16:14:40.634 Info, Trying to open serial port /dev/tty.usbmodem14D41 (attempt 1)
2019-09-01 16:14:40.635 Error, ERROR: Cannot open serial port /dev/tty.usbmodem14D41. Error code 16
2019-09-01 16:14:40.635 Error, ERROR: Failed to open serial port /dev/tty.usbmodem14D41
2019-09-01 16:14:40.635 Warning, WARNING: Failed to init the controller (attempt 2)
2019-09-01 16:14:45.685 Info, Opening controller /dev/tty.usbmodem14D41
2019-09-01 16:14:45.685 Info, Trying to open serial port /dev/tty.usbmodem14D41 (attempt 1)
2019-09-01 16:14:45.685 Error, ERROR: Cannot open serial port /dev/tty.usbmodem14D41. Error code 16
2019-09-01 16:14:45.685 Error, ERROR: Failed to open serial port /dev/tty.usbmodem14D41
2019-09-01 16:14:45.685 Warning, WARNING: Failed to init the controller (attempt 3)
2019-09-01 16:14:50.749 Info, Opening controller /dev/tty.usbmodem14D41
2019-09-01 16:14:50.749 Info, Trying to open serial port /dev/tty.usbmodem14D41 (attempt 1)
2019-09-01 16:14:50.749 Error, ERROR: Cannot open serial port /dev/tty.usbmodem14D41. Error code 16
2019-09-01 16:14:50.749 Error, ERROR: Failed to open serial port /dev/tty.usbmodem14D41
2019-09-01 16:14:50.749 Warning, WARNING: Failed to init the controller (attempt 4)
2019-09-01 16:14:50.749 Detail, contrlr, Notification: DriverFailed
So I’m a bit lost here, does anyone have any idea what to try next?
