📹 Magic Snapshot / Video sequence ===> Telegram
Magic Snapshot blueprint. V2.02
Hello community, here one of the blueprint i use for few month now to get some “animated” snapshot of my camera
The blueprint let you choose
The triggering entity ( binary)
The Camera / video stream
Animated Or fixed image.
The delay to capture it.
The Id of the telegram you want to send it to.
The content of your message.
Edit 22.03.2026
Added a conditional switch
Replaced a deprecated “target” by “chat_id” for the telegram integration.
############## IMPORTANT ###################
First you need to add some line to your
configuration.yaml
shell_command:
  process_alert_video: "ffmpeg -y -i /config/www/snapshots/temp_raw.mp4 -vf 'fps=2' -c:v libx264 -preset ultrafast -an /config/www/snapshots/alert_final.mp4"
Then , Magic thing recommended by Forum Sir :wink:
Do now forget to reboot your Home assistant after that. (Completely, not only the yaml file reload. You lazy little thing…
For the purist, here’s the code:
blueprint:
  name: "Snapshot avec Délai, Script et Condition (Vidéo/Snapshot)"
  description: "Capture une séquence/image, notifie, exécute un script et évalue un interrupteur global optionnel."
  domain: automation
  input:
    condition_switch:
      name: "Interrupteur d'activation (Optionnel)"
      description: "Entité input_boolean. Si définie et sur 'off', annule l'exécution de l'alerte. Laissez vide pour ignorer."
      default: ""
      selector:
        entity:
          domain: input_boolean
    target_script:
      name: "Script (Optionnel)"
      description: "Sélectionnez un script à exécuter au déclenchement. Laissez vide pour l'ignorer."
      default: ""
      selector:
        entity:
          domain: script
    delay_capture:
      name: "Délai avant capture"
      description: "Temps d'attente (en secondes) avant de déclencher l'enregistrement ou le snapshot."
      default: 0
      selector:
        number:
          min: 0
          max: 15
          step: 0.5
          mode: slider
    capture_mode:
      name: "Mode de capture"
      description: "Format du média à capturer et envoyer."
      default: "video"
      selector:
        select:
          options:
            - label: "Séquence animée"
              value: "video"
            - label: "Snapshot (Image fixe)"
              value: "snapshot"
    motion_sensor:
      description: "L'entité binaire qui déclenche l'alerte."
      selector:
        entity:
          domain: binary_sensor
    camera_entity:
      description: "La caméra source."
      selector:
        entity:
          domain: camera
    record_duration:
      name: "Durée (séquence uniquement)"
      description: "Temps d'enregistrement en secondes."
      default: 3
      selector:
        number:
          min: 2
          max: 8
          step: 1
          mode: slider
    telegram_chat_id:
      name: "ID Chat Telegram"
      description: "L'identifiant numérique de la discussion."
      selector:
        text: {}
    notify_title:
      name: "Titre de la notification"
      description: "En-tĂŞte du message Telegram (sera mis en gras)."
      default: "Alerte"
      selector:
        text: {}
    notify_text:
      name: "Texte de la notification"
      description: "Texte d'accompagnement sous le titre."
      default: "Ă  {{ now().strftime('%H:%M') }}, le {{ now().strftime('%d.%m.%Y') }}."
      selector:
        text:
          multiline: true
variables:
  mode: !input capture_mode
  var_title: !input notify_title
  var_text: !input notify_text
  var_script: !input target_script
  var_condition: !input condition_switch
  - platform: state
    entity_id: !input motion_sensor
    to: "on"
  # 0. Évaluation de la condition maître (Bloquante si 'off')
  - condition: template
    value_template: "{{ var_condition | length == 0 or is_state(var_condition, 'on') }}"
  # 1. Exécution du script optionnel (Immédiat)
  - if:
        value_template: "{{ var_script | length > 0 }}"
    then:
      - action: script.turn_on
          entity_id: "{{ var_script }}"
  # 2. Temporisation avant l'action de capture
  - delay:
      seconds: !input delay_capture
  # 3. Routage vers le mode sélectionné
  - choose:
      # Branche 1 : Mode Vidéo
      - conditions:
            value_template: "{{ mode == 'video' }}"
        sequence:
          - action: camera.record
              entity_id: !input camera_entity
              filename: "/config/www/snapshots/temp_raw.mp4"
              duration: !input record_duration
              lookback: 0
          - action: shell_command.process_alert_video
          - action: telegram_bot.send_video
              chat_id: !input telegram_chat_id
              file: "/config/www/snapshots/alert_final.mp4"
              caption: "<b>{{ var_title }}</b>\n{{ var_text }}"
              parse_mode: "html"
      # Branche 2 : Mode Snapshot
      - conditions:
            value_template: "{{ mode == 'snapshot' }}"
        sequence:
          - action: camera.snapshot
              filename: "/config/www/snapshots/alert_snapshot.jpg"
          - action: telegram_bot.send_photo
              file: "/config/www/snapshots/alert_snapshot.jpg"
              parse_mode: "html"
Currently only compatible with Telegram because of the video sequence, but could be adapted to another service.
Hello Adefx,
Thanks for contributing to the community with a new Blueprint.
I have a suggestion for you. Many people who are not familiar with directory structures will have problems installing this without the Home Assistant MY tools.
Adding a MY link for this Blueprint to your top post would help them a lot.
Here is the link to make that.
Create a link – My Home Assistant
Merci, I’ve grabbed it—very handy blueprint.
I simply added a “File name” field.
Hello @nissa , i’ve improved it quite a lot, here’s the beta version, running smoothly for 4 week here . Since it’a beta version, it’ still in french but i may guess it won’t disturb you :wink:
give me you feedback, there is a lot more features like
  • New telegram compatible gif sequence
  • Script activation switch ( optional )
  • Some additional script
  • Cooldown delay ( to prevent multiple automation flood)
blueprint:
  name: "Snapshot avec Délai, Script, Condition et Cooldown"
  description: "Capture une séquence/image, notifie, exécute un script, évalue un interrupteur global et intègre un anti-spam."
  domain: automation
  input:
    condition_switch:
      default: ""
      selector:
        entity:
    target_script:
      default: ""
      selector:
        entity:
          domain: script
    delay_capture:
      default: 0
      selector:
        number:
          min: 0
          max: 15
          step: 0.5
          mode: slider
    cooldown_time:
      name: "Délai anti-spam (Cooldown)"
      description: "Temps mort (en secondes) après exécution avant d'autoriser une nouvelle notification."
      default: 30
      selector:
        number:
          min: 0
          max: 300
          step: 5
          mode: slider
    capture_mode:
      default: "video"
      selector:
        select:
          options:
              value: "video"
              value: "snapshot"
    motion_sensor:
      selector:
        entity:
          domain:
            - binary_sensor
            - switch
    camera_entity:
      selector:
        entity:
          domain: camera
    record_duration:
      default: 3
      selector:
        number:
          min: 2
          max: 8
          step: 1
          mode: slider
    telegram_chat_id:
      selector:
        text: {}
    notify_title:
      default: "Alerte"
      selector:
        text: {}
    notify_text:
      selector:
        text:
          multiline: true
# Restriction d'exécution pour activer l'anti-spam
mode: single
variables:
  - platform: state
    to: "on"
  - if:
    then:
  - delay:
  - choose:
      - conditions:
        sequence:
              lookback: 0
              parse_mode: "html"
      - conditions:
        sequence:
              parse_mode: "html"
  # 4. Verrou temporel (Cooldown)
  - delay:
      seconds: !input cooldown_time
