Hi I have a fresh install of Home assistant supervisor running on Debian 12 that is installed via VMWare fusion on a Mac OS Ventura. Home assistant is working in general, but the supervisor is not starting. I checked the existing posts with similar issues, but no luck. I feel like it has something to do with my vm ip address starting with 172. vs my host machine ip starting with 192.
Here are the logs:
24-01-19 10:22:36 ERROR (SyncWorker_0) [supervisor.docker.network] Can't link container to hassio-net: 500 Server Error for http+docker://localhost/v1.44/networks/0cab060795c263609f1b1d2f2f2c735b551c372d686a8c9d46a8800251011c51/connect: Internal Server Error ("invalid endpoint settings:
no configured subnet or ip-range contain the IP address 172.30.32.4")
24-01-19 10:22:36 WARNING (SyncWorker_0) [supervisor.docker.manager] Can't attach hassio_audio to hassio-network!
24-01-19 10:22:36 INFO (MainThread) [supervisor.docker.audio] Starting Audio ghcr.io/home-assistant/aarch64-hassio-audio with version 2023.12.0 - 172.30.32.4
24-01-19 10:22:41 ERROR (MainThread) [supervisor.store.git] Can't clone https://github.com/hassio-addons/repository repository: Cmd('git') failed due to: exit code(128)
cmdline: git clone -v --recursive --depth=1 --shallow-submodules -- https://github.com/hassio-addons/repository /data/addons/git/a0d7b954
stderr: 'Cloning into '/data/addons/git/a0d7b954'...
fatal: unable to access 'https://github.com/hassio-addons/repository/': Could not resolve host: github.com
24-01-19 10:22:41 ERROR (MainThread) [supervisor.store] Can't retrieve data from https://github.com/hassio-addons/repository due to
24-01-19 10:29:09 INFO (MainThread) [supervisor.docker.observer] Starting Observer ghcr.io/home-assistant/aarch64-hassio-observer with version 2023.06.0 - 172.30.32.6
24-01-19 10:29:12 ERROR (MainThread) [supervisor.homeassistant.api] Can't update Home Assistant access token!
24-01-19 10:29:32 ERROR (MainThread) [supervisor.homeassistant.api] Can't update Home Assistant access token!
24-01-19 10:29:37 ERROR (MainThread) [supervisor.homeassistant.api] Can't update Home Assistant access token!
24-01-19 10:29:42 ERROR (MainThread) [supervisor.homeassistant.api] Can't update Home Assistant access
I’m facing the exact same issue… for some reason the deployment fails to bind the containers to the hassio docker network… so the containers don’t get the expected fixed ip’s and communication fails…
24-01-19 15:42:33 INFO (MainThread) [supervisor.bootstrap] Seting up coresys for machine: qemux86-64
24-01-19 15:42:33 INFO (SyncWorker_0) [supervisor.docker.supervisor] Attaching to Supervisor homeassistant/amd64-hassio-supervisor with version 2023.06.dev2301
24-01-19 15:42:33 INFO (SyncWorker_0) [supervisor.docker.supervisor] Connecting Supervisor to hassio-network
24-01-19 15:42:33 ERROR (SyncWorker_0) [supervisor.docker.network] Can't link container to hassio-net: 500 Server Error for http+docker://localhost/v1.44/networks/1db3d3c73b977f6cc7b416c58d8b1fee3560b5d4cf2a4294f64e8feea28007ef/connect: Internal Server Error ("invalid endpoint settings:
no configured subnet or ip-range contain the IP address 172.30.32.2")
24-01-19 15:42:33 CRITICAL (MainThread) [supervisor.supervisor] Can't setup Supervisor Docker container!
24-01-19 15:42:33 WARNING (SyncWorker_1) [supervisor.docker.interface] Can't find homeassistant/amd64-hassio-supervisor for cleanup
24-01-19 15:42:33 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state CoreState.INITIALIZE
24-01-19 15:42:33 WARNING (MainThread) [supervisor.resolution.evaluations.base] Found unsupported job conditions settings. (more-info: https://www.home-assistant.io/more-info/unsupported/job_conditions)
24-01-19 15:42:33 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
24-01-19 15:42:33 ERROR (MainThread) [supervisor.core] Update '2023.12.1' of Supervisor '2023.06.dev2301' failed!
24-01-19 15:42:33 INFO (MainThread) [supervisor.resolution.module] Create new issue IssueType.UPDATE_ROLLBACK - ContextType.SUPERVISOR / None
24-01-19 15:42:33 INFO (MainThread) [__main__] Setting up Supervisor
24-01-19 15:42:33 INFO (MainThread) [supervisor.api] Starting API on 172.30.32.2
24-01-19 15:42:34 CRITICAL (MainThread) [supervisor.hardware.monitor] Not privileged to run udev monitor!
I was able to trace this back to a system update on Debian 10, and there rolling-back docker-ce and pinning the downgraded version like following solved the issue:
Thank you, the rolling-back was the solution for me as well on Debian 12.
My docker version was “25.0.0-1~debian.12~bookworm”, and reverted back to the earlier one: “24.0.7-1~debian.12~bookworm”. I changed it in your command and it worked well - thankfully.
Same problem here, half of my containers running on Portainer were not able to start. I even lost a couple of them, luckily volumes with their states are still there.
I followed your downgrade suggestion and everything is back online now. I guess that should be reported to the Debian upstream.
Could you please explain, what this command is doing? I assume, it is preventing future updates on docker? Do I need this command? I am updating once a month and I hope, it will be fixed in a future version.
