I’m back, sorry. Everything is still work; however, in the log I’m getting this:
(SyncWorker_1) [homeassistant.components.local_file.camera] Could not read camera mail_usps image from file: /config/www/mail_and_packages/mail_today.gif
The last one yesterday was about 6:30pm and then I got another at about 9:00 this morning. Not another since. Not sure this is a sign I have other problems or if this is normal.
This is the camera component you set up outside the integration. Either the path to the image file is incorrect, you have a permissions issue, or you have the random image file name turned on in the integration.
The integration only deals with the creation of the file and where the file is saved. If the integration is saving a new file as expected after the USPS informed delivery email is received and the integration scans your email box, you may want to search the forum for the Home Assistants camera component errors.
It could perhaps be when the file is in process of being saved and therefore the component cannot read yet?
I tried to install it as a custom repository using HACS pretty much the same way I installed the integration and other custom cards I did change the category to Lovelace. I posted a jpeg of the how I tried to load it previously on this thread. I entered the url both with and without https:// with the same results.
Is there another place besides where you go when you click on the link you provided because I did read through it but saw no installation instructions for the card, just the Lovelace GUI set up which I did do. I’ve not used github much so I may be missing a link to the instructions. I thought maybe it was installed with the integration but I don’t have the JavaScript module on my system so I get custom element does not exist. So I’m guessing Since it’s not in HACS I need to manually download and install the code.
Didn’t notice this until I looked closer, need to tweak that. The automation only triggers with the mail, so if you get packages but no mail for any given day it wouldn’t trigger.
I had (have) the same issue. Yes, I understand that the code is not in HACS. HACS has an option for you to load custom repositories. I can do it with the main component, but not with the card. HACS does not like “something” about the card repository structure.
The advantage of “adding” it to HACS is that HACS will then notify me that there is an updated version vs. having to keep checking ghithub and then manually pull down the new code.
Just updated to latest version and now all the DHL sensors are not available; not a loss as I rarely get package deliveries from them. Have these sensors been removed?
I did get an email from amazon this morning for delivery tomorrow; is this supposed to show today? The sensor is showing 0 so does the sensor only reflected it if it is out for delivery?
