Main User customiztion in Hassio
Good day to everyone
i would to add a device tracker for my main user, i’m working on Hassio with hassos i was able in easy way to add a new person with device tracker but with my main user i’m in trouble.
As mai main person was created automatically by Hassio i’ve tryied with custom config but nothing. Any suggestions?
Here below my code in configuration.yaml
homeassistant:
  customize:
    person.stefano:
      device_trackers:
        - device_tracker.redmi_note_4_2
That’s not how you do it - see the person docs.
The simplest way is simply to enable person (which is the default if you’ve enabled default_config) and use the UI.
Now I’ve understood, person is not always a user or it’s better to say you can link a person to a user
Other questions could be, where the entity or device automatically discovered are stored?
Thanks a lot
Every entity can be found under Developer toolsStates
I’ve seen but I’ve also noticed that some entity are not listed. I can find the missing entity in other menu (like state or il Lovelace config ui) but not in the entity menu. Notice that the missing entity are registered in the history so they exists and works but simply are not present in the entity menu. May there be a setting to list a max number of entities? At the moment I have more than 50. The missing are from different platform.
Right, because not all are listed in Entities or Devices
Only integrations that support the Entity Registry (which is relatively new) show up in those places.
