Mains powered USB hub?
Edit: Well I proved its not a wifi issus. Completely turned off my wifi. I was still able to use Zwave network. So what in the heck is causing the devices kill the USB passthrough?
@Holdestmade have you had connection issues with yours?
So I got 3 of them, to put on each of my hubs. Started getting notifications my network, for example zigbee, was down. Then minute later, its back up. Check the history of the sinilinks and they are constantly becoming unavailable.
They are in easy wifi range but even if they werent and wifi was lost, that shouldent kill the USB pass through, right?
Heres my history from the 3 sinilinks I got. 5:54AM I did full reboot of HA device just to get a fresh start. It didnt help as you can see.
No, no WiFi issues at all been rock solid since I’ve had them. You’re not exceeding the 5a I assume ?
Ones connect to a hub Z dual zwave and zigbee. Another one is connected to a sonoff zigbee hub. Can’t imagine im anywhere close to that
I disconnected them from HA device and just plugged them into USB ports on my home PC. Gonna see if they still randomly go unavailable.
Because this thread is technically solved, I created a new one detailing my specific hardware issue.
