Looks like the refresh did it, I found it, and it’s installing, thanks!
So weird, I rebooted the thing 5 times, and all I needed to do was a refresh xD
So this has been working great for me until now. Not sure when it happened but all my entities are unavailable now. i went through the setup again 4 times now. That usually fixes it but not this time. Here’s the log.
## Log Details (ERROR)
Logger: homeassistant.components.sensor
Source: custom_components/mail_and_packages/sensor.py:878
Integration: Sensor ([documentation](https://www.home-assistant.io/integrations/sensor), [issues](https://github.com/home-assistant/home-assistant/issues?q=is%3Aissue+is%3Aopen+label%3A%22integration%3A+sensor%22))
First occurred: 3:02:49 PM (3 occurrences)
Last logged: 3:15:19 PM
Error while setting up mail_and_packages platform for sensor
File "/usr/src/homeassistant/homeassistant/helpers/entity_platform.py", line 179, in _async_setup_platform
await asyncio.wait_for(asyncio.shield(task), SLOW_SETUP_MAX_WAIT)
File "/usr/local/lib/python3.8/asyncio/tasks.py", line 483, in wait_for
return fut.result()
File "/config/custom_components/mail_and_packages/sensor.py", line 71, in async_setup_entry
sensors.append(PackagesSensor(data, variable))
File "/config/custom_components/mail_and_packages/sensor.py", line 198, in __init__
self.update()
File "/config/custom_components/mail_and_packages/sensor.py", line 254, in update
self.data.update()
File "/usr/src/homeassistant/homeassistant/util/__init__.py", line 239, in wrapper
result = method(*args, **kwargs)
File "/config/custom_components/mail_and_packages/sensor.py", line 139, in update
count[sensor] = get_items(account, ATTR_COUNT)
File "/config/custom_components/mail_and_packages/sensor.py", line 878, in get_items
if len(found[0]) > 0 and found[0] not in orderNum:
TypeError: 'NoneType' object is not subscriptable
What version of the component are you running?
Looks like 0.2.2-b15
Give b16 a run should fix you right up.
That didn’t seem to fix it. Log looks the same as well
Forgot to mention I tried going through the setup again as well.
Don’t forget to restart Home Assistant after you update.
Did that too lol
I’ll try again
While fixing that Amazon sensor there was another fix, it’s now in b17.
Just switched from standard branch. B17 not working:
return fut.result()
self.update()
self.data.update()
File "/config/custom_components/mail_and_packages/sensor.py", line 152, in update
info = get_count(account, sensor, True)
File "/config/custom_components/mail_and_packages/sensor.py", line 654, in get_count
if len(tracking) < len(count):
TypeError: object of type 'int' has no len()
B18 is already out to fix that
Ya b18 fixed that, don’t code without copious amounts of caffeine in your system.
Just updated to b18 and seeing this in my log:
2020-08-08 19:36:03 ERROR (MainThread) [homeassistant.components.websocket_api.http.connection.140235629336368] Unable to serialize to JSON. Bad data found at $.event(event: state_changed).data.new_state(state: sensor.mail_amazon_packages).attributes.order[0]=<re.Match object; span=(23, 43), match='#XXXXXXXXXX'>(<class 're.Match'>, $.event(event: state_changed).data.new_state(state: sensor.mail_amazon_packages).attributes.order[1]=<re.Match object; span=(23, 43), match='#XXXXXXXXX'>(<class 're.Match'>
Causing HASS to crash loading unless I unload the Amazon sensor.
Thanks. B18 hangs my homeassistant, it won’t fully restart . Homeassistant starts fine on release version.
2020-08-08 19:28:35 ERROR (MainThread) [homeassistant.components.websocket_api.http.connection.2940602496] Unable to serialize to JSON. Bad data found at $.event(event: state_changed).data.new_state(state: sensor.mail_amazon_packages_delivered).attributes.order[0]=<re.Match object; span=(22, 42), match='#XXX'>(<class 're.Match'>, $.event(event: state_changed).data.new_state(state: sensor.mail_amazon_packages_delivered).attributes.order[1]=<re.Match object; span=(22, 42), match='#XXX'>(<class 're.Match'>
2020-08-08 19:28:35 ERROR (MainThread) [homeassistant.components.websocket_api.http.connection.2940602496] Unable to serialize to JSON. Bad data found at $.event(event: state_changed).data.new_state(state: sensor.mail_amazon_packages).attributes.order[0]=<re.Match object; span=(22, 42), match='#1XXX'>(<class 're.Match'>, $.event(event: state_changed).data.new_state(state: sensor.mail_amazon_packages).attributes.order[1]=<re.Match object; span=(22, 42), match='#XXX'>(<class 're.Match'>
I restarted, now this error just repeats
2020-08-08 19:45:41 ERROR (MainThread) [homeassistant.components.websocket_api.http.connection.2971110104] Unable to serialize to JSON. Bad data found at $.result[77](state: sensor.mail_amazon_packages_delivered).attributes.order[0]=<re.Match object; span=(22, 42), match='#XXX'>(<class 're.Match'>, $.result[77](state: sensor.mail_amazon_packages_delivered).attributes.order[1]=<re.Match object; span=(22, 42), match='#XXX'>(<class 're.Match'>, $.result[91](state: sensor.mail_amazon_packages).attributes.order[0]=<re.Match object; span=(22, 42), match='#XXX'>(<class 're.Match'>, $.result[91](state: sensor.mail_amazon_packages).attributes.order[1]=<re.Match object; span=(22, 42), match='#XXX'>(<class 're.Match'>
I’m testing a fix now hold on.
EDIT: b19 up, you may have to overwrite the files manual in your custom_component directory if your frontend isn’t loading.
Thanks… B19 Working now…
Keep in mind it only effects the frontend, it doesn’t full stop Home Assistant, just killed the web UI
I managed to reboot and have HASS working for long enough to downgrade to b15 and then reboot, then update to b19.
Also, just an FYI for those looking for another way to get the Amazon emails into your “tracked” folder for the integration, my Amazon emails get sent to Protonmail. I’m sure I could configure the Proton Bridge and get it working that way on my server but that’s too much effort. Instead, I have the bridge running on my desktop and use Thunderbird. I set up a few Thunderbird filters/rules to copy the Amazon emails to the correct Gmail folder so the integration can see it. Works like a charm. Won’t work all the time as I shut down my desktop at night but it’s good enough.
So I just updated to the b20 version. It still doesn’t work, and now I have a different log:
Source: custom_components/mail_and_packages/sensor.py:884
First occurred: 10:34:31 AM (2 occurrences)
Last logged: 10:42:34 AM
return fut.result() File "/config/custom_components/mail_and_packages/sensor.py", line 71, in async_setup_entry
self.update()
self.data.update()
File "/config/custom_components/mail_and_packages/sensor.py", line 884, in get_items
IndexError: list index out of range
