Are you running the beta?
Edit: Found the cause, pushing b3 out the door.
Wow, that was fast
Looks good on reboot after update, Iāll check back in as I monitor the logs.
Thanks @firstof9
How does the camera image get generated? I mustāve missed a step somewhere.
Hello
I keep getting the following error when I try to sent up my mail server? I have tried both my aol and gmail account and nothing has worked. I probably just dont know what I am doing, so any help is appreciated.
āUnable to connect or login to the mail server. Please check the log for details.ā - not sure what log it wants me to look at.
Thank
You must have a USPS informed delivery email for the current day with images and the path you gave in the settings for the image must be valid and writable.
Pleas see the gmail section of the wiki. An app password may be required.
The home-assistant.log
in your configuration directory ie: /config/home-assistant.log
Thank you the app password is what I needed to do
Iām having trouble getting the Custom Lovelace Card set up. The card config code in the Card instructions doesnāt seem to be formatted correctly (I had to remove the dash and all the tabs), so my code now looks like this:
That got the initial card working with only the camera entity. I tried adding the sensors in the config and it turned the card into a bit of a mess. I donāt have 2 packages in transit, but I do have two pieces of mail from USPS, for example. One of those sensors is also showing as just a number off in the left margin.
Is there some additional configuration I need to do for the card that isnāt listed on the readme?
Just wanted to say thanks to moralmunky for the time building this. Got it installed and set upā¦so far running perfectly. For firstof9, thanks for helping in this forum to back up moralmunky, the advice youāve given others was incredibly helpful as were the icons. Still playing with it for what I want to see, but itās working great.
I really appreciate everything on here.
@jsaturday, From your screen shot, each field labeled entity should be showing a label for what sensor should be chosen. Maybe your browser cache needs to be emptied?
At any rate, the text configuration that is generated from the card config UI should be something like this:
camera: false
camera_entity: camera.mail_usps
deliveries_message: sensor.mail_deliveries_message
details: true
fedex_packages: sensor.mail_fedex_packages
gif: /local/mail_and_packages/mail_today.gif
image: true
packages_delivered: sensor.mail_packages_delivered
packages_in_transit: sensor.mail_packages_in_transit
type: 'custom:mail-and-packages-card'
updated: sensor.mail_updated
ups_packages: sensor.mail_ups_packages
uspsMail: sensor.mail_usps_mail
usps_mail: sensor.mail_usps_mail
usps_packages: sensor.mail_usps_packages
@jrogers, I may have got it going but @firstof9 deserves huge kudos. They have kept it alive and provided great contributions to my mushed up code
Strange, clearing the cache seems to have done the trick! I assume the āmail deliveries messageā is from one of the example custom sensors in the readme?
Wow after my family got frustrated that Iām the only one who can see the email coming for the day because USPS doesnāt allow multiple accounts to receive the emails, wow that would be so hard, I searched and found this. Looks like it will show everyone using HA what mail is coming for the day and the pictures. Does this work on the iOS mobile app? Or more specifically work without cutting off a lot?
So I did the following on 0.112.4:
and thatās where I got stuck. No option for Mail and Packages.
Note only thing in my logs which is obviously supposed to be there is:
2020-07-09 08:29:30 WARNING (MainThread) [homeassistant.loader] You are using a custom integration for mail_and_packages which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant.
EDIT: Based on some suggestions I clicked on my profile, it was set to English. Changed it to Dansk and then back to English. No save buttons I could see. Went back and no joy.
EDIT: SOLVED. Looks like clearing the browser cache helped. Tried with IE and Edge before doing so but couldnāt even get the login screen to come up in those browsers.
Usual culprit is the cache. Glad you got it sorted.
Enjoy!
Yep, how do I get the custom:mail-and-packages-card assuming thatās the best way to see the USPS images of the mail coming?
Also is there anything in the HA logs that shows it triggered a mail check? I know I set it to only check ever 60 minutes but assuming it will create that .homeassistant folder for me as part of the image path ā/home/homeassistant/.homeassistant/images/mail_and_packages/ā value and I donāt have to create it manually, I havenāt seen anything trigger in the logs or anything.
Thereās a sensor sensor.mail_updated
that tells you the timestamp it last checked.
This card is on @moralmunkyās github, check his repos.
If youāre using hassOS or the docker container your path should be something like: /config/images/mail_and_packages/
Thanks, Iām guessing that translates to
/usr/share/hassio/homeassistant/www/images
and mail_and_packages would be under that.
JR
