Hei Guys,
I created an automation, that is triggered, when Temperature is lower than a threshold ( hard coded in automation ). This trigger is tested successfull and working.
Is there any option to make that threshold via a UI variable ( helper ?).
Would be nice to achieve that via UI configuration.
I just tested it with a simple configuration but had it with another (iāve not access because itās in friendās house)
Iām using the UI and testing with this trigger:
You wouldnāt be the first person this week to tell me they are running the current version when theyāre not, please tell me the version number that appears on the page Configuration > Info
