Made my Dumb 433Mhz roof FAN a bit smarter
After watching @DrZzs
and doing it I could tasmota to lean the rf codes It has 4 speeds
high med low off
so I created a script for each one and MQTT sensor which keep track of the Speed
the two Sensor
- platform: mqtt
  name: "Lounge Fan Status"
  state_topic: "home/lounge-fan"
- platform: mqtt
  name: "Lounge Fan cmnd"
  state_topic: "home/lounge/fan/cmnd/FanSpeed"
now the Scripts
lounge_fan_3:
  alias: lounge fan Speed 3
  sequence:
    - service: mqtt.publish
        topic: "cmnd/RF_Bridge_raw/Backlog"
        payload: "RFRAW AA B0 1E 03 08 017C 02E4 2620 28090909181818180909090909090909180909090909 55 RFRAW 0"
        payload: "3"
        payload: "on"
  mode: single
lounge_fan_2:
  alias: lounge fan Speed 2
  sequence:
        payload: "RFRAW AA B0 1E 03 08 0172 02E4 2620 28090909181818180909090909090918090909090918 55 RFRAW 0"
        payload: "2"
        payload: "on"
  mode: single
lounge_fan_1:
  alias: lounge fan Speed 1
  sequence:
        payload: "RFRAW AA B0 1E 03 08 0172 02E4 2620 28090909181818180909090909090918180909091809 55 RFRAW 0"
        payload: "1"
        payload: "on"
  mode: single
lounge_fan_0:
  alias: lounge fan Speed 0
  sequence:
        payload: "RFRAW AA B0 1E 03 08 017C 02E4 2620 28090909181818180909090909090909090918181818 55 RFRAW 0"
        payload: "0"
        payload: "off"
  mode: single
NOTE the script name and the payload of the MQTT
now the fan controler bit
- platform: mqtt
  command_topic: "home/lounge/fan/cmnd/FanSpeed"
  speed_state_topic: "home/lounge-fan"
  speed_command_topic: "home/lounge-fan"
  payload_on: "on"
  payload_off: "off"
  payload_low_speed: "1"
  payload_medium_speed: "2"
  payload_high_speed: "3"
  speeds:
    - low
    - medium
    - high
now the bit that join them
I want the right script to run when I select the speed
so could used the new choose option (still getting head around it)
- id: b12c44a8-d707-4892-9f75-c84c6927dab4
  alias: Lounge Fan Control
  initial_state: true
    - entity_id: sensor.lounge_fan_status
      platform: state
  - data_template:
      entity_id: script.lounge_fan_{{ trigger.to_state.state }}
    service: script.turn_on
now the tidy ups
- id: c9fe33f8-07a1-4bf3-9bd5-2fd144d4dcd6
  alias: Lounge Fan Status right
  - entity_id: sensor.lounge_fan_cmnd
    platform: state
    to: 'off'
        payload: 0
as I have all the right bits to make a switch so
    switches:
      lounge_fan:
        icon_template: mdi:fan
        friendly_name: Lounge Fan
        value_template: '{{ is_state("sensor.lounge_fan_cmnd", "on") }}'
        turn_on:
            entity_id: script.lounge_fan_1
        turn_off:
            entity_id: script.lounge_fan_0
putting all together
here the code
cards:
  - cards:
      - entity: climate.lounge_fan
        type: 'custom:simple-thermostat'
        step_layout: row
        control:
          _headings: false
    type: horizontal-stack
  - cards: null
    entities:
      - entity: fan.lounge_fan
        type: 'custom:fan-control-entity-row'
      - entity: switch.lounge_fan
    type: entities
  - cards:
      - align_state: center
        entities:
          - color: '#11A579'
            entity: sensor.bt_lounge_temperature
            index: 0
        type: 'custom:mini-graph-card'
type: 'custom:vertical-stack-in-card'
cant take credit for the lovelace found that in here.
Make Smarter
what about working out the difference between the room temp and the climate setpoint
do some maths
    lounge_factor:
      friendly_name: Lounge Factor
      value_template: >-
        {%set temp_indoor = states.sensor.bt_lounge_temperature.state | float %}
        {%set temp_fan = state_attr("climate.lounge_fan","temperature") %}
        {%set  factor = (temp_indoor - temp_fan)|int %}
        {{factor}}
now I get a Number
add a Input_boolean
  lounge_auto:
    initial: off
so other automation
- id: 4d586798-4280-49e7-afc0-0e675bb30dbd
  alias: Auto Lounge Fan Control
  initial_state: true
  - platform: state
    entity_id: sensor.lounge_factor
  condition:
    condition: and
    conditions:
    - condition: state
      entity_id: input_boolean.lounge_auto
      state: 'on'
    - condition: numeric_state
      above: 0
  - data_template:
so now if as the room get warmer the fan speed should increase and decrease and it get cooler
I’m currently trying to implement this into my HA and I’m stuck at this point, I have added it into my config.yaml
