Mail and Packages: Custom component for UPS, FEDEX, and USPS
Try the following modifications:
- alias: "Mail Notif - Mail Delieveries"
  initial_state: 'on'
  #Trigger if mail or packages get updated
    - platform: state
      entity_id: sensor.mail_usps_mail
    - platform: state
      entity_id: sensor.mail_usps_delivering
  #send only if mail or packages are more than 0
  condition:
    - condition: or
      conditions:
        - condition: template
          value_template: "{{ (as_timestamp(now()) - as_timestamp(states.sensor.mail_usps_mail.last_changed)) < 15 }}"
          value_template: "{{ (as_timestamp(now()) - as_timestamp(states.sensor.mail_usps_delivering.last_changed)) < 15 }}"
    - service: notify.YOUR_NOTIFY_METHOD
      data_template:
        title: "*Today's Mail and Packages*"
        message: "{{ states('sensor.mail_deliveries_message')}}"
        message: "Here is the mail"
          document:
            file: "/<config path>/images/mail_and_packages/mail_today.gif"
Note that I haven’t tested these modifications yet myself, so YMMV.
I’m not getting spammed anymore, so it’s probably working. Won’t really know until I receive an update I think. Thank you!
I’ve updated the wiki to reflect the change, I’ve tested it myself, works great.
So I updated to the latest beta version and noticed that all my entities were unavailable. After trying to set it up again I keep getting at an error on step 2 that says “User input malformed.” I haven’t changed anything for a while now and I can’t get past this step. What am I doing wrong?
A new option was added, go through the “options” and complete them, will fix you right up.
That’s exactly how I did it since the old way wasn’t working at all for me. I even tried to reinstall it and still no go.
Can you paste the error from the log?
Would this be it?
Logger: homeassistant.components.sensor
Source: custom_components/mail_and_packages/sensor.py:130
Integration: Sensor (documentation, issues)
First occurred: 8:25:00 AM (1 occurrences)
Last logged: 8:25:00 AM
Error while setting up mail_and_packages platform for sensor
Traceback (most recent call last): File “/usr/src/homeassistant/homeassistant/helpers/entity_platform.py”, line 178, in _async_setup_platform await asyncio.wait_for(asyncio.shield(task), SLOW_SETUP_MAX_WAIT) File “/usr/local/lib/python3.7/asyncio/tasks.py”, line 442, in wait_for return fut.result() File “/config/custom_components/mail_and_packages/sensor.py”, line 130, in async_setup_entry CONF_GENERATE_MP4: entry.data[CONF_GENERATE_MP4], KeyError: ‘generate_mp4’
Yes, try enabling the “Generate MP4” option in step 2 of the configuration. Then go back and disable it. Unless you want it on that is.
This worked, I was able to get past the setup finally but entities still show unavailable after reboot. But the gif shows now.
Source: custom_components/mail_and_packages/sensor.py:731
First occurred: 9:21:09 AM (2 occurrences)
Last logged: 9:50:07 AM
Traceback (most recent call last): File “/usr/src/homeassistant/homeassistant/helpers/entity_platform.py”, line 178, in _async_setup_platform await asyncio.wait_for(asyncio.shield(task), SLOW_SETUP_MAX_WAIT) File “/usr/local/lib/python3.7/asyncio/tasks.py”, line 442, in wait_for return fut.result() File “/config/custom_components/mail_and_packages/sensor.py”, line 137, in async_setup_entry sensors.append(PackagesSensor(data, variable)) File “/config/custom_components/mail_and_packages/sensor.py”, line 268, in init self.update() File “/config/custom_components/mail_and_packages/sensor.py”, line 316, in update self.data.update() File “/usr/src/homeassistant/homeassistant/util/init.py”, line 239, in wrapper result = method(*args, **kwargs) File “/config/custom_components/mail_and_packages/sensor.py”, line 197, in update count[sensor] = get_items(account, “count”) File “/config/custom_components/mail_and_packages/sensor.py”, line 731, in get_items orderNum.append(found[0]) IndexError: list index out of range
Exactly the same issue for me. I’ve just downloaded the component for the first time. Setup completes OK, but I have no entities and the log has the same error.
Hotfix coming up
@WhimsySpoon and @Jeremy_S give b10 a shot
Amazing work! I installed b10 via HACS, restarted HA and sixteen entities were automatically created (I didn’t need to reinstall the integration).
Thank you for resolving this so quickly.
That did the trick. Thank you!
:tada: 0.2.1 is released :tada:
Breaking change
You will need to run through the options and complete them to update the configuration due to a new feature.
What’s New
  • Added more Amazon TLDs for searching, currently: .com, .co.uk, .ca #125
  • Added a limited CA Post search since I couldn’t find an “Out for delivery” email template so there’s only a ‘delivered’ sensor at this time. #124
  • Fix filter_text function to detect USPS “out for delivery” emails better #92
  • Applied fix to Amazon email parser (should no longer error out)
  • Import of quopri
  • Amazon sensor regression fix
  • sync info.md with master
  • International Amazon fix
  • Added support for Amazon India in const.py
  • Previous code was unintentionally parsing all Amazon emails, instead of shipping confirmation mails. Implemented proposal in this comment: https://github.com/moralmunky/Home-Assistant-Mail-And-Packages/issues/125#issuecomment-643792745
  • Adjust Amazon sensor to pull order number from subject with regex
  • Simplified code to remove addition subject line parsing
  • Clean up some commented lines
  • Translation file updates #145
  • Add python-resize-image requirement #32
  • New image resize function #32
  • Translation URLs fixed
  • Add ability to generate mp4 file (requires ffmpeg) for use as a camera source #138
Is there a usable way to have the mp4 act as a stream that can be usable in homekit?
I tried changing my camera from local_file to ffmpeg but I get a demuxing DTS error. Curious if you’ve labbed out a working config for that?
I’ve tried a couple things and haven’t figured out a way to stream. It may be a limitation of home assistant stream. I think it only supports a certain steam type.
that’s a bummer. I wonder if there are flags that can be fed to ffmpeg to nudge it into working.
Getting this error. Had to re-do the integration after the recent changes, and since then have been getting this error in my logs. I have no use for this particular entity. Any help to remove or at least stop it from generating the error?
Unknown sensor type: capost_delivering
7:56:34 PM – Mail and Packages (ERROR)
