Make a string sensor using template as numeric sensor
I have a Switch Sensor that deliveres the current consumption. But after the last Home Assistant Update the value is a string, not a numeric anymore.
So I decided to create a template sensor to cast the value to float:
    pool_verbrauch_watts:
        friendly_name_template: "Pool Verbrauch (Watt)"
        value_template: "{{ states('sensor.meerschweinchen_current_consumption') | float }}"
        unique_id: "pool_verbrauch_watts"
If I test the new sensor using the template function in developer tools, I get this Messages:
{{states(‘sensor.pool_verbrauch_watts’)}}
→ 5.5
{{states(‘sensor.pool_verbrauch_watts’) | float > 5 }}
→ True
{{states(‘sensor.pool_verbrauch_watts’) > 5 }}
→ TypeError: ‘>’ not supported between instances of ‘str’ and ‘int’
Can someone tell me, what’s wrong with the template sensor?
Best regards!
A state is always a string.
Thank you. What do you recommend?
The Problem is, that a numeric trigger of an Auto script does not work - also with the new template sensor.
You have to specify a unit_of_measurement in your template sensor’s configuration.
I’m not sure what you mean here.
could you post an example of what you tried that doesn’t work?
I’m using now a switch template sensor with value_template checking for the desired value. That is working for me.
Would you please so kind and share your solution code with us?
Definitely worth seeing what was allegedly done to circumvent this:
{{states('sensor.pool_verbrauch_watts') > 5 }}
Because that’s a perfectly normal error message due to a mistake in the template (comparing mixed value types). Like francisp said, all state values are strings so if you want to compare it to a numeric value you have to convert it to int or float.
