Adax has finally added an endpoint for energy readings to its API:
“/rest/v1/energy_log/{roomId} – returns hourly energy log from current time back to 1 week for the specified room in 1h intervals.”
Can we please adjust the Adax - Home Assistant Integration to be able to use the Energy readings for the Energy Dashboard etc.
Thanks a lot!
Michael
Hakan007
(Hakan)
January 6, 2025, 11:29am
3
m.rebitzki.vennhoff:
Energy Dashboard
This information would be great to have
//Hakan
Any news on this feature request ?
It would be great to have it.
odelma
March 11, 2025, 12:39pm
5
Not maybe news as such, but I was wondering about the status of this as well and found a fork with some additions related to energy monitoring: GitHub - parholmdahl/home_assistant_adax: Integration for Adax heaters
Has anyone tried this version?
edwinvdg
(Edwin)
March 13, 2025, 12:37pm
6
Yeah, I would love to have that info on my energy dashboard
I agree, this could I also use in my setup with my 7 ADAX radiators.
TreGrill
(Trond Egil Gjelsvik-Bakke)
May 6, 2025, 10:42am
8
Any update on this ?
Been looking for this for some time, but it seems like the development has stopped…
I’m also looking for this.
It seems there needs to be a bigger change to the entire integration to be able to do it. And as far as i can se the change that is needed before they can work on the energy endpoints had a update that was merged last week. I’m not a developer, but hopefully this will let them start work on the energy integraton.
dev
← LazyTarget:feature/adax/data-coordinator
opened 12:21PM - 28 Feb 25 UTC
## Proposed change
This implements two DataCoordinators for the Adax-integrat… ion, one for each connection type (Cloud and Local).
This is something that has been requested as a dependency via another PR: #131314
When fetching from Adax API, the results are stored in the Coordinator.
Entities listen on changes in the coordinator via the `_handle_coordinator_update` callback function
If an entity requests updates then it will be flagged to the coordinator via the `await self.coordinator.async_request_refresh()`
`SCAN_INTERVAL` has been set to 60 seconds
Added a version to `manifest.json` since it was missing
## Type of change
- [ ] Dependency upgrade
- [ ] Bugfix (non-breaking change which fixes an issue)
- [ ] New integration (thank you!)
- [ ] New feature (which adds functionality to an existing integration)
- [ ] Deprecation (breaking change to happen in the future)
- [ ] Breaking change (fix/feature causing existing functionality to break)
- [X] Code quality improvements to existing code or addition of tests
## Additional information
- This PR fixes or closes issue: fixes #
- This PR is related to issue:
- Link to documentation pull request:
- Link to developer documentation pull request:
- Link to frontend pull request:
## Checklist
- [x] The code change is tested and works locally.
- [x] Local tests pass. **Your PR cannot be merged unless tests pass**
- [x] There is no commented out code in this PR.
- [x] I have followed the [development checklist][dev-checklist]
- [x] I have followed the [perfect PR recommendations][perfect-pr]
- [x] The code has been formatted using Ruff (`ruff format homeassistant tests`)
- [x] Tests have been added to verify that the new code works.
If user exposed functionality or configuration variables are added/changed:
- [ ] Documentation added/updated for [www.home-assistant.io][docs-repository]
If the code communicates with devices, web services, or third-party tools:
- [ ] The [manifest file][manifest-docs] has all fields filled out correctly.
Updated and included derived files by running: `python3 -m script.hassfest`.
- [ ] New or updated dependencies have been added to `requirements_all.txt`.
Updated by running `python3 -m script.gen_requirements_all`.
- [ ] For the updated dependencies - a link to the changelog, or at minimum a diff between library versions is added to the PR description.
To help with the load of incoming pull requests:
- [ ] I have reviewed two other [open pull requests][prs] in this repository.
[prs]: https://github.com/home-assistant/core/pulls?q=is%3Aopen+is%3Apr+-author%3A%40me+-draft%3Atrue+-label%3Awaiting-for-upstream+sort%3Acreated-desc+review%3Anone+-status%3Afailure
[dev-checklist]: https://developers.home-assistant.io/docs/development_checklist/
[manifest-docs]: https://developers.home-assistant.io/docs/creating_integration_manifest/
[quality-scale]: https://developers.home-assistant.io/docs/integration_quality_scale_index/
[docs-repository]: https://github.com/home-assistant/home-assistant.io
[perfect-pr]: https://developers.home-assistant.io/docs/review-process/#creating-the-perfect-pr
