My installation (on Mac OS running Python 3) seemed to go well enough, but when I run homeassistant I get one error:
ERROR:homeassistant.setup:Error during setup of component frontend
File “/Library/Frameworks/Python.framework/Versions/3.6/lib/python3.6/site-packages/homeassistant/setup.py”, line 190, in _async_setup_component
result = yield from component.async_setup(hass, processed_config)
File “/Library/Frameworks/Python.framework/Versions/3.6/lib/python3.6/site-packages/homeassistant/components/frontend/init.py”, line 308, in async_setup
import hass_frontend
ModuleNotFoundError: No module named ‘hass_frontend’
Any help would be appreciated.
Also, when I get past this, its not clear from the documentation online how I actually start the frontend (it gives hassbian instructions but I’m not using hassbian).
Thank you!
