Magic Home, Lednet Led Bar v4
Hi guys,
I’ve installed this led bar behind my tv, and i can control the led bar without any issue from the Magic Home App, but if i add it to HA with the configuration posted below, i can only control the on off, without control for brightness and color. i’ve tried all the different options but they made only the bar crash and restart itself.
Any onf you have any luck with the V4 of the lednet led bar?
Here is the configuration that im using:
light:
  - platform: flux_led
    devices:
      192.168.1.90:
        protocol: 'ledenet'
        mode: "rgb"
Were you able to resolve the issue? I just got mine and I am experiencing the same issue
I am in the process of updating this integration which might help. If you want to test the work in progress you can grab the latest files from https://github.com/home-assistant/core/pull/44333 and drop them in as a custom component.
It is working for me with full control on my newer lights.
