MacOs + VMWare Fusion + Debian 12 + Home Assistant Supervisor - Can't update Home Assistant access token!
That’s exactly what it does. Pinning is not really necessary, it’s just a precautionary step. Once there’s a fix, you should unpin the version and allow updates again:
prompt: sudo apt-mark unhold docker-ce
yes, thank you, sorry for not responding sooner @schneich
For Debian Bookworm the new version 25.0.1-1 released yesterday seems to work for me on rpi5.
docker-ce (5:25.0.1-1~debian.12~bookworm) bookworm; urgency=low
  * Version: 25.0.1
  -- Docker <[email protected]>  Tue, 23 Jan 2024 23:09:35 +0000
So as written above you can run the command below to unhold and the run the normal update.
Just did the update as Anteus suggested and everything is working OK. Can say it is safe to proceed.
