macs79
(Mac)
1
I have followed the instructions here: MacOS - Home Assistant
But when I boot the image, theres this error:
Any suggestions?
I can’t add more than one image per post, so I am replying with more info below.
Thank you and sorry for the newbie question.
I could not find an answer for this case in the forum.
macs79
(Mac)
2
homeassistant.local:8123 is not accessible:
macs79
(Mac)
3
Not sure if there should be an IP address to this interface enp0s3:
macs79
(Mac)
4
This is the VirtualBox setup:
macs79
(Mac)
8
Although docker has this IP Address above, my macbook has the following IP
What version of VirtualBox are you using?
I have the exact same problem. Any help will be appreciated.
ikifar2015
(Matheson Steplock)
12
ensure you are using a hardwired connection on bridged mode, a Wi-Fi connection on the host will not work
