Magichome devices work PERFECT with homeassistant (reflash this code with ESPHOME)
It is actually five channels: RGB, warm white and cold white.
I have flashed it with Esphome and it works great.
Great thanks for that. I now just need to look into nabu cassa and if it can be controlled via voice. Before I go flashing them I currently have 12 around the house and garden.
Thanks to this guide I have flashed one of my controllers as shown in the 1st pictures. I can change colour, brightness , on/off with the colour wheel but how do I change the colour or even get an effect like flash with an automation, the only thing I can see is turn on , off or toggle. This device controls the colour of my alarm keypad, and I would like it to be red in a fault condition and flash between red and blue in alarm, and also dim at night, ect. any pointers would be greatly welcomed.
I only have RGB led connected to this one, and it works with flux_led…no flash needed:
light:
- platform: flux_led
    devices:
      192.168.1.104:
        mode: rgb
..But i do need help in configuring a 230V switch!(https://ae01.alicdn.com/kf/H3527e55900ed4868b7923ae054e37d1dT.jpg)
Is this the one you purchased?
It’s the only one from that seller that is RGB, I don’t have a need for the white channel.
I suppose the RGBW controller would work for RGB LEDs, would just not use the white channel pin?
I just did 3 of these last week. Works great!
Care to share a link to the ones you got? I need to order a few and would rather not have to deal with a non ESP82 device.
I got them from the Zinuo store on AliExpress. Turns out I ordered them a year ago. Took forever to receive them, and I just got around to flashing them last week. So, no guarantee it’s still the same. Mine had no remotes, not sure if that’s significant.
Also, the link in my order comes up unavailable.
This was also 1 year ago but the link is still valid. Ymmv…
€ 3,38 30% Off | Magic Home DC5V 12V 24V Bluetooth-compatible Wireless WiFi Controller,RGB/RGBW IR RF LED Controller for WS2811 WS2812 led strip
Clearly an improvement in size and looks from my original:
Does anyone have a good source for these that are flashable and has purchased in the last month on Amazon or Ali ?
Mine is more different :
try GitHub - openshwprojects/OpenBK7231T_App: Open source firmware (Tasmota/Esphome replacement) for BK7231T, BK7231N, BL2028N, T34, XR809, W800/W801, W600/W601 and BL602
Will be working on this controller tomorrow morning, let’s see if I can flash it with ESPhome.
any ideas?
are you able to share your config.yaml?
Sure! Here it is!
esphome:
  platform: ESP8266
  board: esp8285
wifi:
  ssid: "wifi_name"
  password: "wifi_password"
  ap:
    ssid: "kok bank"
    password: "ap_password"
captive_portal:
# Enable logging
logger:
# Enable Home Assistant API
api:
  password: "api_password"
ota:
  password: "ota_password"
light:
  - platform: rgbww
    red: pwm_r
    green: pwm_g
    blue: pwm_b
    cold_white: pwm_cw
    warm_white: pwm_ww
    cold_white_color_temperature: 6536 K
    warm_white_color_temperature: 2000 K
output:
  - platform: esp8266_pwm
    pin: GPIO12
    frequency: 1000 Hz
    max_power: 100%
    pin: GPIO5
    frequency: 1000 Hz
    max_power: 100%
    pin: GPIO13
    frequency: 1000 Hz
    max_power: 100%
    pin: GPIO15
    frequency: 1000 Hz
    max_power: 100%
    pin: GPIO5
    frequency: 1000 Hz
    max_power: 100%
I see that both pwm_g and pwm_cw are on GPIO5, is this correct?
  • platform: esp8266_pwm
    pin: GPIO5
    frequency: 1000 Hz
    max_power: 100%
    pin: GPIO5
    frequency: 1000 Hz
    max_power: 100%
Good catch! I only used RGB so never noticed the error.
I might have time to look at this later this week.
So there were three errors in the code, wrong pins for R, G and CW. New code:
output:
    pin: GPIO14
    frequency: 1000 Hz
    max_power: 100%
    pin: GPIO12
    frequency: 1000 Hz
    max_power: 100%
    pin: GPIO13
    frequency: 1000 Hz
    max_power: 100%
    pin: GPIO15
    frequency: 1000 Hz
    max_power: 100%
    pin: GPIO5
    frequency: 1000 Hz
    max_power: 100%
I havn’t used this in quite a while.
