Magic Blue Bulb Bluetooth 4.0
Hi Guys,
Has anyone looked at this bulb http://www.gearbest.com/smart-light-bulb/pp_230349.html, I’ve got a couple they are pretty cheap and come in 3 flavours (E26/7 and B22) and with the app you can do plenty with them, however I want to control them via my RPI3 and this https://github.com/Betree/magicblue has been written by Betree in python, so my question is would it be possible to integrate into HA? I can currently control them with scripts using commandline (sudo magicblueshell -c ‘set_color red’ -m C7:17:1D:43:39:03) but it would be nice if they were integrated with HA.
Keith
Any luck with this? I was thinking of getting either the one you listed or similar (bulb) and would want to control it through HASS.
I haven’t been able to integrate MB bulb with HA yet so I’m still using scripts to control them. As for your bulb I couldn’t find any python to control it so I’m guessing that it would not integrate with HA, unless you can find out what codes the bulb is using.
Hey, I am the main developer of magicblue unofficial API.
I just found out about this post and the HomeAssistant project and it looks really cool :smile:
As you said the API is written in python 3 so it shouldn’t be complicated to integrate. Project can be used in command line as you’re doing now in your scripts but Python API is pretty straightforward too :
>>> from magicbluelib import magicblue
>>> bulb_mac_address = 'XX:XX:XX:XX:XX:XX'
>>> bulb = MagicBlue(bulb_mac_address)
>>> bulb.connect()
>>> bulb.set_color([255, 0, 0])         # Set red
>>> bulb.set_random_color()             # Set random
>>> bulb.turn_off()                     # Turn off the light
>>> bulb.turn_on()                      # Set white light
By looking at the HomeAssistant documentation example here you may just be able to include magiblue in REQUIREMENTS and use it directly. We may have to deploy it on https://pypi.python.org/ first (I’m not sure how they manage their dependencies).
However I don’t have the time to do it now but would be happy to help if someone wants to :wink:
Hey @Betree, I have a single bulb that i have bought in error so I am going to have a play with the AppDaemon in HomeAssistant to see if i can get some sort of control over it as a trial via a standard Python script, then i will look at a custom light platform
Edit: Will go through this: https://github.com/Betree/magicblue
Any tips?
Ok I went straight for the custom component but hit an issue.
I am getting
Command “python setup.py egg_info” failed with error code 1 in /tmp/pip-mleix1z3-build/
When i start HASS after adding the light to the config.
@Betree any ideas?
Also will i need the bulb to have just turned on in order to get a connection to it? Once connected will the bulb remember the source of the connection for the next time?
This command works fine when I run it directly on magicblue setup.py :
$ python setup.py egg_info
running egg_info
writing requirements to magicblue.egg-info/requires.txt
writing magicblue.egg-info/PKG-INFO
writing top-level names to magicblue.egg-info/top_level.txt
writing dependency_links to magicblue.egg-info/dependency_links.txt
writing entry points to magicblue.egg-info/entry_points.txt
reading manifest file 'magicblue.egg-info/SOURCES.txt'
reading manifest template 'MANIFEST.in'
writing manifest file 'magicblue.egg-info/SOURCES.txt'
Do you have any more logs you could provide ? What is the content of the directory printed when it fails (/tmp/pip-mleix1z3-build/) ?
Hey @Betree, i tried removing homeassistant from the equation.
Turns out I’m not getting much luck even directly through the shell commands or gatttool.
The tool will just not connect to the bulb. Hcitool sees it and i get the Mac address but no commands work. Could it be a version thing?
See my post here Xiaomi Mi Plants Monitor Flower at the bottom, for what I had to do to get BLE working.
In the bluemagic app what hardware does it say your bulb is? (just incase you have a newer version)
Thanks. Just took a look through.
Bulb hardware is v10. That was the easy bit.
Unfortunately after reinstalling my bluez version, following the steps, hciconfig no longer returns any results.
Bluetooth service is running, but there appears to be no devices anymore.
So i thinks this going to take a bit longer, last resort will be a reinstall of raspbian, but as that will knock out all my lighting in the house it is a definite last resort.
What does bluetoothctl come back with, can you see any devices using scan on?
OK, I see you have a newer version than magicblue supports, but if you specify version 9 it might work i think. Also wrt bluetooth … https://cdn-learn.adafruit.com/downloads/pdf/install-bluez-on-the-raspberry-pi.pdf this might help.
Right, i’ll give this a proper go tonight, currently working away. Before i left i did manage to do a quick run of bluetoothctl.
No Default Controller Available(or similar error, sorry doing this from memory). Not had a chance to do anything further, a quick scan of blogs gives this [http://raspberrypi.stackexchange.com/questions/48220/raspberry-pi-3-bluetooth-no-default-controller-available] (http://raspberrypi.stackexchange.com/questions/48220/raspberry-pi-3-bluetooth-no-default-controller-available) sio i’ll give that a shot.
WRT the adafruit link, this was the article i used to do the setup, the bluetooth service runs fine, it is really odd.
I feel your pain, it’s taken me a good two weeks to get my ble working properly, as although I use a RPI3 I use an external dongle for bluetooth :stuck_out_tongue:
Good luck getting yours working.
Finally got it working… Had to go through this article. https://www.pi-supply.com/make/fix-raspberry-pi-3-bluetooth-issues/
Managed to control the bulb from the shell script (some odd errors but it worked).
Then tried to put a quick python script together, However the first line failed
pi@raspberrypi:~/magicblue $ python3 MagicBlue.py
  File "MagicBlue.py", line 1, in <module>
ImportError: No module named 'magicbluelib'
If i run via the python shell:
Python 2.7.9 (default, Sep 17 2016, 20:26:04)
[GCC 4.9.2] on linux2
Type "help", "copyright", "credits" or "license" for more information.
  File "<stdin>", line 1, in <module>
ImportError: No module named magicbluelib
(Full disclosure, i am a c# / javascript dev by trade, Python NOOB. So could well just be a stupid thing like paths)
magicbluelib.py should be in the magicblue dir after installing it, at least it is in mine.
Your feedback about V10 compatibility will be valuable, don’t hesitate to open an issue on Github to report bugs or installation specificities.
For your current problem, I assume you simply cloned the repo. The easiest way to use magicblue is to install it, either by calling python3 setup.py install in your cloned repo or directly with :
pip3 install git+https://github.com/Betree/pyMagicBlue.git
:warning: You may have to run previous commands as root
Of course you’ll need the dependencies but I think you already got that part :
sudo apt-get install libglib2.0-dev
sudo pip3 install bluepy
Then you’ll be able to run magicblueshell command or to import it with :
from magicblue import MagicBlue
There was a glitch in README.md, I just fixed it with the previous line.
Thanks Guys.
Install was done following the readme, so i used the pip3 install command.
With the corrected import line, running from the Python shell as sudo i now get:
pi@raspberrypi:~ $ sudo python
  File "magicblue/MagicBlue.py", line 1, in <module>
ImportError: cannot import name MagicBlue
If i go via a script (after making the mistake of using CAPS in my mac address) i can get control.
A quick test in Home Assistant was unsuccessful,
Command "python setup.py egg_info" failed with error code 1 in /tmp/pip-0uc30b7c-build/
The path is a director where home assistant seems to unpack things
I wonder if have the wrong line for requirements:
REQUIREMENTS = [
    'https://github.com/Betree/magicblue'
    '/archive/0.2.2.zip'
    '#magicblue==0.2.2']
EDIT: Looking through the Home Assistant doc yes that bit is wrong. I’ll try installing it with a target to the deps folder tonight.
Are you sure your default python is python 3 ? On most debian-like systems python command is mapped to python2.7. You can run python --version to check that.
If this is your problem, you can usually run python 3 with python3 command. Ubuntu and some others also provide a pip3 package. Python 2 and Python 3 environments are totally separated (libraries you install for one version are only installed for this version).
Also, MagicBlue is only compatible with Python3 but it should be fine as HomeAssistant run on Python 3 too :slight_smile:
Yep Python 3 is there.
Got my python script working in isolation from Home Assistant so step 1 is done.
So i have now installed the magicblue library with a target of the deps folder (as per Home Assistant instructions) which has stopped the setup.py egg_info error. So another step forward!
However the start of the Home Assistant service now gets stuck and does not load any of my lights. I cannot see an errors but the load gets halted.
My theory is that the connection to the bulb is not going through, I think this may be sue to the need for the python script needing to run under sudo to access the bluetooth but Home Assistant not running it’s components in the same manner.
Any pointers welcome.
