Any of you experienced this error or know what causing it?
homeassistant.service: Main process exited, code=killed, status=7/BUS
homeassistant.service: Unit entered failed state.
homeassistant.service: Failed with result 'signal'.
It happens on two raspberry and a 16.04 ubuntu. New installation or old config. Same error. Happens on manual service start or randomly through the day.
On the pies, it happens when i restart hass from the webui.
On the ubuntu machine, when restarting hass from ssh or webui, rebooting, and if i manage to boot it up it crashes randomly after a while.
Is there any way to check a detailed error log?
edit: Strangly, these instances worked for months, (nearly a year). They are connected together by mosq mqtt.
I believe the TTS is whats killing my hass processes
This is the error msg i get when booting up HASS (it still boots fine, until tts is called)
pulseaudio[2679]: [pulseaudio] server-lookup.c: Unable to contact D-Bus: org.freedesktop.DBus.Error.NotSupported: Unable to autolaunch a dbus-daemon without a $DISPLAY for X11
pulseaudio[2679]: [pulseaudio] main.c: Unable to contact D-Bus: org.freedesktop.DBus.Error.NotSupported: Unable to autolaunch a dbus-daemon without a $DISPLAY for X11
Today i tried to play a test automation for TTS service (just a basic âhelloworldâ) when hass crashed. I couldnt even start it back up. It kept crashing at service startup with the status=7/BUS. I had to reboot the ubuntu server to succesfully start hass.
That suggests youâve got a deeper issue, it might be related to installing the desktop environment, Iâm unsure. Iâd try a fresh Pi3 install of Hassbian, so that youâre not running any GUI on your server.
