I have had one setup for a while now and it’s been perfect. Just got anither wifi rgb controller off Amazon to convert a basic ir strip to wifi. I solders a 4 female pin that I took off an old unit and was color coded. It turned on fine, and was able to set it up. When I try to change colors the strip shows something different than what the magichome and HA shows. Before I setup wifi on it it was cycling red green blue so I figured it was all good. Any ideas what the issue is?
