Ahhh so it is tileboard you need help with, I suggest you do to the tileboard page TileBoard - New dashboard for Homeassistant
How did you install home assistant?
Home assistant is running directly on the raspberry pi.
Tried getting help there but nothing so far.
Iām using a new installed home assistant. so really nothing in it so far.
Added the TileBoard changed the config.js and thatās where Iām stuck.
Then I think the directory will be /config not /root/config
Tried itā¦
same issue.
Am I correct that the only thing u really need to do is to add the TileBoard folder and then edit the config.js?
Please go to the tileboard thread. This is not the place. I canāt see any questions from you there (but it is long!)
Would you like to share your code?
Iāve now published the source at https://github.com/lukas-hetzenecker/smart-mirror
But unfortunately the documentation is severely lacking (read: non-existent), so Iām not sure it will be really useful
For everyoneās clarity, this source code Lukas posted isnāt what my integration uses. My project doesnāt require any external projects to work since itās all using Home Assistant addons.
Nice repo though
Hi Darren,
Many thanks for the great instructions been looking for options to integrate my smart mirror into home assistant.
I seem to have a problem with the state script though. On and off scripts work fine but the state script shows:
state.sh: 3: state.sh: [[state: not found
off
This shows the same no matter what script has been run at the time.
Any ideas?
Cheers
Michael
