I got a magic home led controller but is doesnt work that wel on/off works fine and coller picking as wel but as soon as i warm white select it doesnt react anymore.
- platform: flux_led
devices:
192.168.1.37:
mode: "rgbw"
Logger: homeassistant.components.websocket_api.http.connection
Source: components/flux_led/light.py:349
Integration: Home Assistant WebSocket API (documentation, issues)
First occurred: 16:21:50 (8 occurrences)
Last logged: 16:28:05
[547758714736]
[547610660096]
File "/usr/src/homeassistant/homeassistant/components/websocket_api/commands.py", line 185, in handle_call_service
await hass.services.async_call(
File "/usr/src/homeassistant/homeassistant/core.py", line 1491, in async_call
task.result()
File "/usr/src/homeassistant/homeassistant/core.py", line 1526, in _execute_service
await handler.job.target(service_call)
File "/usr/src/homeassistant/homeassistant/helpers/entity_component.py", line 213, in handle_service
await self.hass.helpers.service.entity_service_call(
File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 658, in entity_service_call
future.result() # pop exception if have
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 760, in async_request_call
await coro
File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 695, in _handle_entity_call
await result
File "/usr/src/homeassistant/homeassistant/components/light/__init__.py", line 417, in async_handle_light_on_service
await light.async_turn_on(**filter_turn_on_params(light, params))
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 785, in async_turn_on
await self.hass.async_add_executor_job(ft.partial(self.turn_on, **kwargs))
File "/usr/local/lib/python3.8/concurrent/futures/thread.py", line 57, in run
File "/usr/src/homeassistant/homeassistant/components/flux_led/light.py", line 349, in turn_on
self._bulb.setRgbw(*tuple(rgb), w=white, brightness=brightness)
File "/usr/local/lib/python3.8/site-packages/flux_led/__main__.py", line 869, in setRgbw
raise Exception
Exception
