Hey, I have a magiclight/flux led bulb under the illume brand. I had previously had it installed through the config, it has dropped offline and I need to re add it to home assistant. According to the fluxled documentation I should be able to find it now in integrations however I am unable to find anything. Any ideas?
The documentation mentioned the configuration over the UI before. But that wasn’t correct because for now the configuration is only possible woth yaml and the seems the documentation was reverted.
But there are some changes in the work for reworking the component which among other things makes the configuration over the UI possible.
