You should like b11, even has the image being pulled down like you requested
I just set this up and so far so good, except I see on the Amazon Packages sensor it detected atleast 3 of my orders since the order number is listed, but still says 0 packages. Did I screw something up?
Also whats the intended use for the images? I canāt find a way to display them on the Overview page because the file names change. Can you make a slideshow and have it target the folder?
Please see the wiki for examples of the images use.
Your package counter will only tick up on the day of the delivery. Hereās how it works.
Thanks! 10char
oh and as far as the custom lovelace cards config goes, if I use the editor built into the interface, the examples donāt work, everything in quotes is the wrong syntax, no current functioning cards use that. What am I missing here?
The camera stuff is an automation
and a camera
setup for your configuration.yaml
Ok so I guess Iām confused because the instructions say to use the Lovelace editor
Scroll up to the camera section.
sorry, iām probably retarded. I tried adding the example via the lovelace editor and to the configuration.yaml and neither worked.
I scrolled up to the camera section, I have already done that and havenāt had any issues with that part, so iām not sure what you want me to see there. Again, sorry im retarded.
Oh, once you have the camera bits added in the configuration.yaml, youāll need to restart HA if you havenāt already. Then you should be able to do the card bits. Which card example are you trying to use?
yes, the camera was added a long time ago, again I have no issues with the camera portion. I donāt know where to put the code for the custom cards. It doesnāt work in the lovelace editor, it doesnāt work in the configuration.yaml. Not sure it matters, but Im trying to add either of the Vertical Stack Custom Card code
Are there any visual signs of it not working? Red background with text where the card should be? Is the vertical stack custom card installed correctly? Is there indentation issues when copying the yaml in?
im actually trying to do this card now https://github.com/moralmunky/Home-Assistant-Mail-And-Packages-Custom-Card#home-assistant-mail-and-packages-custom-card
I was able to add the lovelace resource fine (although I have no clue what the resource for the js is pointing to because that location doesnāt exist in the file system afaik) but when I add the card i get red background card āCustom element doesnāt exist: mail-and-packages-card.
type: ācustom:mail-and-packages-cardā
updated: sensor.mail_updated
details: true
image: falseā
Iām assuming I need to install mail-and-packages-card? Didnāt see that in the example
So it sounds like you having issues getting through the installation of the required JS files for custom cards. The string ālocalā is the home assistances internal way of pointing to the www directory. Find /YOUR CONFIG PATH/www/, you may need to create it but I think itās a default folder when HA in installed. Put custom card resources here and construct the url in the settings to how ever you store the JS files under www. You may also need to empty your cache and refresh the page before the resources are loaded.
I just updated the JSON. The Mail and Packages Custom Card repository loads in HACS. I didnāt test the install.
Iāve added the card, and Iām getting this error
TypeError: Failed to fetch dynamically imported module: https://MYHAURL/hacsfiles/Home-Assistant-Mail-And-Packages-Custom-Card/mail-and-packages-card-editor.js
The card looks āokā ,but I cannot save after adding to lovelace
EDIT: I could only find one refrence to this error in the community. It did mention using a proxy server. I am using a proxy server. Maybe thatās it?
EDIT2: I tried using local IP and also tried firefox, etc. Same issue
Not sure if this is it, but it looks like there needs to be a bit of a code update as well.
2020-07-24 14:21:13 ERROR (MainThread) [hacs] Tried to serve up ā/home/homeassistant/.homeassistant/www/community/Home-Assistant-Mail-And-Packages-Custom-Card/mail-and-packages-card-editor.jsā but it does not exist
File is now named - Home-Assistant-Mail-And-Packages-Custom-Card-editor.js
