Grab b21, that [0]
shouldn’t be in that first part
That did it. Thank you!
Shout out for the shout out to @firstof9 on the HASS blog for contributions in the main HASS project. @firstof9 has been the main contributor for a while to the mess of code I put together a year ago. Big thank you for all improvements and continued support to this small project and HASS as a whole!
My Amazon sensor isn’t working correctly, at least not based on how I understand it should work. I have packages out for delivery today (shipped yesterday) and the sensor.mail_amazon_packages
shows the order numbers but not a package count. Maybe I’m not reading the wiki section right?
Shipped yesterday, expected delivery is when?
Today. Some tomorrow. I just don’t think i’ve ever seen it increase.
Amazon packages delivered are not included in the count of total package delivered?
If the date in green text says “tomorrow” it currently doesn’t work.
Correct, Amazon is handled differently, currently.
Ok so that won’t get picked up? Curious then, how (or even does) the sensor value go up?
Yes to coming from shipment-tracking (edited spelling). Granted, this is with an email copied over from ProtonMail to Gmail (because I don’t feel like configuring a bridge just for this). But the component picks up the order numbers (including the one that’s out for delivery).
Actually just realized I have 2 out for delivery today.
Might be part of the update to allow forwarded emails
can you report your findings in the issue please? I’ll look into it in a moment.
Sure. I’m actually still on b21 so that shouldn’t be affecting. But i’ll throw it there. Wasn’t sure if it was a bug or not
Also if you like, do you have debug on? that will help a lot too
I’ll enable for an update.
Also, working on a way via Tasker to track Amazon packages that are out for delivery and when they’re near to home. So this will be Android only and will require AutoNotification. Thought process is use the NR integration to create a sensor then Tasker intercepts notification (and potentially clears it) -> Webhook to HASS (or in my case NodeRed) -> Add 1 to the sensor and finally update the sensor. Then when there’s a sensor update send me a notification that I can track in HASS.
I’m sure it could be done outside of NodeRed too. And it’s totally a kludge solution but…it should work. In theory
Ok so it works. The most difficult part is dealing with the deliveries and lowering the count so it’s accurate. Think I’ve got it figured out but I’ll test over the next few days (did some WFH-based upgrades to my desk/setup so lots of Amazon orders coming).
Been loving this card. Apparently have two entities I didn’t set triggers for when things are coming or arriving. What are these for? Is this FedEx?
mail_packages_in_transit
mail_packages_delivered
Note I thought the above was USPS but isn’t this USPS packages?
mail_usps_delivering
mail_usps_delivered
