You should use a photo of a jukebox, or her favorite nostalgic music device.
Loving the project. Most of the integrations are in place, Hass and Spotify only so far. I am running the project just as described on git and with the pre-made Docker-config (just disabled the Sonos docker). It works most of times, but in a couple of instances I have gotten an error message and only way to resolve it, so far, have been to trigger the restart script. Error is:
Read Card ID: 5500d2b10d
magic-cards | [1] Finding card...
magic-cards | [1] Found card: Lounge Music. Processing...
magic-cards | [1] Processing action: Home Assistant
magic-cards | [1] {"message": "Event magic_card_scanned fired."}
magic-cards | [1] events.js:165
magic-cards | [1] throw er; // Unhandled 'error' event
magic-cards | [1] ^
magic-cards | [1]
magic-cards | [1] Error: ENODEV: no such device, read
magic-cards | [1] Emitted 'error' event at:
magic-cards | [1] at ReadStream.<anonymous> (/usr/src/app/scanner/node_modules/input-event/lib/index.js:45:10)
magic-cards | [1] at ReadStream.emit (events.js:180:13)
magic-cards | [1] at fs.read (fs.js:2116:12)
magic-cards | at FSReqWrap.wrapper [as oncomplete] (fs.js:673:17)
magic-cards | [1] error Command failed with exit code 1.
magic-cards | [1] info Visit https://yarnpkg.com/en/docs/cli/run for documentation about this command.
magic-cards | [1] yarn scanner exited with code 1
Anyone else experiencing this or know where I could look for a solution?
eww, could you open an issue on maddox/magic-cards repo for this? I’ll look into it.
Having to manually restart is a bummer.
I’ll investigate some more on my part and open an issue on git if the problem reoccurs.
i would be also interested in realizing this project in my home. but I was wondering if I would need to buy a separate rpi for the nfc reader as my hass.io is already running on a rpi 3.
Can’t I just connect the nfc reader to the rpi running hass.io? or does it need to be used on a separate rpi?
Adding running software to hass.io requires it to be bundled as a hass.io add-on. Magic Cards does not support that.
I had the same problem for some software installations, but I wanted to take advantages of both worlds.
It is possible to install hass.io on a Hassbian image
It was fluent, but needed some work. When I have some time left, I’ll post a tutorial…if someone is interested
BTW I love your Magic Cards
my pi zero w arrived and i tried getting it to run but with no luck. this is what i got:
pi@raspberrypi:~ $ ls -al /dev/input
total 0
drwxr-xr-x 4 root root 120 Sep 7 08:44 .
drwxr-xr-x 14 root root 3280 Sep 7 08:44 ..
drwxr-xr-x 2 root root 60 Sep 7 08:44 by-id
drwxr-xr-x 2 root root 60 Sep 7 08:44 by-path
crw-rw---- 1 root input 13, 64 Sep 7 08:44 event0
crw-rw---- 1 root input 13, 63 Sep 7 08:44 mice
pi@raspberrypi:~ $ docker ps
CONTAINER ID IMAGE COMMAND CREATED STATUS PORTS NAMES
ddf4ac219f0d jonmaddox/magic-cards "/usr/bin/entry.sh s…" 17 minutes ago Up 2 minutes 0.0.0.0:5000->5000/tcp magic-cards
pi@raspberrypi:~ $ curl 192.168.1.60:5000
curl: (7) Failed to connect to 192.168.1.60 port 5000: Connection refused
do you guys have an idea what is going wrong?
did you try checking the log output of the docker container to see if it was reporting any errors? Are you sure that’s the right IP?
Try curl localhost:5000
as well.
yupp, i am sure and local host is no different unfortunately. i cannot check the log output as apparently the container is restarting the whole time.
sorry, found the log:
2018-09-07T19:15:41.729044995Z [0] yarn server exited with code null
2018-09-07T19:15:41.822298739Z error Command failed with exit code 1.
2018-09-07T19:15:46.983919605Z Starting Magic Cards...
2018-09-07T19:16:50.250412181Z [0] $ cd server && yarn start
2018-09-07T19:16:50.427021723Z [1] $ cd scanner && yarn start
2018-09-07T19:17:26.022959641Z [0] $ node server.js
2018-09-07T19:17:26.535814347Z [1] $ node scanner.js
2018-09-07T19:17:46.879829407Z [1] internal/modules/cjs/loader.js:550
2018-09-07T19:17:46.880082406Z [1] throw err;
2018-09-07T19:17:46.880214406Z [1] ^
2018-09-07T19:17:46.880335405Z [1]
2018-09-07T19:17:46.880453405Z [1] Error: Cannot find module '/usr/src/app/scanner/actions/../../config/config.json'
2018-09-07T19:17:46.880571405Z [1] at Function.Module._resolveFilename (internal/modules/cjs/loader.js:548:15)
2018-09-07T19:17:46.880691404Z [1] at Function.Module._load (internal/modules/cjs/loader.js:475:25)
2018-09-07T19:17:46.880809404Z [1] at Module.require (internal/modules/cjs/loader.js:598:17)
2018-09-07T19:17:46.880927404Z [1] at require (internal/modules/cjs/helpers.js:11:18)
2018-09-07T19:17:46.881043404Z [1] at Object.<anonymous> (/usr/src/app/scanner/actions/Action.js:1:84)
2018-09-07T19:17:46.881166403Z [1] at Module._compile (internal/modules/cjs/loader.js:654:30)
2018-09-07T19:17:46.881288403Z [1] at Object.Module._extensions..js (internal/modules/cjs/loader.js:665:10)
2018-09-07T19:17:46.881407403Z [1] at Module.load (internal/modules/cjs/loader.js:566:32)
2018-09-07T19:17:46.881563402Z [1] at tryModuleLoad (internal/modules/cjs/loader.js:506:12)
2018-09-07T19:17:46.887332388Z at Function.Module._load (internal/modules/cjs/loader.js:498:3)
2018-09-07T19:17:46.999663109Z [1] error Command failed with exit code 1.
2018-09-07T19:17:47.010395082Z [1] info Visit https://yarnpkg.com/en/docs/cli/run for documentation about this command.
2018-09-07T19:17:47.199604612Z [1] error Command failed with exit code 1.
2018-09-07T19:17:47.214484575Z [1] info Visit https://yarnpkg.com/en/docs/cli/run for documentation about this command.
2018-09-07T19:17:47.424539053Z [1] yarn scanner exited with code 1
2018-09-07T19:17:47.440248014Z --> Sending SIGTERM to other processes..
2018-09-07T19:17:49.457024008Z [0] internal/modules/cjs/loader.js:550
2018-09-07T19:17:49.457249008Z [0] throw err;
2018-09-07T19:17:49.457372007Z [0] ^
2018-09-07T19:17:49.457491007Z [0]
2018-09-07T19:17:49.457609007Z [0] Error: Cannot find module '/usr/src/app/server/../config/config.json'
2018-09-07T19:17:49.457726007Z [0] at Function.Module._resolveFilename (internal/modules/cjs/loader.js:548:15)
2018-09-07T19:17:49.457921006Z [0] at Function.Module._load (internal/modules/cjs/loader.js:475:25)
2018-09-07T19:17:49.458050006Z [0] at Module.require (internal/modules/cjs/loader.js:598:17)
2018-09-07T19:17:49.458163005Z [0] at require (internal/modules/cjs/helpers.js:11:18)
2018-09-07T19:17:49.458280005Z [0] at Object.<anonymous> (/usr/src/app/server/server.js:7:16)
2018-09-07T19:17:49.458396005Z [0] at Module._compile (internal/modules/cjs/loader.js:654:30)
2018-09-07T19:17:49.458508005Z [0] at Object.Module._extensions..js (internal/modules/cjs/loader.js:665:10)
2018-09-07T19:17:49.458621004Z [0] at Module.load (internal/modules/cjs/loader.js:566:32)
2018-09-07T19:17:49.458735004Z [0] at tryModuleLoad (internal/modules/cjs/loader.js:506:12)
2018-09-07T19:17:49.484382940Z at Function.Module._load (internal/modules/cjs/loader.js:498:3)
2018-09-07T19:17:49.523788843Z [0] error Command failed with exit code 1.
2018-09-07T19:17:49.532776820Z [0] info Visit https://yarnpkg.com/en/docs/cli/run for documentation about this command.
2018-09-07T19:17:49.638052559Z [0] error Command failed with exit code 1.
2018-09-07T19:17:49.646811538Z [0] info Visit https://yarnpkg.com/en/docs/cli/run for documentation about this command.
2018-09-07T19:17:49.703851396Z [0] yarn server exited with code null
2018-09-07T19:17:49.804025148Z error Command failed with exit code 1.
2018-09-07T19:17:56.011190790Z Starting Magic Cards...
2018-09-07T19:19:01.518884784Z [1] $ cd scanner && yarn start
2018-09-07T19:19:01.622494540Z [0] $ cd server && yarn start
and github tells me to use
script/install
in order to start magic cards but it just gives the following:
pi@raspberrypi:~ $ script/install
-bash: script/install: No such file or directory
I think you need to be in the magic-cards directory.
cd magic-cards
script/install
You’re conflating the installation instructions. You only use that command if you’re installing onto your system. But you are using the docker image. You don’t use that when using docker.
It’s erroring because you didn’t create your config file. You need to have a config.json file for the project, and have it mounted into your docker container.
Please re-read the instructions on how to set things you. You’ve left a few things out.
regarding the script/install topic:
Yeah, I thought so as it did not make sense to me. But no harm was done anyway so I tried. The reason I tried anyway was because it was listed as a seperate item on the table of content of the instructions and not as part of the standalone installation topic.
regarding the missing config.json:
I followed the instructions carefully, which is why I already had a config file:
pi@raspberrypi:~/magic-cards $ cd config
pi@raspberrypi:~/magic-cards/config $ ls -l
total 12
-rw-r--r-- 1 root root 125 Sep 7 08:04 actions.json
-rw------- 1 pi pi 1319 Sep 7 08:22 actions.json.save
-rw-r--r-- 1 root root 61 Sep 7 08:19 config.json
- I do not know what the actions.json.save is. can I delete it? there is a chance that it was created by me by mistake
- i think the missing part is the “mount it into your docker container”. There is no word about “mounting” in the instructions. How do I do that?
That actions.jaon.save file looks like some cache or something from your editor. You can delete it.
In the instructions it show that you start the container like this:
--name magic-cards \
--restart=always \
-d \
-p 5000:5000 \
-v `pwd`/config:/usr/src/app/config \
--device=/dev/input/event0 \
The -v part is where it’s mounting the config directory into your docket container. Run this command inside the project directory for it to work as pasted. Otherwise you need to adjust the path in that line to your config directory.
ok, now i just formated the sd card and set everything up again from scratch and I end up with the same error. so frustrating and I honestly am following the instructions. the only thing I can think of is that I am installing the container wrongly. Both times I ran Docker from within the rpi root folder (not from within the magic-cards folder) . And the actions and config json files are placed in magic-cards/config/ and the content is as follows:
config.json:
"room": "Living Room",
"input_device": "event0"
actions.json:
"Home Assistant": {
"type": "home_assistant",
"host": "192.168.1.15",
"port": "8123",
"ssl": true,
"password": "MY_HA_API_PASSWORD"
I now deleted the container and rerun the command from within the magic-cards folder. it still does nto work but the log has changed:
[0] /usr/src/app/server/server.js:11
[0] clientId: config.spotify.clientID,
[0] ^
[0]
[0] TypeError: Cannot read property 'clientID' of undefined
[0] at Object.<anonymous> (/usr/src/app/server/server.js:11:28)
[0] at Function.Module._load (internal/modules/cjs/loader.js:498:3)
[0] at Function.Module.runMain (internal/modules/cjs/loader.js:695:10)
[0] at startup (internal/bootstrap/node.js:201:19)
[0] at bootstrapNodeJSCore (internal/bootstrap/node.js:516:3)
[0] yarn server exited with code 1
[0] ^
[0]
ok, it now works for me after some trial and error and logical thinking, although i had no knowledge about this terminal stuff before.
the mistakes I made, which were also not crystal clear in the github readme:
- the container needs to be run from within the magic-cards folder
- the config.json MUST include room, input device AND spotify components (in the readme it just says that the given config parameters are just an example)
now, magic cards is running. but that was jsut the setup, i will now try to use it and I am pretty sure that I will bother you again with further advice request
I just tried to create a card, while it auto populates the required fields, I was hoping that the Card Code will automatically be populated when I swipe the RFID card over the RFID reader (which is attached to the rpi zero via micro usb). but it does not and honestly I do know what the readme exactly means here:
What do I need to do to auto populate the card ID? Does my rpi recognize the rfid scanner as “mice”?
pi@raspberrypi:/dev/input $ ls -1
by-id
by-path
event0
mice
pi@raspberrypi:/dev/input $ cd /dev/input/by-id/
pi@raspberrypi:/dev/input/by-id $ ls -l
total 0
lrwxrwxrwx 1 root root 9 Sep 9 12:38 usb-Sycreader_USB_Reader_08FF20150112-event-kbd -> ../event0`
Heya, glad to see you got it up and running. Thanks for the feedback on what failed if it wasn’t set up. Yes, a lot of assumptions are built into it.
As for the Card ID, you will need to have the scanner plugged into your computer that you’re using to create cards. With it plugged in…focus the Card ID field in the card editor, and scan your card. That will input the card’s ID. The scanner acts just like a keyboard.
This is why the instructions suggest purchasing 2 card scanners. One for your Magic Cards install and one for managing cards from your computer. Be sure you also follow the instructions for setting up the card scanner. You need to use windows software to configure the scanner and put it into a specific mode for this to work. The instructions are in there.
