MAJOR UPDATE v1.2.0: HAOSKiosk Add-on – Display your dashboards directly on your HAOS server
HAOSKiosk allows users to view their dashboards and control Home Assistant using a display attached directly to their HAOS server (e.g., RPi or miniPC).
This efficient, standalone setup avoids the need to use/setup/power a separate device, screen and associated browser just to manage and monitor your HA instance, saving cost, energy, and space.
This update adds the following capabilities:
  • Audio support (Auto, HDMI, USB, None)
  • Ability to set Home Assistant Theme
  • Ability to assign arbitrary key and touchscreen gestures to commands (See configuration option: Gesture Command List)
  • Ability to set REST IP Address configuration option (in addition to existing REST Port option)
  • Added mouse buttons (left/right/middle/drag) to default Onboard keyboard layout
  • Added Command Whitelist regex configuration option to allow fine-grained control of gesture commands and rest server commands (replaces blunt Boolean Allow User Command)
Other key changes:
  • Improved Luakit browser refresh logic and overall stability
  • Changed Onscreen Keyboard configuration option default to True
  • Rewrote REST server
PLEASE SUBMIT BUG REPORTS AND FEATURE REQUESTS ON THE GITHUB SITE RATHER THAN DISCUSSING HERE
Here is the updated README
HAOS-kiosk
Display HA dashboards in kiosk mode directly on your HAOS server.
Author: Jeff Kosowsky (version: 1.2.0, January 2026)
Description
Launches X-Windows on local HAOS server followed by OpenBox window manager and Luakit browser.
Standard mouse and keyboard interactions should work automatically. Supports touchscreens (including onscreen keyboard) and screen rotation. Includes REST API that can be used to control the display state and to send new URLs (e.g., dashboards) to the kiosk browser.
You can press ctl-R at any time to refresh ( reload) the browser./ Alternatively, you can right click (or long press touchscreen) to access browser menu that includes options for page Back, Forward, Stop, and Reload.
NOTE: You must enter your HA username and password in the Configuration tab for add-on to start.
NOTE: The add-on requires a valid, connected display in order to start.
If display does not show up, try rebooting and restarting the addon with the display attached
Note: Luakit browser is launched in kiosk-like (passthrough) mode.
To enter normal mode (similar to command mode in vi), press ctl-alt-esc.
You can then return to passthrough mode by pressing ctl-Z or enter insert mode by pressing i.
See luakit documentation for available commands.
In general, you want to stay in passthrough mode.
NOTE: Should support any standard mouse, touchscreen, keypad and touchpad so long as their /dev/input/eventN number is less than 25.
NOTE: If not working, please first check the bug reports (open and closed), then try the testing branch (add the following url to the repository: GitHub - puterboy/HAOS-kiosk: Display HA dashboards in kiosk mode directly on your HAOS server · GitHub). If still no solution, file an issue on github bug report and include full details of your setup and what you did along with a complete log.
If you appreciate my efforts:
Buy Me a Coffee
Configuration Options
HA Username [required]
Enter your Home Assistant login name.
HA Password [required]
Enter your Home Assistant password.
HA URL
Default: http://localhost:8123
In general, you shouldn’t need to change this since this is running on the local server.
HA Dashboard
Name of starting dashboard.
(Default: “” - loads the default Lovelace dashboard)
Login Delay
Delay in seconds to allow login page to load.
(Default: 1 second)
Zoom Level
Level of zoom with 100 being 100%.
(Default: 100%)
Browser Refresh
Time between browser refreshes. Set to 0 to disable.
Recommended because with the default RPi config, console errors may overwrite the dashboard.
(Default: 600 seconds)
Screen Timeout
Time before screen blanks in seconds. Set to 0 to never timeout. (Default: 0 seconds - never timeout)
Output Number
Choose which of the connected video output ports to use. Set to 1 to use the first connected port. If selected number exceeds number of connected ports, then use last valid connected port. (Default: 1)
NOTE: This should always be set to 1 unless you have more than one video output device connected. If so, use the logs to see how they are numbered.
Dark Mode
Prefer dark mode where supported if True, otherwise prefer light mode. (Default: True)
NOTE: This applies to all url’s.
HA Theme
Set HA theme to given string. This setting applies only to HA dashboards and may override the value of DARK_MODE unless the theme support both dark and light variants. See HACS for downloadable themes to use. (Default: True)
NOTE: You can force the dark or light default theme specifically for HA dashboards by setting the theme to {"dark":true} or {"dark":false} respectively. Similarly, leaving the theme blank (or setting it to {} or Home Assistant) is equivalent to “auto”, in which case the default light or dark scheme is governed by the value of DARK_MODE.
HA Sidebar
Presentation of left sidebar menu (device-specific).
Options include: (Default: None)
  • Full (icons + names)
  • Narrow (icons only)
  • None (hidden)
Rotate Display
Rotate the display relative to standard view.
Options include: (Default: Normal)
  • Normal (No rotation)
  • Left (Rotate 90 degrees clockwise)
  • Right (Rotate 90 degrees counter-clockwise)
  • Inverted (Rotate 180 degrees)
Map Touch Inputs
Map touch inputs to the selected video output, so that the touch devices get rotated consistently with the video output. (Default: True)
Cursor Timeout
Time in seconds for cursor to be hidden after last mouse movement or touch. Cursor will reappear when mouse moved or screen touched again. Set to 0 to always show cursor. Set to -1 to never show cursor. (Default: 5 seconds)
Keyboard Layout
Set the keyboard layout and language. (Default: us)
Onscreen Keyboard
Display an on-screen keyboard when keyboard input expected if set to true. (Default: True)
To move, resize, or configure keyboard options, long press on the ... within the Return key. You can also resize the keyboard by pressing and dragging along the keyboard edges.
You can manually toggle keyboard visibility on/off by tapping extreme top right of screen or triple-clicing.
See GitHub - dr-ni/onboard: Onboard is an onscreen keyboard useful for everybody that cannot use a hardware keyboard; for example TabletPC users, mobility impaired users,... · GitHub for more details
Save Onscreen Config
Save and restore changes to onscreen keyboard settings made during each session if set to True. Overwrites default settings. (Default: True)
Xorg.conf
Append to or replace existing, default xorg.conf file.
Select ‘Append’ or 'Replace options.
To restore default, set to empty and select ‘Append’ option.
Audio Sink
Set the audio output sink. (Default: Auto)
Options include: ‘Auto’, ‘HDMI’, ‘USB’, ‘NONE’, picking the first respective audio output, HDMI audio output, and USB/Aux audio output.
REST IP address
IP address where the REST Server listens. (Default: 127.0.0.1) By default, for security it only accepts request from localhost – meaning that REST commands must originate from the homeassistant localhost.
If you want to accept requests from anywhere, then set to ``0.0.0.0` BUT BE FOREWARNED that unless you set up and use a REST Bearker Token, this is a security vulnerability.
REST Port
Port used for the REST API. Must be between 1024 and 49151. (Default: 8080)
Note for security REST server only listens on localhost (127.0.0.1)
REST Bearer Token
Optional authorization token for REST API. (Default: “”) If set, then add line -H "Authorization: Bearer <REST_BEARER_TOKEN>" to REST API calls.
Debug
For debugging purposes, launches Xorg and openbox and then sleeps without launching luakit.
Manually, launch luakit (e.g., luakit -U localhost:8123/<your-dashboard>) from Docker container.
E.g., sudo docker exec -it addon_haoskiosk bash
Gestures
Editable list of JSON-like key-value pairs where the key represents a (valid) gesture string and the value is a structured set of one or more action commands. See section “GESTURE COMMANDS” below for more details, examples, and default gestures.
Command Whitelist Regex
Regex (Python) of shell command that can be used in creating gesture commands or when running the run_command and run_commands REST APIs.
If left blank, then all commands are allowed except for those blacklisted as dangerous (otherwise, whitelist overrides internal blacklist).
Note that if you want to truly allow all commands, then use the wildcard .* but beware that it is DANGEROUS. If you want to disallow all commands set the regex to ^$.
Note that regardless of setting only commands found in /bin, /usr/bin, and /usr/local/bin of the HAOSKiosk add-on container are allowed.
REST APIs
launch_url {“url”: “”}
Launch the specified ‘url’ in the kiosk display. Overwrites current active tab.
Usage: curl -X POST http://localhost:<REST_PORT>/launch_url -H "Content-Type: application/json" -d '{"url": "<URL>"}'
refresh_browser
Refresh browser
Usage:
curl -X POST http://localhost:<REST_PORT>/refresh_browser
is_display_on
Returns boolean depending on whether display is on or off.
Usage:
curl -X GET http://localhost:8080/is_display_on
display_on {“timeout”: “”}
Turn on display. If optional payload given, then set screen timeout to <timeout> which if 0 means never turn off screen and if positive integer then turn off screen after <timeout> seconds
Usage:
curl -X POST http://localhost:<REST_PORT>/display_on
curl -X POST http://localhost:8080/display_on -H "Content-Type: application/json" -d '{"timeout": <timeout>}
display_off
Turn off display
Usage:
curl -X POST http://localhost:<REST_PORT>/display_off
xset
Run xset <args> to get/set display information. In particular, use -q to get display information.
Usage:
curl -X POST http://localhost:<REST_PORT>/xset -H "Content-Type: application/json" -d '{"args": "<arg-string>"}'
current_processes
Return number of currently running concurrent processes out of max allowed
Usage: curl -X GET http://localhost:8080/current_processes
run_command {“cmd”: “”}
Run command in the HAOSKiosk Docker container where cmd_timeout is an optional timeout in seconds.
Only allowed if Allow User Commands option is set to true.
Usage:
curl -X POST http://localhost:<REST_PORT>/run_command -H "Content-Type: application/json" -d '{"cmd": "<command>", "cmd_timeout": <seconds>}'
run_commands {“cmds”: [“”, “”,…], “cmd_timeout”: }}
Run multiple commands in the HAOSKiosk Docker container where cmd_timeout is an optional timeout in seconds.
Usage:
curl -X POST http://localhost:<REST_PORT>/run_commands -H "Content-Type: application/json" -d '{"cmds": ["<command1>", "<command2>",...], "cmd_timeout": <seconds>}'
NOTE: The API commands logs results to the HAOSkiosk log and return:
  "success": bool,
  "result": {
    "success": bool,
    "stdout": str,
    "stderr": str,
    "error": str (optional)
Note that run_commands returns an array of "results" of form: "results": [{"success": bool, "stdout": str, "stderr": str, "error": str (optional)},...]
You can format the stdout (and similarly stderr) by piping the output to: jq -r .result.stdout
In the case of run_commands, pipe the output to: jq -r '.results[]?.stdout'
HA REST Command Syntax
You can also configure all the above REST commands in your configuration.yaml as follows (assuming REST_PORT=8080)
rest_command:
  haoskiosk_launch_url:
    url: "http://localhost:8080/launch_url"
    method: POST
    content_type: "application/json"
    payload: '{"url": "{{ url }}"}'
  haoskiosk_refresh_browser:
    url: "http://localhost:8080/refresh_browser"
    method: POST
    payload: "{}"
  haoskiosk_is_display_on:
    url: "http://localhost:8080/is_display_on"
    method: GET
  haoskiosk_display_on:
    url: "http://localhost:8080/display_on"
    method: POST
    payload: '{% if timeout is defined and timeout is number and timeout >= 0 %}{"timeout": {{ timeout | int }}}{% else %}{}{% endif %}'
  haoskiosk_display_off:
    url: "http://localhost:8080/display_off"
    method: POST
    payload: "{}"
  haoskiosk_current_processes:
    url: "http://localhost:8080/current_processes"
    method: GET
  haoskiosk_xset:
    url: "http://localhost:8080/xset"
    method: POST
    payload: '{"args": "{{ args }}"}'
  haoskiosk_run_command:
    url: "http://localhost:8080/run_command"
    method: POST
    payload: '{% if cmd_timeout is defined and cmd_timeout is number and cmd_timeout > 0 %}{"cmd": "{{ cmd }}", "cmd_timeout": {{ cmd_timeout | int }}}{% else %}{"cmd": "{{ cmd }}"}{% endif %}'
  haoskiosk_run_commands:
    url: "http://localhost:8080/run_commands"
    method: POST
    payload: '{% if cmd_timeout is defined and cmd_timeout is number and cmd_timeout > 0 %}{"cmds": {{ cmds | tojson }}, "cmd_timeout": {{ cmd_timeout | int }}}{% else %}{"cmds": {{ cmds | tojson }}}{% endif %}'
Note if optional `REST_BEARER_TOKEN~ is set, then add the following two authentication lines to each of the above stanzas:
    headers:
The rest commands can then be referenced from automation actions as: rest_command.haoskiosk_<command-name>
Examples
actions:
  - action: rest_command.haoskiosk_launch_url
      url: "https://homeassistant.local/my_dashboard"
  - action: rest_command.haoskiosk_refresh_browser
  - action: rest_command.haoskiosk_is_display_on
  - action: rest_command.haoskiosk_display_on
      timeout: 300
  - action: rest_command.haoskiosk_display_off
  - action: rest_command.haoskiosk_current_processes
  - action: rest_command.haoskiosk_xset
      args: "<arg-string>"
  - action: rest_command.haoskiosk_run_command
      cmd: "command"
      cmd_timeout: <seconds>
  - action: rest_command.haoskiosk_run_commands
      cmds:
- "<command1>"
        - "<command2>"
REST API Use Cases
  1. Create automations and services to:
  • Turn on/off display based on time-of-day, proximity, event triggers, voice commands, etc.See ‘examples’ folder for trigger based on ultrasonic distance and HA boolean sensor.
  • Send dashboard or other url to HAOSKiosk display based on event triggers or pre-programmed rotation (e.g., to sequentially view different cameras).
  • Create simple screensavers using a loop to iterate through an image folder and call launch_urlSee ‘examples’ folder for simple Bash script example screensaver.
  1. Use custom command(s) to change internal parameters of HAOSKiosk and the luakit browser configuration.
GESTURE COMMANDS
Each Gesture Command is a JSON-like key-value pair where the key is a valid Gesture String corresponding to a specific sequence of button clicks or finger taps and the value is an Action Command containing a structured set of one or more commands to execute when the gesture is recognized.
The formats of the Gesture Strings and Action Commands are precisely defined, so if they fail to load check your log for error messages.
Gesture String Keys
Each Gesture String key is of form:
<CONTACTS>_<DEVICE>_<CLICKS>_<GESTURE>
where:
<CONTACTS> field captures he maximal contact set during the gesture. Either:
  • A number (N, N+, N-) representing the (maximum) number of contacts (buttons or fingers), where N+ and N- respectively indicate greater than and less than or equal to N
    • List of button numbers and/or corresponding button names (for mouse-type devices only) e.g., [Left, Right], [1, 3], [Left, 3]
<DEVICE> field identifies the type of input contact either by:
  • Device Type (e.g., MOUSE, TOUCH) or the wildcard ANY
  • Mechanism (e.g., Button, Finger)
<CLICKS> field captures the number (M, M+, M-) of clicks/taps in the gesture where M+ and M- are respectively greater than or less than or equal to M (e.g., 1 for single-click, 2 for double-click, 2+ for 2 or more clicks)
<GESTURE> field specifies the general class or device-specific name of the gesture
  • Class (e.g., CLICKTAP, DRAG, SWIPE, LONG, CORNER_<name>) or the wildcard ANY
  • Friendly Name (e.g., Click, Tap, Drag, Swipe, Long Click, Long Tap). Note the names may be device-specific (e.g., Click for Mouse, Tap for Touch)
Additional notes regarding gesture naming:
  • ANY is a wildcard matching any gesture
  • Corners are named: CORNER_TOPLEFT, CORNER_TOPRIGHT, CORNER_BOTLEFT, CORNER_BOTRIGHT
  • DRAG and SWIPE differ primarily in velocity (SWIPE is faster)
  • Both DRAG and SWIPE may include suffixes _LEFT, _RIGHT, _UP, or _DOWN
  • Undirected DRAG/SWIPE act as wildcards for their directional variants
  • LONG can take the optional device-specific suffixes _CLICK or TAP
  • CORNER_ triggers when click or tap is in within “click_dim” of the named corner (default 5 pixels)
  • DRAG, SWIPE, and LONG (and their variants) are always single-click gestures
  • Matching is case-insensitive
Note that Gesture String Keys are matched in order, so that you should always enter keys from particular to more general when using wildcards
Validity Checks
  • Single-click gestures cannot be used if more than 1 Click/Tap
  • Click applies only to mouse devices; Tap applies only to touch devices
Valid Examples
[Left, Right]_MOUSE_3_CLICKTAP
[1,2,3]_MOUSE_1+_CORNER_TOPRIGHT
2_TOUCH_1_DRAG_LEFT
2_Button_1_Long Click
3_Finger_2_Tap
2+_Finger_1_Swipe_down
1_ANY_2-_CLICKTAP
1+_ANY_1+_ANY
Invalid Examples
1_Mouse_3-Tap     (Tap is for Touch)
1-Touch_2-Long    (Long gestures must be single contact)
Action Command Values
Action command values may be expressed in one of three forms:
  1. Single command string e.g., "ls -a -l" Note that an empty string acts as a No-Op – i.e., it will be ignored and can be used with wildcard gestures to block actions of lower priority.
  2. List of commands - Each command may be either:
  • A string: "echo hello"
    • An argv-style list: ["ls", "-a", "-l"]
Example ["echo hello", ["ls", "-a", "-l"]]
Note that the commands themselves can either be shell commands or kiosk-specific internal commands that begin with the prefix ‘kiosk.’
Examples include:
  1. Command dictionary with required key "cmds": and optional keys: "msg": and "timeout"
Examples:
{"cmds": "ls -al", "msg": "list all files", "timeout": 1}
{"cmds": ["echo hello", ["ls", "-al"]], "msg": "echo hello and list all files", "timeout": 5}
Defaults & Examples
The following gestures are included by default (but can be removed by clicking on the X next to them):
  • Single Tap or Click in Top Right Corner: Toggle on-screen keyboard
"1_ANY_1_CORNER_TOPRIGHT": {"cmds": [["dbus-send", "--type=method_call", "--dest=org.onboard.Onboard", "/org/onboard/Onboard/Keyboard", "org.onboard.Onboard.Keyboard.ToggleVisible"]], "msg": "Toggling Onboard keyboard..."}
  • Left Triple Mouse Click: Toggle on-screen keyboard
"[Left]_MOUSE_3_CLICK": {"cmds": [["dbus-send", "--type=method_call", "--dest=org.onboard.Onboard", "/org/onboard/Onboard/Keyboard", "org.onboard.Onboard.Keyboard.ToggleVisible"]], "msg": "Toggling Onboard keyboard..."}
  • 3-Finger Single Tap: Toggle on-screen keyboard
"3_TOUCH_1_TAP": {"cmds": [["dbus-send", "--type=method_call", "--dest=org.onboard.Onboard", "/org/onboard/Onboard/Keyboard", "org.onboard.Onboard.Keyboard.ToggleVisible"]], "msg": "Toggling Onboard keyboard..."}
  • 3-Finger Double Tap: Refresh Browser
"3_TOUCH_2_TAP": {"cmds": [["xdotool", "key", "--clearmodifiers ctrl+r"]], "msg": "Refresh Browser"}
  • 3-Finger Triple Tap: Restore Default HA dashboard (HA_URL/HA_Dashboard)
"3_TOUCH_3_TAP": {"cmds": "luakit \"$HA_URL/$HA_DASHBOARD\"", "msg": "Restore default dashboard"}
  • 3-Finger Left Swipe: Go forward one element in browser history
"3_TOUCH_1_SWIPE_LEFT": {"cmds": [["xdotool", "key", "--clearmodifiers", "ctrl+Right"]], "msg": "Go forward in the history browser"}
  • 3-Finger Right Swipe: Go back one element in browser history
"3_TOUCH_1_SWIPE_RIGHT": {"cmds": [["xdotool", "key", "--clearmodifiers", "ctrl+Left"]], "msg": "Go back in the history browser"}
  • 2-Finger Triple Tap: Open Google search
"2_TOUCH_3_TAP": {"cmds": "luakit \"www.google.com\"", "msg": "Open Google search"}'
This is great, thanks for sharing. I am just getting into HA and have a RPi4 with the v2 of the display, i don’t suppose there is anychance of getting DSI support for the Rpi display 2?
Ah i see that in a previous update, people have mentioned the DSI display2 and have made it work, i will investigate bit more a so far i get the error:
[16:24:29] INFO: DRM video card driver and connection status:
[16:24:29] INFO: ERROR: No connected video card detected. Exiting…
[16:24:29] INFO: Cleaning up and exiting…
I LOVE YOU <3 Thank you thank you thank you. I got a HP slice G2 refurbished pc, with usb c 12" touchscreen. I am new to all this and I realized I want to run supervised, bare metal server, for addons and stuff but came to sad realization that is actually just shows the terminal, no dashboard. I mean for 200 euros i5 8g of ram, nvme, bang and olufsen speakers, touchscreen, ok, i can live with that, got a nice server. But damn man, you just made me smile, it just started on first launch and it works like a charm, only small quirk is that sometimes i have to click back 2 times to go back a page on dashboard, forward clicks on cards work perfectly…once again THANK YOU <3 So with weird HP pc intended for microsoft teams and usb c touch it works, no special settings needed.
Thanks. Your praise means a lot.
Can you explain better what you mean by needing to click twice? Is that just with touch or also with a keyboard? What about using the right-click menu back-page? What about using the back page gesture that is added to the last release? If this is a bug, I would love to nail it!
BTW, nothing says love like a cup of coffee if you want to contribute :slight_smile:
See the link on the README If you are interested :slight_smile:
Just released v1.3.0 (February 2026) with the following new features and improvements – most focused on added REST_API, key binding, and gesture functionality including:
  1. Ability to enable/disable keyboard and touch inputs (to protect kiosk)
  2. Ability to mute/unmute and set audio volume
  3. Ability to remotely take screenshots and monitor the kiosk via VNC
v.1.3.0 (February 2026)
  • Added more key bindings for opening/closing/rotating tabs and windows
  • Add x11vnc server to facilitate remote viewing or debugging of kiosk
  • Added ‘screenshot’ function to REST_API and gesture action commands
  • Added enable_inputs and disable_inputs functions to REST_API to allow
    locking down (and unlocking) inputs by disabling keyboard, mouse and
    touch functions
  • Added mute_audio, unmute_audio and toggle_audio functions to
    REST_API to change audio state (toggle_audio also added to gesture action commands)
  • Converted default gestures in config.yaml to use internal
    kiosk.<function> handlers rather than calling shell functions
  • Added short list of built-in keyboard shortcuts
  • Enhanced ultrasonic-trigger.py example with new functionality to
    enable/disable inputs, mute/unmute audio, and rotate through a list of URLs
  • Added INSTRUCTIONS section to README.md (thanks: @cvroque)
  • Added more details to README.
This is a good add-on and thanks for contributing to the community. I think it would be really helpful and cost effective for a lot of people to use this (including myself).
I spent the entire weekend tinkering with this but didn’t have any luck, specifically sorting out these issues.
The good:
-HAOS-Kiosk works well and loads up quickly and properly using a Freenove 7 Inch Touchscreen Monitor for Raspberry Pi
-Dashboard looks great and everything works well except…
The “Needs Improvement”:
-When using HAOS-Kiosk on a touch screen, the first “wake-up” touch should be ignored as to not accidently hit a button on the display.
-Sliders not working properly meaning most music volume modules won’t work. (I see this issue is being addressed on GitHub though) I’m working on a work-around for this.
-Touch wont rotate with screen rotation (I see this is also addressed)
-A little slow on respossiveness
Anyways, this add-on is just about there, I know its a fresh development so I’ll keep working on it because it would really help me out if it did work to my needs.
Thank you again.
