valde
(Carlos)
March 17, 2019, 2:40am
1
Hi!
I’m triying to configure a Magic Home RGBW led controller (esp8285 version)
I’ve manage to assign the 4 channels correctly using generic module type and this configuration
But I cant turn on and off or change the color from Home Assistant. The light card says the light its not available.
My configuration.yaml:
light:
- platform: flux_led
devices:
10.10.0.152:
mode: "rgbw"
The mosquitto log says:
1552789919: |-- mosquitto_auth_acl_check(..., client id not available, mqttuser, tele/magichome/STATE, MOSQ_ACL_WRITE)
1552789919: |-- aclcheck(mqttuser, tele/magichome/STATE, 2) CACHEDAUTH: 0
Any idea?
nickrout
(Nick Rout)
March 17, 2019, 4:58am
2
Is that a tasmota config page in your first picture? If so I don’t think that flux-led is the right component once you have flashed it.
wills106
(Will)
March 17, 2019, 6:59am
3
Have a look at the Tasmota Wiki for setting your devices up either as auto discovery or manual configuration.
You will need to change every instance of light1 to what ever MQTT Topic setup on your device. It looks like you may have just called it magichome. So instead of "cmnd/light1/POWER"
you will want "cmnd/magichome/POWER"
instead etc
Alternative firmware for ESP8266 with easy configuration using webUI, OTA updates, automation using timers or rules, expandability and entirely local control over MQTT, HTTP, Serial or KNX. Full do...
valde
(Carlos)
March 17, 2019, 9:42am
4
I didn’t even think it would work as is and I flashed as it arrive
Thanks a lot, now its working flawless
