I have a sensor: “sensor.solveien_total_lifetime_energy_output_2”. This sensor counts lifetime kWh produced by my solar panels.
I like to make two new sensors that gets it value from the “solveien_total_lifetime_energy_output_2” sensor.
The two new sensors need to be updated with new values, once each month, day 1 at 00:00:01, and the second sensor need to be updated once a year, January 1. at 00:00:01.
The monthly sensor can be named: growatt_lifetime_mnd_value
The yearly sensor can be named: growatt_lifetime_year_value
I run my manually made sensors (ie not made in visual editor) written in yaml, in the file: configuration.yaml
Hi. Today I use Utility meters. But when the input sensors i use in the Utility meter, has some down time, eg after each HA update, the sum of the Utility meters get lagging the correct value. This is the reason behind my question above. Because with your help, I will have fixed values set every 1. day of month, and 1. day of a new year. :-). These fixed values I plan to use in again new sensor I will write, where I write and store of of my own written sensors today, in the configuration.yaml.
Thanks. I made this work, copy value of one sensor to a new. Now I need to find out how I run this only once a month and once a year. And not like now, where it is updated all the time
