Title says it all. Been using it for a while and it works great. Change the parameters in the blueprint file if you want. Currently, it’s configured for Cannabis plant.
blueprint:
description: This blueprint helps maintain the VPD for plants by controlling a humidifier based on temperature, humidity, and VPD thresholds, and optionally sets the color of an RGB light based on the VPD value.
domain: automation
input:
temperature_entity:
description: Entity for the temperature of the plant
selector:
entity:
domain: sensor
humidity_entity:
description: Entity for the humidity
selector:
entity:
domain: sensor
humidifier_switch:
description: Switch entity to turn the humidifier on or off
selector:
entity:
domain: switch
light_entity:
description: Entity for the RGB light
selector:
entity:
domain: light
default: null
min_vpd:
description: Minimum VPD number input
selector:
number:
min: 0.0
max: 10.0
step: 0.1
max_vpd:
description: Maximum VPD number input
selector:
number:
min: 0.0
max: 10.0
step: 0.1
delta:
description: Delta value for VPD adjustments
selector:
number:
min: 0.0
max: 5.0
step: 0.1
- platform: state
entity_id: !input temperature_entity
- platform: state
entity_id: !input humidity_entity
condition: []
- variables:
temp: !input temperature_entity
humidity: !input humidity_entity
min_vpd: !input min_vpd
max_vpd: !input max_vpd
delta: !input delta
light_entity: !input light_entity
vpd: >
{% set temp_k = states(temp) | float + 273.15 %}
{% set es = 0.6108 * (2.71828 ** ((17.27 * (states(temp) | float)) / (states(temp) | float + 237.3))) %}
{% set ea = states(humidity) | float / 100 * es %}
{% set vpdvar = es - ea %}
{{ vpdvar }}
- choose:
- conditions:
- condition: template
value_template: "{{ vpd < (min_vpd - delta) }}"
sequence:
- service: switch.turn_off
entity_id: !input humidifier_switch
- choose:
- conditions:
value_template: "{{ light_entity is not none }}"
sequence:
- service: light.turn_on
entity_id: !input light_entity
rgb_color: [255, 0, 0] # Red color
- conditions:
value_template: "{{ vpd > (max_vpd + delta) }}"
sequence:
- service: switch.turn_on
- choose:
- conditions:
sequence:
- conditions:
value_template: "{{ (min_vpd - delta) <= vpd <= (max_vpd + delta) }}"
sequence:
- choose:
- conditions:
sequence:
rgb_color: [0, 255, 0] # Green color
