MacOS: Nmap error
Im getting this error, anyone have any clue?:
2017-07-03 16:07:39 ERROR (MainThread) [homeassistant.components.device_tracker] Error setting up platform nmap_tracker
File “/usr/local/lib/python3.6/site-packages/homeassistant/components/device_tracker/init.py”, line 151, in async_setup_platform
platform.get_scanner, hass, {DOMAIN: p_config})
File “/usr/local/Cellar/python3/3.6.1/Frameworks/Python.framework/Versions/3.6/lib/python3.6/asyncio/futures.py”, line 331, in iter
yield self # This tells Task to wait for completion.
File “/usr/local/Cellar/python3/3.6.1/Frameworks/Python.framework/Versions/3.6/lib/python3.6/asyncio/tasks.py”, line 244, in _wakeup
future.result()
File “/usr/local/Cellar/python3/3.6.1/Frameworks/Python.framework/Versions/3.6/lib/python3.6/asyncio/futures.py”, line 244, in result
raise self._exception
File “/usr/local/Cellar/python3/3.6.1/Frameworks/Python.framework/Versions/3.6/lib/python3.6/concurrent/futures/thread.py”, line 55, in run
File “/usr/local/lib/python3.6/site-packages/homeassistant/components/device_tracker/nmap_tracker.py”, line 47, in get_scanner
scanner = NmapDeviceScanner(config[DOMAIN])
File “/usr/local/lib/python3.6/site-packages/homeassistant/components/device_tracker/nmap_tracker.py”, line 82, in init
self.success_init = self._update_info()
File “/usr/local/lib/python3.6/site-packages/homeassistant/util/init.py”, line 303, in wrapper
result = method(*args, **kwargs)
File “/usr/local/lib/python3.6/site-packages/homeassistant/components/device_tracker/nmap_tracker.py”, line 109, in _update_info
from nmap import PortScanner, PortScannerError
ImportError: cannot import name ‘PortScanner’
