OK all fixed. Thanks. Now I must be blind because I still can’t seem to find the install procedures for the custom card that goes with this. And finally, though I got an email today about an Amazon package delivery for tomorrow, am I correct that the sensor will only show it on the day of delivery like packages from other sources?
Started reading the HACS doc and there was mention of the repo name and file name being the same and then got pulled away and haven’t revisited it.
I think I also have to update the JSON file to match the name change.
In the meantime, people interested can simply download the two JS files. In this case all HACS is doing is downloading the two JS files correct? You still have to manually add the references to the Lovelace resources.
I did a manual install and got the card working but It doesn’t look like it Amazon packages are being handled properly. The summary is showing two packages in transit; however, both were separately delivered several hours ago. But I’m seeing 0 deliveries and there doesn’t seem to be a place to put the number of Amazon packages delivered. Since most of my packages come from Amazon, I would like to see them broken out more like the others.
The summary sensor you create is separate from the integration and the custom card, however the numbers it pulls in are from the integration.
Amazon is complicated because they use their own contractors to deliver (and do not send emails to confirm delivery) and they also use USPS and UPS. This means two things:
Amazon Contractor: You get the email that says when the package should arrive, there is no day of in transit email and there is no delivery confirmation email. In this case the count will hang out in the email sensor until it is out of the sensors 3 day search scope. @firstof9 am I reading the code right?
Amason outside carrier (like USPS or UPS): You get that same email saying when the package should arrive. This, again, shows in the Amazon sensor until it is out of search scope. You also will get a count through which ever carrier they send the package through. If it was USPS, for example, you would see a count in USPS through in transit and delivery.
So when you say you are seeing it indicate 2 packages in transit, it depends on how Amazon sent them to you and if you are getting delivery notifications from the carrier. @firstof9, I see the constant shippers doesn’t include Amazon. So I @ZombiEd is talking about the cumulative in transit sensor, it should have picked up a notification from “capost”, “dhl”, “fedex”, “ups”, or “usps” and hasn’t received (or didn’t sign up for) the delivery confirmation emails, correct?
I suppose some of this Amazon explanation should go into the wiki
I agree Amazon can be complicated but maybe I can help. The two packages I got today were delivered by Amazon and not one of the carriers. For each one I got a delivery notification yesterday with a subject:
They ask for feedback on the delivery and include a photo of the package left by the front door. They state:
Track your next shipment with Alexa, turn on delivery notification.
The first package arrived at 1:30 and the second at 3:14. I just took a snippet of the the card which at 10:36 shows this:
If the packages are delivered by UPS, USPS, or FedEx, I don’t get a delivery notification from Amazon. But the fact that I got two delivery notices today, implies you can turn them on and they should be looked for to change them from in transit to delivered. Included in both In transit amounts and to the total deliveries if you find delivery notification.
I really like what you both have done, and please don’t consider my posts as complaints. I was a programmer many moons ago and understand requirement creep. Since I get packages regularly, I will keep notes on notices and provide what I can should you need it.
