I’ve converted a binary sensor to a lock using this binary sensor template
back_door_lock:
friendly_name: "Back Door"
device_class: lock
value_template: >-
{{ is_state('binary_sensor.lumi_lumi_sensor_magnet_aq2_ce212304_on_off', 'off') }}
Trouble is the domain appears as ‘binary_sensor’ I need it show as lock.
I tried to use the lock template but can’t get it to validate as there is not service called when a binary sensor changes state.
lock:
value_template: "{{ is_state('binary_sensor.lumi_lumi_sensor_magnet_aq2_ce212304_on_off', 'off') }}"
lock:
service: ???
entity_id: binary_sensor.lumi_lumi_sensor_magnet_aq2_ce212304_on_off
unlock:
service: ???
Any ideas?
tom_l
September 10, 2020, 4:36pm
2
What do you do now to lock und unlock the door?
Why do you need the domain to be a lock?
It’s a dumb lock where I just detect the lock state using a binary sensor
I need it to be the lock domain as the addon i’m using requires it to show as a lock domain
I have tried that but couldn’t get it to work as there is no corresponding service I can use.
What add-on are you using that requires a lock?
Change the device class to lock. Go to settings (make sure you have advanced mode on) there you see customize option. Select your binary_sensor entity and edit the device class to lock.
Or are you trying to achieve something else?
petro
(Petro)
September 10, 2020, 4:56pm
9
Make a dummy script.
script:
dummy:
sequence:
delay: "00:00:00"
and a template lock
lock:
lock:
service: script.dummy
unlock:
Already tried that
back_door_lock:
device_class: lock #customised device class
blando
January 19, 2023, 1:42pm
12
Thank you! Works perfect!
